Platinum_Racing Posted June 4, 2009 Share Posted June 4, 2009 Check the oil drain plug. Mine drips oil occasionally and it's very tight. I've gotta replace it and the washer soon I think. Link to comment Share on other sites More sharing options...
vanman281 Posted June 4, 2009 Author Share Posted June 4, 2009 hm, i was reading up an another ej22 leak at high rpm's. people are suggesting camshaft crankshaft, and piston rings burning the oil. The PCV valve was also mentioned, ill have to check that out. There is minnimal oil getting sucked into the intake, i've heard that happens to most unless they have a catchcan. The bottom of the engine is very clean, i got my oil changed at a dealer and they forgot to tighten the oil filter which made it a little oily undernneath. Otherwise there is no oil from the filter or the drain plug, thanks for the idea tho. Link to comment Share on other sites More sharing options...
