rs6er Posted May 24, 2009 Share Posted May 24, 2009 I bought a Borla because I didn't want my car to be too loud. I know a downpipe will make it louder. Is there a good one that will mate up with my Borla well without too much noise? Link to comment Share on other sites More sharing options...
Bolksey85 Posted May 24, 2009 Share Posted May 24, 2009 Cobb. Mates to the Borla donut flange and is heavy duty enough to not sound tinny. Link to comment Share on other sites More sharing options...
Darkness of Death Posted May 24, 2009 Share Posted May 24, 2009 and put a second resonator on the catback ~ Link to comment Share on other sites More sharing options...
HansGT Posted July 14, 2009 Share Posted July 14, 2009 ^ relevance to the question? Pick any 3" DP you want and get this... http://www.fredbeansparts.com/servlet/the-2651/3-Inch-Downpipe-to/Detail Or gut your stock DP and bolt the Borla right up. Link to comment Share on other sites More sharing options...
snow05gtRI Posted July 15, 2009 Share Posted July 15, 2009 Cobb mated to my Borla with no issue. Does make it louder, but to the level I wanted. I almost cut out the resonator when I was Stage 1. I'd only get a full 3" DP if you plan on going full 3" catback somewhere down the road. otherwise you're just building in a 0.5" wall right where the DP meets the cat back (if using suggested adapter), instead of the tapered section Cobb has. Link to comment Share on other sites More sharing options...
tetsulo Posted July 15, 2009 Share Posted July 15, 2009 I picked up one of these to connect my SPT CBE and my Invidia DP. I couldn't bring myself to cut the taper out of the SPT exhaust. http://www.rallysportdirect.com/shop/elite-awd-down-pipe-stocktapered-cat-back-adapter-p-3911.html It was a little rough around the edges out of the box -- the gasket it came with seems like JUNK vs the gasket that came with my Invidia DP and the holes for the bolts to go through needed a little loving with a file/dremel. Looks like it was cut out from a low end laser bed or something. The welds are excellent and provides a nice taper from 3" to 2.5" instead of the wall as mentioned above. Also comes with new spring bolts and heavy springs to keep some flex in the exhaust system. I've test fitted it to the DP but won't be doing the actual install until RomRaider supports my car's firmware. Just another option to think about. Matt Link to comment Share on other sites More sharing options...
korpsepatrol Posted July 15, 2009 Share Posted July 15, 2009 i would definitely say cobb if you can find it. Since cobb will mate up better with its 2.5 inch taper at the end. 2008 6mt Legacy Gt Spec B DGM - Not so Stock/Work in progress 2006 5mt Legacy Gt OBP - Sold 2005 5eat Legacy Gt OBP - RIP R.I.P Coxx Link to comment Share on other sites More sharing options...
