Guest Posted November 4, 2009 Share Posted November 4, 2009 Btw, Subaru really made sure to make the turbo upgrade a bitch. Look at the compressor cover with the flanges, it even has a flange for the inlet. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted November 4, 2009 Share Posted November 4, 2009 Btw, Subaru really made sure to make the turbo upgrade a bitch. Look at the compressor cover with the flanges, it even has a flange for the inlet. It will be easier then the stupid inlet tube we have now. I for one, am actually quite excited to see what Subaru will have in-store for us. Maybe the next STI (cause LGT is too big now) will have DI, and the turbo under the motor. That might make for some wicked mod potential. Maybe a TS3076 will spool at 3000 rpm given the proximity to the cylinder heads. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
CasopoliS Posted November 4, 2009 Author Share Posted November 4, 2009 I like the flange. Yes, it makes it harder to upgrade (more flanges will be needed)... but at the same time you feel more comfortable about the seal IMO. Compressing an O-ring with 2-bolts makes for a good seal and you don't have to worry about hose clamps, etc. At the same time, there is less room for "give". You will have to have a hump-hose on aftermarket intakes... I foresee a flange being made that you clamp a hump hose onto for aftermarket intakes. Link to comment Share on other sites More sharing options...
whitetiger Posted November 5, 2009 Share Posted November 5, 2009 Well, I should have said - it's unlikely it's twinscroll. One, the exhaust housing doesn't look like one. Two, this: http://img.photobucket.com/albums/v307/Rutch/CarPics/noscroll.jpg If the gasket is as pictured, then its prolly not a TS, but dont forget that this ins only a sketch. It may be drawn wrong. definitive proof would be pics of the actual turbo, which we have not seen yet. Link to comment Share on other sites More sharing options...
whitetiger Posted November 5, 2009 Share Posted November 5, 2009 BTW, wher did you find that diagram? ive been loking for a 2010 parts catalog with pics. do thay have a diagram of the actual turbo itself? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted November 5, 2009 Share Posted November 5, 2009 http://www.atpturbo.com/mm5/graphics/00000001/Catalog%20Images/Turbochargers/GRT-TBO-050_450-2.jpg And a IHI TS turbine rear view: http://img185.imageshack.us/img185/4436/vf372no0.jpg Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Guest Posted November 5, 2009 Share Posted November 5, 2009 ^ I know very well, I have that turbo Note, the inlets are still offset and you can see the scrolls in exhaust housing. If it was a twinscroll the gasket should separate both streams. Link to comment Share on other sites More sharing options...
Rutchard Posted November 5, 2009 Share Posted November 5, 2009 Ugh, I'm going to my dealership tonight to order the gasket along with some other parts. If the gasket is oval like in the service manual, then it is definately NOT twin scroll. If the streams aren't separated, it's not twin scroll. I know when I posted my pics I said it was twin scroll, I've studied it more, I really doubt it is TS now. If you take a good look at that JDM manifold and turbo off the car, you can see the hotside of the turbo just funnels both exhaust streams into one. Our best bet at this point is that they start using this turbo placement on the WRX/STi eventually. Still a crapshoot, but I wouldn't think they'd do all this redesigning just for one chassis. Link to comment Share on other sites More sharing options...
Guest Posted November 5, 2009 Share Posted November 5, 2009 Ugh, I'm going to my dealership tonight to order the gasket along with some other parts. If the gasket is oval like in the service manual, then it is definately NOT twin scroll. If the streams aren't separated, it's not twin scroll. I know when I posted my pics I said it was twin scroll, I've studied it more, I really doubt it is TS now. If you take a good look at that JDM manifold and turbo off the car, you can see the hotside of the turbo just funnels both exhaust streams into one. Our best bet at this point is that they start using this turbo placement on the WRX/STi eventually. Still a crapshoot, but I wouldn't think they'd do all this redesigning just for one chassis. In the past they were known to experiment with strange setups on Legacy turbo. 3rd gen. JDM turbo (and also 2nd, but I am unsure) had a weird twin turbo setup, while Impreza kept the original single turbo setup (exhaust plumbing wise) from the 1st generation Legacy turbo. JDM 4th generation Legacy got a unusual twinscroll setup incompatible with the JDM STI, while USDM went back to Impreza layout. In other words - who knows... Link to comment Share on other sites More sharing options...
wpgspecb Posted January 23, 2010 Share Posted January 23, 2010 it seems like for a car that's gonna get driven and sold all over the world, a front, low mounted turbo doesn't seem like the best spot? I mean isn't a lot of crap gonna get all over that thing, even with a shield/skidplate and whatnot. Link to comment Share on other sites More sharing options...
D0WNxSH1FT Posted January 27, 2010 Share Posted January 27, 2010 it seems like for a car that's gonna get driven and sold all over the world, a front, low mounted turbo doesn't seem like the best spot? I mean isn't a lot of crap gonna get all over that thing, even with a shield/skidplate and whatnot. Go ask all the Evo owners of the world. Link to comment Share on other sites More sharing options...
Reuben Posted January 27, 2010 Share Posted January 27, 2010 And what do they have to say? Cause i was wondering about that when these things came out. As for the twin and single scroll, the JDM 2L's will undoubtedly be twin. No idea about the "world spec" 2.5's though. Link to comment Share on other sites More sharing options...
mwiener2 Posted February 2, 2010 Share Posted February 2, 2010 Go ask all the Evo owners of the world. theirs is still a good foot higher than the new GT's My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
BryanBNR Posted August 26, 2010 Share Posted August 26, 2010 who is first in line for a 2010+ BNR Supercars hybrid turbocharger? Link to comment Share on other sites More sharing options...
KGB Posted October 21, 2015 Share Posted October 21, 2015 Thinking of putting a bigger turbo on the LGT 2010+ new low mount location. But the exhaust manifold seems to be very restrictive, I guesstimate the ID of the runners to be ~30mm, only. that, compare to the 40mm Exhaust port IDs... And, the merger is only ~55-degrees - plenty of exhaust turbulence and some will definitely be pushed back into the opposing cylinder... Is there anybody who makes an after market upgrade to exhaust manifold for there 2010+ LGT which address the above issues ? Thanks! Link to comment Share on other sites More sharing options...
GTEASER Posted October 21, 2015 Share Posted October 21, 2015 Holy old thread resurrection man!!! I think 5 years + is a new record. Lol! Take some time to look in the 5th Gen model specific forum. There are multiple discussions going on right now about aftermarket headers, etc. Also, folks have been putting 18g and 20g turbos on our cars for some time now. Our header setup is great for low end torque, not top end power like other Subarus. We need to go twin scroll if that's ever going to happen, so join those other discussions. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
ICE7 Posted January 3, 2019 Share Posted January 3, 2019 Love it Link to comment Share on other sites More sharing options...
Scubaboo Posted February 24, 2019 Share Posted February 24, 2019 ^You're a little early for the regular 5 year resurrection. Link to comment Share on other sites More sharing options...
