Which springs fit 05+ GT wagons with stock struts?
JohnSoPA
Posted
I would like to slightly lower my 05 GT wagon while maintaining a close-to-stock ride. It looks like Pinks, Cobb, Ion, Eibach and Progress springs would be good candidates but I can't find any info on springs for the GT wagons.
Anyone know which company makes springs for the GT wagon?
Posted
you won't have the saggy bum issue if you use the stock shocks because the front gets lowered more with the stock front struts. the pinks for example will drop the front a over 1" on stock GT struts, the swifts even more.
but as others have pointed out, lowering on the sock shocks does not work well. the stock shocks are weak, taking away travel only makes them less effective.
Posted
OK, what I am planning to do now is use the STi Pinks on the stock struts, then get Bilstein HDs when the stock struts are done.
Make sense to you guys?
Posted
Swifts are a pretty large drop. You say you're looking for a slight drop. The slightest drop are STi Pinks. If you're not in a rush you could wait until these come out should be the slightest drop available...
http://legacygt.com/forums/showthread.php?t=96917
Cheers!
Cobb are one of the slightest drops I've seen. Pinks drop an inch or more on stock struts. The 15mm drop you are seeing listed is for Bilsteins...which too seems a bit off. Swifts will be too aggressive for stock struts.
Do yourself a favor and save an extra $500 and also pick up some Bilstein HD's or even Koni or Tokico's. The springs alone may satisfy you for a short time, but you'll soon learn you need a better strut.
Posted
Send a PM to Jstaggs. He's running pinks on stock struts. See what he thinks.
Posted
Again, save your time and money. Whatever you will put on stock crap suspension you will be disappointed.
Posted
unclemat:
To a degree I have to disagree. The addition of springs will eliminate a lot of the dip and diving feel of the stock suspension. So at first he may be happy. But yes, he will soon learn that better struts are needed. If you can live with the cons the pros are pretty good. (ions/stock struts for 18months)
Posted
Thanks for the input guys. I used to race SCCA Spec Racers and club race Porsches with full coilover setups, so I know that I am compromising with this proposed setup. I had a set of Bilstein PSS9's on my old 993 street car and they were great.
This LGT wagon is just my daily driver with mostly highway driving -- I am not planning to have any track time with it. In fact, I drive a lot more sedately on the street compared to before I started racing. Wierd, I guess.
Given that I have 50k on the car, it might make sense to get the Bilstein HDs and Pink springs sooner rather than later. I'd bet the stock struts are soon shot anyway.
Posted
Good choice. For the record I run Bilstein PSS coilovers on my LGT wagon. Way more comfortable than Bilsteins+Pinks, actually more comfortable than stock suspension - and handling cannot be compared.
Posted
JohnSoPA?
Whoa whoa whoa. Change that screenname buddy.
Joe
:lol: :lol: :lol:
Why? We've now got a Joe and a John from PA! I've been getting you two confused for the last couple of months! :lol:;)
Han's is right about the larger drop in front with Pinks on stock struts. I think that is desirable as the wheel gaps will then look even. I'm planning on getting some Pinks and the Koni inserts to take advantage. Unless the Racecomp "Regular guy" springs come out in time.
Cheers!
Posted
JoeFromPA, are you JOE the plumber? LOL!
So many choices. I just talked with Ion and might be going their route now.
Posted
I had them on my LGT sedan (Ion Sport Spec). Even if they are not perfect for the struts I enjoyed the reduction in dipping and diving over the stock suspension. You will find the stock struts are a bit out of their league. With Ion, if you get them they have different front springs for stock KYB struts vs. Bilsteins. So if you upgrade to Bilstein HD's you'll need new front springs. Also, they have "spec b" specific springs and another kind called HD which I believe some people prefer on the wagon as it jacks up the rear a tad to prevent the sag look due to the rear quarter panel of the wagon. Do plenty of research first.
Posted
JohnSoPA,
I have iON sport spec fronts and HD rears on my '05 LGT Ltd 5EAT wagon, so I thought I'd chime in. They're on Koni inserts in stock strut housings (front) and Koni rears. I used the USDM ('thin') tophats. It produced a moderate drop with a slight rake that I really like.
I found that with the adjustability of the Koni's, the car has great daily-driving manners with good damping (3/4 turn from full soft in the front, 1 turn from full soft in the rear). The ride can be made much more aggressive by stiffening the dampers.
Tires 'before' (225/45R17)are different than 'after' (245/40R17), so not exactly apples to apples; wheels are 17x8, +50 offset.
Before:
http://img.photobucket.com/albums/v230/MauiJim/026-1.jpg
After:
http://img.photobucket.com/albums/v230/MauiJim/DSC07290.jpg
http://img.photobucket.com/albums/v230/MauiJim/DSC07292.jpg
Posted
mauij-
What kinda wheels you running?
They're the Japanparts STi wheel by Enkei (I posted in the older Forester Sports wheel thread :D)
Posted
MauiJim
Your set spring/strut combo is one that I'm considering for my wagon. Do you know what the drop is over the stock configuration? Also how does this set-up work over really bumpy roads and patchwork roads. We have a lot of both here.
Posted
Swifts are the best drop / ride for wagons.
Swifts are nice, but low!
I run ions and they have been great for almost 3 years now. Subtle 1" drop, and high quality.
