BobGee Posted December 22, 2009 Share Posted December 22, 2009 Its not the cost to register the wheels each season that bothers me it's the fact Subaru makes you leave the car for the entire day to do it. Why they don't use common sense to allow two sets of wheels irritates the hell out of me. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted December 22, 2009 Author Share Posted December 22, 2009 Its not the cost to register the wheels each season that bothers me it's the fact Subaru makes you leave the car for the entire day to do it. That's the dealer's fault. It takes less than five minutes to register the sensors plus any road test should they decide to do so. Link to comment Share on other sites More sharing options...
Throttlejockey Posted December 22, 2009 Share Posted December 22, 2009 I just use a black piece of electrical tape. But your way is the correct way. Link to comment Share on other sites More sharing options...
naimouasta Posted December 23, 2009 Share Posted December 23, 2009 good job. just curious though, those that use "black tape", would you pass vehicle inspections if the tpms light is on? Link to comment Share on other sites More sharing options...
Throttlejockey Posted December 23, 2009 Share Posted December 23, 2009 Vehicle inspection?? On an 08?? Link to comment Share on other sites More sharing options...
naimouasta Posted December 23, 2009 Share Posted December 23, 2009 yearly inspections right? in PA, there inspections for vehicle and emissions. Link to comment Share on other sites More sharing options...
Throttlejockey Posted December 23, 2009 Share Posted December 23, 2009 Oh, we only have emissions every 2 years. No inspections. Link to comment Share on other sites More sharing options...
spec.B Dream Posted December 29, 2009 Share Posted December 29, 2009 Just found this on iwsti. It is another inexpensive method to run multiple wheel sets without having to go to the dealer for tpms. http://www.iwsti.com/forums/gr-tires-wheels/181023-tpms-reset-tool.html I wish I would have known this a month ago. I would have ordered the sensors with my winter wheels from tirerack. Next time I replace the snow tires, I'll make sure to have sensors installed. Link to comment Share on other sites More sharing options...
lackskill Posted December 31, 2009 Share Posted December 31, 2009 There are tools available and/or are coming soon. Autel makes a reasonably priced kit, it seems and I don't think they're the only ones. http://www.auteltech.com/tpms901.htm http://www.auteltech.com/maxitire.htm The maxitire doesn't explicitly list Subaru as compatible, but the 501 says it will work for every vehicle released to date. It will be interesting to see how much it costs when it's available. Also, forgive my cross posting, but here's a guy that seems to have put most of the pieces together: http://www.iwsti.com/forums/gr-tires-wheels/181023-tpms-reset-tool.html I'm guessing the ideal solution will become affordable for the average joe in the near future. In the meantime, there's a way to make it work. Link to comment Share on other sites More sharing options...
lackskill Posted December 31, 2009 Share Posted December 31, 2009 Weird. Post 33 wasn't there a minute ago... Link to comment Share on other sites More sharing options...
ehsnils Posted November 18, 2011 Share Posted November 18, 2011 You can also do a TPMS pipe bomb as described here: http://www.clublexus.com/forums/is-second-generation/328044-diy-tpms-canister-pipe-bomb.html Link to comment Share on other sites More sharing options...
spec.B Dream Posted November 19, 2011 Share Posted November 19, 2011 Have you seen the pipe bomb work in a subaru? It is my understanding that our tpms only worked when the sensors were rotating in the wheel. Link to comment Share on other sites More sharing options...
lackskill Posted November 19, 2011 Share Posted November 19, 2011 Have you seen the pipe bomb work in a subaru? It is my understanding that our tpms only worked when the sensors were rotating in the wheel. On MY08, at least, that's correct. They come on at like 25mph or some such nonsense. Link to comment Share on other sites More sharing options...
berto2727 Posted December 2, 2011 Share Posted December 2, 2011 If we just unplug the TPMS harness without using TPMS on winter rims, would that turn off the indicator light? Link to comment Share on other sites More sharing options...
Mr. Sinister Posted December 2, 2011 Author Share Posted December 2, 2011 If we just unplug the TPMS harness without using TPMS on winter rims, would that turn off the indicator light? Nope. Link to comment Share on other sites More sharing options...
PeterJMC Posted December 2, 2011 Share Posted December 2, 2011 Sweet! Maybe i can do this also with my Prius. Link to comment Share on other sites More sharing options...
CapnJack Posted December 19, 2011 Share Posted December 19, 2011 Found out today that I can't take the TPMS module and tires from my 07 LGT and put them on my 08 3.0R. Light comes on. Must be ECU dependent? Booo..... Link to comment Share on other sites More sharing options...
Mr. Sinister Posted December 19, 2011 Author Share Posted December 19, 2011 Do the two models use different TPMS computer part numbers? How long did you drive to see if the light would go off? It can take a while sometimes. Link to comment Share on other sites More sharing options...
CapnJack Posted December 19, 2011 Share Posted December 19, 2011 (edited) I drove it close to 75 miles and light is still on. I just looked at both the modules. I believe you are correct on the part number. The one on the 07 is a 28201AG02A and the one on the 08 is a 28201AG06A. I can't believe they are that different... I guess I will find out. I have an appointment at the dealership to see if they can re-program it. Edited December 27, 2011 by CapnJack Corrected part numbers Link to comment Share on other sites More sharing options...
CapnJack Posted December 21, 2011 Share Posted December 21, 2011 Well, the dealership visit didn't go so well... As they were pulling the car on the lift, they punctured one of my tires. Crap... I have to give them props though. They are buying me four new tires and a new rim. The search begins for new snow tires since the Dunlop Wintersport M3s are sold out for the season. Link to comment Share on other sites More sharing options...
CapnJack Posted December 27, 2011 Share Posted December 27, 2011 (edited) UPDATE - Dealer ordered me new snow tires and a new rim. I had them installed tonight and found out the two TPMS modules are NOT compatible between an 08 and an 07. I walked though it with the Subaru Tech and the 07 module will accept the sensor numbers, but will NOT read tire pressure while installed in an 08 model. The 08 module WILL read and accept the sensors from the 07 though! So I'm now running 07 wheels, with 07 sensors, on an 08 Legacy 3.0R with the 08 TPMS module. Looks like I'll have to buy another module. Edited December 27, 2011 by CapnJack Link to comment Share on other sites More sharing options...
supergokougt Posted April 1, 2014 Share Posted April 1, 2014 I have a 2011 Legacy and need some help. I should have just used electrical tape for my winter tires !!! But at this point I have two sets wheels, tires, tpms and a keyless entry unit/tpms computer. I can not find where it goes under the seat and then I am worried about having to reprogram my keyless entry fobs to this new unit. Does anyone have the information on and pictures for this? Link to comment Share on other sites More sharing options...
jedraz Posted April 3, 2014 Share Posted April 3, 2014 http://legacygt.com/forums/showthread.php/location-tpms-control-uniti-62217.html?p=1174400 For an 09, not sure if this helps. Link to comment Share on other sites More sharing options...
ShadowImg Posted April 3, 2014 Share Posted April 3, 2014 I'm actually surprised this is still "alive" as a method. You can buy programmable TPMS sensors from Schrader and probably other brands now. You can just program both sets of TPMS to have the same IDs and not worry about all the other nonsense anymore. Link to comment Share on other sites More sharing options...
supergokougt Posted April 4, 2014 Share Posted April 4, 2014 I'm actually surprised this is still "alive" as a method. You can buy programmable TPMS sensors from Schrader and probably other brands now. You can just program both sets of TPMS to have the same IDs and not worry about all the other nonsense anymore. Thanks - thought I was saving money buying TPMS off this forum, little did I know the trouble it would cause. Link to comment Share on other sites More sharing options...
