outbacksam Posted March 9, 2009 Share Posted March 9, 2009 After coming back from dealer did not notice the shake it happens between 25 and 40 mph the steering wheel shakes a bit ,did they do something or ??? and is it a easy fix inspection due now regards Outbacksam Link to comment Share on other sites More sharing options...
lvethesnow Posted March 9, 2009 Share Posted March 9, 2009 im going with either your wheel arent balanced right our you warped you rotors. either way easy fixes History does not entrust the care of freedom to the weak or timid People sleep peacefully at night cause rough men stand ready to do violence on there behalf Link to comment Share on other sites More sharing options...
Gire Posted March 9, 2009 Share Posted March 9, 2009 Take it back to the dealer and tell them to look at your balancing. Did you get a tire rotation? Brake work? Link to comment Share on other sites More sharing options...
magnetic1 Posted March 9, 2009 Share Posted March 9, 2009 Or it could possibly be wheels not torqued down! That, or improperly balanced tires. It is industry standard to be within 0.25 for wheel balance. Some might even do it to within 0.50. My guess is one of the two things above. I doubt it has anything to do with the brakes since the dealer didnt service the brakes. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
fonts Posted March 9, 2009 Share Posted March 9, 2009 Shaking when you brake is typical of lugs not being torqued. Link to comment Share on other sites More sharing options...
outbacksam Posted March 10, 2009 Author Share Posted March 10, 2009 forgot to add it's in the header this only happens when braking wheel out of bal. would be all the time (at certain speeds) how can the rotors warp after tire replacement 1st day no brake overheat last comment seems to be what happened I will check and write back Link to comment Share on other sites More sharing options...
fonts Posted March 11, 2009 Share Posted March 11, 2009 You should always do a re-torque of your wheel lugs about 100 miles or so after the wheels are removed. Link to comment Share on other sites More sharing options...
