taskforcefreddy Posted November 15, 2008 Share Posted November 15, 2008 In case you thought you've seen it all, this was copied/pasted from a Ford Powerstroke forum. Well, I have been working on changing my oil and installing a FS 2500 for about 6 hrs now. I am also changing over to Amsoil at the same time. In order to get the most of the oil out, I drained the as much oil out of the pan as would drain. Then I put in about 2 quarts of clean Rotella T 15w40 which is what I was using before, aswell as a quart of tranny fluid (to help clean up any sludge etc). Then I started it and let it idle for about 30 seconds to a minute. It ran ruff and the oil pressure light went on. As I reached to turn it off, it died. I didnt think anything of it as I figured once I refilled it would prime right back up. But after installing a new filter, the bypass, and filling with oil, and cranking it for 15 seconds, 3 times. It hasnt started. What do I do next? I am already late for dinner with my family.... On top of the fact the the PSD (powerstroke diesel) takes nearly 4 gallons of oil, the sophisticated fuel injection system uses a high pressure oil pump in order to actuate the massive injectors. So not only did he run his engine dry on oil but he ruined his fuel injection system as well. He was able to finally get it started after filling it up with oil and cranking if for 30 seconds but he's pretty much destroyed his $7,000 engine. Link to comment Share on other sites More sharing options...
PhilT Posted November 15, 2008 Share Posted November 15, 2008 You shouldn't laugh at other people's misfortunes, but........ :lol: Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
mattg Posted November 15, 2008 Share Posted November 15, 2008 this thread is pretty worthless without the link Link to comment Share on other sites More sharing options...
taskforcefreddy Posted November 15, 2008 Author Share Posted November 15, 2008 this thread is pretty worthless without the link LOL... what? Like I have nothing better to do than to sit around and make up a story like this? OK...gimmie a sec and I'll post the link so you can verify it's authenticity. Link to comment Share on other sites More sharing options...
mattg Posted November 15, 2008 Share Posted November 15, 2008 not trying to verify authenticity want to see the flaming and aftermath, duh. Link to comment Share on other sites More sharing options...
taskforcefreddy Posted November 15, 2008 Author Share Posted November 15, 2008 lol... sorry boss :-). I'm reading you now. It actually wasn't as bad as you might think... here ya' go: http://www.powerstroke.org/forum/engine-911/69795-changed-oil-now-wont-start-i-need-leave-now.html Link to comment Share on other sites More sharing options...
mattg Posted November 15, 2008 Share Posted November 15, 2008 thx Link to comment Share on other sites More sharing options...
Strabismo Posted November 16, 2008 Share Posted November 16, 2008 wtf is this guy for real? Link to comment Share on other sites More sharing options...
taskforcefreddy Posted November 17, 2008 Author Share Posted November 17, 2008 LOL... It's not just him. Today someone asked for some opinions on trading his 2006 Covette for a 2008 F350 Crew Cab. A lot of people chimed in with opinions and the OP mentioned that he's really gonna miss the power of the vette. That's when some other guy chimed in and said (and I quote), "Put Spartan tunes and DPF delete on that truck and you'll think that 'Vette was pokey." So you're saying that you're 8,000 pound, slightly modded pick up truck will beat a 12 second stock corvette? Link to comment Share on other sites More sharing options...
dammitjim Posted November 17, 2008 Share Posted November 17, 2008 Post 11 FTW Link to comment Share on other sites More sharing options...
JohnnyGT08 Posted November 17, 2008 Share Posted November 17, 2008 And HE was threatening to stop "helping" others. I bet they're all thankful he blew his own truck up first, before offering advice on how to do the same to theirs... NEVER ARGUE WITH A STUPID PERSON. THEY WILL DRAG YOU DOWN TO THEIR LEVEL, THEN BEAT YOU WITH EXPERIENCE. [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
jonklein611 Posted November 17, 2008 Share Posted November 17, 2008 No man this really works, I'm telling you. It's the way to fight our oil dependency! No oil means less bucks going overseas. Now why doesn't it turn over? LOL Someone should get his starter motor wired backwards (fun thing about diesels, you can run most of em in reverse, then they are a bioch to shut off....) Link to comment Share on other sites More sharing options...
ehsnils Posted November 17, 2008 Share Posted November 17, 2008 And when you run a diesel in reverse you will have the oil pump doing the same thing and the engine will be ruined due to lack of lubrication. The only engines that can stand running in reverse (in general) are 2-stroke engines unless they have a oil mixture pump that depends on the rotation. Link to comment Share on other sites More sharing options...
jonklein611 Posted November 17, 2008 Share Posted November 17, 2008 And they don't shut off very easily because there's no throttle... Link to comment Share on other sites More sharing options...
ehsnils Posted November 17, 2008 Share Posted November 17, 2008 A diesel is regulated by controlling the amount of fuel injected so you just cut the fuel instead. But the injection pump may be designed to only rotate in one direction and therefore the regulator will be "confused" when it goes backward and increase fuel instead of decrease it when trying to regulate the rpm. And if you have a turbodiesel and the turbo dies so the engine oil goes into the engine you will have a runaway engine that can't be stopped. Rather dangerous. Link to comment Share on other sites More sharing options...
jonklein611 Posted November 17, 2008 Share Posted November 17, 2008 only way is to plug the exhaust, and pray..... Link to comment Share on other sites More sharing options...
urs1ne Posted November 17, 2008 Share Posted November 17, 2008 Haha, but this is still my fav ^ n00bs below this line Link to comment Share on other sites More sharing options...
ehsnils Posted November 17, 2008 Share Posted November 17, 2008 :lol: Link to comment Share on other sites More sharing options...
jonklein611 Posted November 17, 2008 Share Posted November 17, 2008 think they proved it was fake, but still funny none the less..... Link to comment Share on other sites More sharing options...
bradlgt21 Posted November 17, 2008 Share Posted November 17, 2008 OMG that better be a fake that was so stupid. Link to comment Share on other sites More sharing options...
taskforcefreddy Posted November 18, 2008 Author Share Posted November 18, 2008 ^^ Yeah. That was eventually proven to be false...still funny NTL. Link to comment Share on other sites More sharing options...
JohnnyGT08 Posted November 18, 2008 Share Posted November 18, 2008 Haha, but this is still my fav Oldie but a Goodie! NEVER ARGUE WITH A STUPID PERSON. THEY WILL DRAG YOU DOWN TO THEIR LEVEL, THEN BEAT YOU WITH EXPERIENCE. [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
jmorris6689 Posted November 19, 2008 Share Posted November 19, 2008 whata dumbass. I almost feel bad for the poor sap, geeze i get people like this at work all the time but this one is pretty good. Link to comment Share on other sites More sharing options...
dammitjim Posted November 19, 2008 Share Posted November 19, 2008 i get people like this at work all the time got any good stories? Link to comment Share on other sites More sharing options...
Penguin Posted November 19, 2008 Share Posted November 19, 2008 I think the dumbass in that thread had a 6.0L Powerstroke right? If so his fuel injection rail is powered hydraulically by engine oil. If there is no oil, there is no fuel pressurization, and there is no more running. Link to comment Share on other sites More sharing options...
