LegacyLexTek Posted February 3, 2009 Share Posted February 3, 2009 wondering if anyone can help me with this issue. i have the cusco front and rear sway bars on my lgt. the bushings are shot. the bars are 23 f and 21 rear. does anyone have any idea where i can get new bushings besides cusco because i really dont feel like paying 25 bucks a bushing. has anyone tried using energy suspensions universals. thanks Link to comment Share on other sites More sharing options...
LGT Dave Posted February 3, 2009 Share Posted February 3, 2009 I have Cusco F&R bars on my car and I installed the Energy Suspension bushings that have a grease fitting so they can be greased up easily with a grease gun. The Cusco bushings are rubber and don't last very long so I wouldn't suggest trying to get more. The brackets that came with the Engergy Suspension bushings for the front needed a fair amount of trimming because they are a lot bigger than the stock brackets, but the bushings themselves are so much better than the Cusco ones. I started getting some bad clunking and squeeking from the bushings that my bars came with, but I don't have those problems now with the new bushings and they should last a lot longer since they're urethane. Here's a good thread so you get an idea of what needs to be done to the brackets to get them to fit: http://www.legacygt.com/forums/showthread.php?t=97981 Link to comment Share on other sites More sharing options...
Th3Franz Posted February 3, 2009 Share Posted February 3, 2009 Yep check the bushing thread in this sub-forum. Whiteline's bushings should be compatible, also. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
LegacyLexTek Posted February 13, 2009 Author Share Posted February 13, 2009 yo just found today that AVO turboworld has bushings for stock bushing mounts, they are poly, orange, and a range of sizes. 25 bucks a pair, ordered them today Link to comment Share on other sites More sharing options...
BigBad Posted February 13, 2009 Share Posted February 13, 2009 I have been using the energy suspension poly bushings on mine and they work very well. I have the greasable ones in the front and modified the rear ones so they are greasable too. Link to comment Share on other sites More sharing options...
caramall2 Posted February 19, 2009 Share Posted February 19, 2009 Would definitely suggest the energy bushings if you don't mind having to trim the brackets some to make them fit. The thing I love about them is the grease fitting and groves for grease--takes 2 seconds with a grease gun to lube them up great. Link to comment Share on other sites More sharing options...
bobo69 Posted February 20, 2009 Share Posted February 20, 2009 Would definitely suggest the energy bushings if you don't mind having to trim the brackets some to make them fit. The thing I love about them is the grease fitting and groves for grease--takes 2 seconds with a grease gun to lube them up great. you only trimmed the passenger's side right? Link to comment Share on other sites More sharing options...
LGT Dave Posted February 20, 2009 Share Posted February 20, 2009 you only trimmed the passenger's side right? I had to trim the brackets for both the passenger and driver's side to get them to fit. Link to comment Share on other sites More sharing options...
caramall2 Posted February 20, 2009 Share Posted February 20, 2009 It's been a while so I can't quite remember...but I think you're right. May have had to trim driver side a little bit. Link to comment Share on other sites More sharing options...
BigBad Posted February 20, 2009 Share Posted February 20, 2009 I only had to trim the passenger side bracket. The drivers side did not require any modification. Link to comment Share on other sites More sharing options...
LGT Dave Posted February 20, 2009 Share Posted February 20, 2009 That's weird. Both sides were symmetrical underneath my car so I had to trim the same amount caramall2 had to in his thread off of both brackets Link to comment Share on other sites More sharing options...
bobo69 Posted February 20, 2009 Share Posted February 20, 2009 im with big bad on this one i only had to trim the passenger side Link to comment Share on other sites More sharing options...
hassa Posted February 21, 2009 Share Posted February 21, 2009 I've had the Energy Suspension ones for well over a year now and they are holding up great.....for Cusco buyers that have paired them with the AVO RSB Reinforment Brackets, make sure you get longer bolts to replace the OEM ones!!! Link to comment Share on other sites More sharing options...
