foolds Posted February 11, 2009 Share Posted February 11, 2009 Any one got a Tuning Cable I can borrow for a couple of days if mine does not show up by Friday? I need it to flash an open source tune and then pull some logs. Link to comment Share on other sites More sharing options...
foolds Posted February 12, 2009 Author Share Posted February 12, 2009 No one has a Tactrix Or Vag-com Cable I can borrow if mine does show up in time ? I will put down a $200 Cash deposit if a Tactrix Cable or $30 Dollar if Vac-Com Link to comment Share on other sites More sharing options...
tommypenguin Posted February 12, 2009 Share Posted February 12, 2009 I have one but I need it, I use it daily, if you could roll down to my neck of the woods I could flash the map for you and take a couple logs to see if its safe on your car. But I could not part with my cable, not even for a day. Link to comment Share on other sites More sharing options...
foolds Posted February 13, 2009 Author Share Posted February 13, 2009 I have one but I need it, I use it daily, if you could roll down to my neck of the woods I could flash the map for you and take a couple logs to see if its safe on your car. But I could not part with my cable, not even for a day. Thanks! I might do this if no one else is able to help out. Might be kinda nice to have some one show me how to flash the first time any how. Link to comment Share on other sites More sharing options...
tommypenguin Posted February 13, 2009 Share Posted February 13, 2009 Thanks! I might do this if no one else is able to help out. Might be kinda nice to have some one show me how to flash the first time any how. Let me know, flashing a map is easy, just make sure you have all the updated ecu definitions from the romraider forum and you shouldn’t have any issues. Link to comment Share on other sites More sharing options...
foolds Posted February 14, 2009 Author Share Posted February 14, 2009 Well, the Upgrades are on hold. The dealer had to order some parts to be replaced under the 3yr/36k Link to comment Share on other sites More sharing options...
808LGT Posted February 17, 2009 Share Posted February 17, 2009 Where can I buy one for myself? Vag-com or tactrix, and which is more user friendly? Link to comment Share on other sites More sharing options...
foolds Posted February 20, 2009 Author Share Posted February 20, 2009 I bought my Vag-com on ebay but it took some work to set it up. The Tactrix cable I hear is pretty much plug and play. For the savings the Vag-Com was the right fit for me as I am pretty computer savy. Car is back at the deal for the 5th time in a 10 days, and was just supposed to have a Engine mount replaced because it was leaking but they found that the car was loosing a lot of oil, and apparently have found oil in the intercooler. They are doing a leak down test, and getting in contact with Subaru. Some thing tells me they may be asking for maintenance records here soon. Car has 33,465 Miles on it and less then 3 weeks left on the bumper to bumper =(. I pulled some logs on it yesterday and found 2 misses on Cylinder 4, Two times, and 1 Miss on Cylinder 2. I also Logged the Knock Sum, What is an Acceptable number of knock on a stock tune? Link to comment Share on other sites More sharing options...
johnAWD Posted February 20, 2009 Share Posted February 20, 2009 Zero. And bummer about the issues. Link to comment Share on other sites More sharing options...
foolds Posted February 20, 2009 Author Share Posted February 20, 2009 Yep... Great, Turns out the Engine has a leak in cylinder#2 failed the leak down test. Link to comment Share on other sites More sharing options...
enthusiast Posted February 20, 2009 Share Posted February 20, 2009 I also Logged the Knock Sum, What is an Acceptable number of knock on a stock tune? You will have some knock during shifting gears. You just don't want to have any during a WOT run. Engine should be part of the 6/60 too. My mod list Link to comment Share on other sites More sharing options...
foolds Posted February 21, 2009 Author Share Posted February 21, 2009 It sounds like they are going to "rebuild" the motor to fix this problem. But were told by Subaru to do it the cheapest way possible. Does this mean they are going to just fix what ever the problem is and ignore the rest of the motor while they are in there? Also I got Subaru's Good-Will speech due to my K&N pannel airfilter and Borla Exhaust. Link to comment Share on other sites More sharing options...
nka Posted February 21, 2009 Share Posted February 21, 2009 yeah, it's well know that exaust are breaking cylinder... Link to comment Share on other sites More sharing options...
foolds Posted February 21, 2009 Author Share Posted February 21, 2009 Thats What I said. Things got quite heated when they said that to me. Link to comment Share on other sites More sharing options...
foolds Posted February 23, 2009 Author Share Posted February 23, 2009 Well the Pistons on Cylinder 2, 4 were cracked. Of course they claim the K&N could have caused this. BTW the car is at Go Subaru West. Link to comment Share on other sites More sharing options...
foolds Posted February 24, 2009 Author Share Posted February 24, 2009 I posted this over on the Turbo Powertrain since it became much more then borrowing a tuning cable to pull some logs. Link to comment Share on other sites More sharing options...
bsdzine Posted February 24, 2009 Share Posted February 24, 2009 isn't subaru notorious for having issues with cylinder #2 & #4? I'm running cobb maps now... but i need a v2 to get the new 1.18 map that fixes this common problem brian Link to comment Share on other sites More sharing options...
enthusiast Posted February 25, 2009 Share Posted February 25, 2009 Or just go open source.. My mod list Link to comment Share on other sites More sharing options...
