vanman281 Posted February 6, 2009 Share Posted February 6, 2009 I have a 99 legacy ej22, which is going through too much oil. I've found no signs of any leaking under the car, and it doesn't burn oil. I've added four quarts of oil since the last oil change which was about 1500 miles ago, any suggestions of where to check? Link to comment Share on other sites More sharing options...
Long Island Legacy Posted February 6, 2009 Share Posted February 6, 2009 I have a 99 legacy ej22, which is going through too much oil. I've found no signs of any leaking under the car, and it doesn't burn oil. I've added four quarts of oil since the last oil change which was about 1500 miles ago, any suggestions of where to check? well your are defff doing something with that oil I'm pretty sure if ya adding 4 quarts ya burning it. check your intake tracts Link to comment Share on other sites More sharing options...
vanman281 Posted February 6, 2009 Author Share Posted February 6, 2009 if i was buring oil due to the intake tracts would it show no signs of smoke in the exhaust? Link to comment Share on other sites More sharing options...
tbssubaru Posted February 6, 2009 Share Posted February 6, 2009 how long have you owned it and did this just start happening recently ? it's either leaking or burning it, nowhere else it can go, does your exhaust stink more than it used to ? or other cars ? Link to comment Share on other sites More sharing options...
vanman281 Posted February 6, 2009 Author Share Posted February 6, 2009 I've owned the car for about 5 months. It was loosing a little oil, but not like it is now. There is no smoke coming from the exhaust and there is no smell. Link to comment Share on other sites More sharing options...
jonklein611 Posted February 7, 2009 Share Posted February 7, 2009 Anything in the engine bay that's oily? Link to comment Share on other sites More sharing options...
vanman281 Posted February 7, 2009 Author Share Posted February 7, 2009 nothing, the engine bay is very clean. i'm going underneath the car tomarrow to check out everything again. Does anyone know how to check the intake tracts? Link to comment Share on other sites More sharing options...
jonklein611 Posted February 7, 2009 Share Posted February 7, 2009 It may not be burning at idle..... but could be burning at higher RPMs... Link to comment Share on other sites More sharing options...
NightmareH4 Posted February 7, 2009 Share Posted February 7, 2009 Heres what happens when you start your engine up in the cold and dont let it warm up. expecially when driving at higher rpms right after starting the engine. oil goes into the turbo to lubricate the bearings. how do i phrase this. the peices inside the turbo are not heated up enough to make a good seal. so oil from inside the bearings comes out into the exhaust side of the turbo and burns away. which can make alot of oil go away very fast. i found this out when i got first got my legacy in the winter and it did that. this winter im fine cause i always let it warm up before i drive it. Link to comment Share on other sites More sharing options...
vanman281 Posted February 7, 2009 Author Share Posted February 7, 2009 yeah, i know turbo'd cars burn more oil, but i have the ej22 non turbo. To jonklein, you may be right, i tend to keep it under or around 3k rpm but i have thought it may be burning it when i mash on it since it's so slow. lol Link to comment Share on other sites More sharing options...
987687 Posted February 7, 2009 Share Posted February 7, 2009 Have you checked your coolant? That is the other place it can go. Link to comment Share on other sites More sharing options...
vanman281 Posted February 7, 2009 Author Share Posted February 7, 2009 Just checked the coolant, pure green. If any oil is slipping past the rings would there be smoke coming out the exhaust? Link to comment Share on other sites More sharing options...
NightmareH4 Posted February 8, 2009 Share Posted February 8, 2009 oh sorry didnt know it was non turbo. I would guess if there was oil slipping past the rings there would be smoke and the oil burning smell. humm only thing i can think of is there has to be a leak or something. for you to loose that much oil and not notice smoke. interesting Link to comment Share on other sites More sharing options...
vanman281 Posted February 8, 2009 Author Share Posted February 8, 2009 yeah, i checked throughly underneath the car again yesterday, no signs of oil anywhere. i may just tak it into a shop and see if they can find anything/tell me what they think. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted February 9, 2009 Share Posted February 9, 2009 At least you don't have massive signs of oil. Looking under the front of my car it looks as though the whole thing was dipped in a giant vat of the stuff, lol. Link to comment Share on other sites More sharing options...
987687 Posted February 9, 2009 Share Posted February 9, 2009 I'm not sure which is worse... I think I'd rather know where it was going. Link to comment Share on other sites More sharing options...
vanman281 Posted February 9, 2009 Author Share Posted February 9, 2009 that can't be good lol. Where are you leaking from? Link to comment Share on other sites More sharing options...
Stang70Fastback Posted February 9, 2009 Share Posted February 9, 2009 that can't be good lol. Where are you leaking from? everywhere!!!!! Link to comment Share on other sites More sharing options...
vanman281 Posted May 18, 2009 Author Share Posted May 18, 2009 Does anybody if there are signs of oil burning from the piston rings? I am almost positive i am burning the oil while i am running in higher rpm's. The past couple of times i've driven on the freeway in around the 3500 rpm range is when i loose the most oil, even right after an oil change. Link to comment Share on other sites More sharing options...
b707guy Posted May 18, 2009 Share Posted May 18, 2009 How about the inside of the tail pipe? Is it black and sooty/greasy at all? Should be either clean or grayish. Another troubleshooting possibility - has anyone followed behind you on the highway to verify no smoke? Unlike "Uncle Buck's" car (John Candy movie...), you may not be able to see minor smoke on the highway if it dissipates quickly enough and you are basing the observation on looking in the mirror. Lastly, are you using oil of a proper viscosity, not too thin? Hope you find the problem! Link to comment Share on other sites More sharing options...
vanman281 Posted May 18, 2009 Author Share Posted May 18, 2009 well the muffler is black, not much soot, but had some water or condensation in there. I've had my dad drive behind me and he says there is no smoke coming out of the exhaust when it's warm. I have been using 10w 30 which is recommended for me car. I've used thicker and it still disappears. Link to comment Share on other sites More sharing options...
vanman281 Posted May 18, 2009 Author Share Posted May 18, 2009 I was wondering if anybody in the Seattle area has had a ring or valve test done at gregs japanese auto and what the cost was? Link to comment Share on other sites More sharing options...
cseagle08 Posted May 18, 2009 Share Posted May 18, 2009 It could just be normal for your car, depending on the tolerances of the cylinders and such. I have a '78 camaro and an '02 camaro and both of them will use some oil when you drive above 80 mph for long runs. When I say 'use' I mean it'll lose about a 1/4 of a quart in 700 miles (like driving from FL to TN at 80+). Link to comment Share on other sites More sharing options...
vanman281 Posted May 18, 2009 Author Share Posted May 18, 2009 yeah, i understand that boxxer engines are known to burn a little oil, but i am loosing around or more than 3/4 a quart in 250 or 300 miles. Link to comment Share on other sites More sharing options...
HeathyVT Posted June 3, 2009 Share Posted June 3, 2009 Have you tried replacing the pvc valve? I know on my toyota tercel I had awhile back, that sucker would be wide open and get sucked in the intake. Link to comment Share on other sites More sharing options...
