Beanboy Posted April 25, 2009 Share Posted April 25, 2009 Background: Superpro LCA bushings, cusco lower control arm brace, JDM bilsteins, on for over year 8K+ miles. RE9060s with 47 psi front, 44 psi rear hot. On the highway today, noticed that if I pass left and right past dead center, I could feel the car made the direction change, but yet the weight of the car took a moment to catch-up and settle into the turn. Almost feels like a little float around dead center. Would think this points to LCA bushings, but being solid poly, they look fine externally. Was the first really hot day since I got the tires back in November, perhaps I'm feeling a little fall-off with the increased hot pressure, also think the front to rear difference is a little much which I will correct. Just curious if I'm looking in the right spot, and what else might cause the above situation. Thanks! -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
Underdog Posted April 25, 2009 Share Posted April 25, 2009 Are you running stock springs and swaybars? The Crimson Dynamo Link to comment Share on other sites More sharing options...
Beanboy Posted April 25, 2009 Author Share Posted April 25, 2009 No, JDM Spec B Rev A Bilstein strut and springs, stock sways. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
