tommypenguin Posted April 21, 2009 Share Posted April 21, 2009 I didn't know that as you increase core thickness you increase heat soak, makes sense. So when selecting a TMIC for a daily driver ideally you want the one that heat soaks the least, ie largest surface area and thinnest core available? Link to comment Share on other sites More sharing options...
praedet Posted April 21, 2009 Share Posted April 21, 2009 Correct Link to comment Share on other sites More sharing options...
praedet Posted April 21, 2009 Share Posted April 21, 2009 I didn't know that as you increase core thickness you increase heat soak, makes sense. So when selecting a TMIC for a daily driver ideally you want the one that heat soaks the least, ie largest surface area and thinnest core available?No, for a daily driver, I wouldn't worry about it at all... For a drag racing TMIC, you want very little heat soak. For a road racer, you are more concerned w/ pressure drop and flow capacity... Link to comment Share on other sites More sharing options...
tommypenguin Posted April 21, 2009 Share Posted April 21, 2009 No, for a daily driver, I wouldn't worry about it at all... For a drag racing TMIC, you want very little heat soak. For a road racer, you are more concerned w/ pressure drop and flow capacity... So in drag racing, or I take it sitting around in rush hour in the summer, would having a thinner TMIC be the only scenarios a thinner core is more beneficial than running a thicker one in terms of heat soak. If you are constantly moving, having a thicker core would always be more beneficial. The next question I have for you ted, is how much cooler like in this case, would the thinner top mount be if everything is the same in terms of length and width only difference is a ½ inch in core thickness. Link to comment Share on other sites More sharing options...
grocery getter Posted April 21, 2009 Author Share Posted April 21, 2009 Jae, Where did you get your TMIC size info? NASIOC has: Perrin: 20" x 7" x 4" APS: 20" x 7.5" x 4.5" And he is right, thicker does mean more flow capacity, but cooling can be much worse... Off the vendor site rallysportdirect Link to comment Share on other sites More sharing options...
praedet Posted April 21, 2009 Share Posted April 21, 2009 Thanks^^^ So, for me personally, I don't really push it from light to light. So a little heatsoak in traffic is not a big deal as I am not going to push my car there. I am more likely to do it on a rolling start getting on the freeway, or to pass... There is truly a balance between making the core thicker so you have more flow volume and less pressure drop, and cooling. If the core is really thick, the air coming in the scoop does not want to go through the passages in the TMIC, so cooling actually gets worse, not better. It is all a balance, and fitment can be more important than any of it So in drag racing, or I take it sitting around in rush hour in the summer, would having a thinner TMIC be the only scenarios a thinner core is more beneficial than running a thicker one in terms of heat soak. If you are constantly moving, having a thicker core would always be more beneficial. The next question I have for you ted, is how much cooler like in this case, would the thinner top mount be if everything is the same in terms of length and width only difference is a ½ inch in core thickness. Link to comment Share on other sites More sharing options...
tingtang Posted April 21, 2009 Share Posted April 21, 2009 so pretty much you have to have a balance in height width and thickness?? so too big any direction is not necessarily better?? unless you have a balanced core?? Link to comment Share on other sites More sharing options...
grocery getter Posted April 21, 2009 Author Share Posted April 21, 2009 Got the first snag of the build....looks like on the 08+ the air pump assembly needs to be removed all together and blocked using a cosworth bracket to get the APS inlet on. That means no more air pump and more room under the hood (used by Subaru to get more air into the car during start up and help out emissions in the begining....oh well). Outside of that everything is progressing along. Link to comment Share on other sites More sharing options...
tingtang Posted April 22, 2009 Share Posted April 22, 2009 ^ well i hope the rest of the build goes a smooth as eggs Link to comment Share on other sites More sharing options...
grocery getter Posted April 22, 2009 Author Share Posted April 22, 2009 Thanks - usually one or two in ever major build....the only problem is the longer it takes the more items I want to buy! Link to comment Share on other sites More sharing options...
tingtang Posted April 22, 2009 Share Posted April 22, 2009 ^ LOL!! i kno exactly what you mean!!! this is why i am behind on bills because ive been buyin crap for my car... Link to comment Share on other sites More sharing options...
tommypenguin Posted April 27, 2009 Share Posted April 27, 2009 Bump for update, how goes it Jae? Link to comment Share on other sites More sharing options...
executor485 Posted April 27, 2009 Share Posted April 27, 2009 He hasnt posted about it yet... maybe he's still out driving it and cant stop grinning If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
tingtang Posted April 27, 2009 Share Posted April 27, 2009 Link to comment Share on other sites More sharing options...
Legend Posted April 27, 2009 Share Posted April 27, 2009 Post Harvey's dyno sheet too... very curious about this turbo. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
grocery getter Posted April 27, 2009 Author Share Posted April 27, 2009 Sorry guys just got back from the Sand dunes and the Leggy is still at SUBA (the cosworth part didn't get to the shop till late Friday night). I plan on picking it up this week and getting it tuned on Friday....stay tuned! Link to comment Share on other sites More sharing options...
praedet Posted April 29, 2009 Share Posted April 29, 2009 Hey Jae, are you good enough friends w/ the guys at Suba performance that they might help one of your friends out at a reduced rate? Link to comment Share on other sites More sharing options...
tommypenguin Posted April 29, 2009 Share Posted April 29, 2009 What issues are you having currently Ted? Link to comment Share on other sites More sharing options...
praedet Posted April 29, 2009 Share Posted April 29, 2009 No issues, I need some Fab work done... Link to comment Share on other sites More sharing options...
tommypenguin Posted April 29, 2009 Share Posted April 29, 2009 No issues, I need some Fab work done... On a custom hood scoop? Did you get your boost problem sorted out or still running WG? Link to comment Share on other sites More sharing options...
grocery getter Posted April 29, 2009 Author Share Posted April 29, 2009 Sorry guys just got back from the Sand dunes and the Leggy is still at SUBA (the cosworth part didn't get to the shop till late Friday night). I plan on picking it up this week and getting it tuned on Friday....stay tuned! Here are some pics of them buttoning the Leggy up...looks clean like it came from the factory! Once again the guys at SUBA did an excellent job! Now for the tune and APS BOV change out on Friday (later next month for the intercooler sprayer and hood splitter mod) http://i271.photobucket.com/albums/jj134/JaeandNoelle/P4291758.jpg http://i271.photobucket.com/albums/jj134/JaeandNoelle/P4291759.jpg http://i271.photobucket.com/albums/jj134/JaeandNoelle/P4291760.jpg http://i271.photobucket.com/albums/jj134/JaeandNoelle/P4291761.jpg Link to comment Share on other sites More sharing options...
grocery getter Posted April 29, 2009 Author Share Posted April 29, 2009 Hey Jae, are you good enough friends w/ the guys at Suba performance that they might help one of your friends out at a reduced rate? I'm going back later today to pick up it up (with my wife) and I'll ask. They are looking into some custom hood splitter work for me as well. Link to comment Share on other sites More sharing options...
tommypenguin Posted April 29, 2009 Share Posted April 29, 2009 That looks great, TMIC is definitely a fatty. Link to comment Share on other sites More sharing options...
praedet Posted April 29, 2009 Share Posted April 29, 2009 Don't tell me you are running the SPT intake Link to comment Share on other sites More sharing options...
grocery getter Posted April 29, 2009 Author Share Posted April 29, 2009 Yup I got it cheap and all the tuners I spoke to mentioned that it was fine as long as you get it tuned with the heat shield Link to comment Share on other sites More sharing options...
