snow05gtRI Posted October 24, 2008 Share Posted October 24, 2008 Specifically in the rear driver's side (or at least sounds like that side). I notice it mostly when I go over a bump on one of the streets I take regularly from work to home. When I get to the end of the street where it meets the cross street, the cross street is kind of raised up from the one i'm leaving. I make a right turn onto the street, my front end goes up and then when the rear end goes up it makes a crunch sound. The change in elevation isnt extremely abrupt, not like a sharp meet of raised road to low road, imagine a speed bump but at the top it staying level... any thoughts? Link to comment Share on other sites More sharing options...
BigBad Posted October 24, 2008 Share Posted October 24, 2008 What are you running now in terms of suspension mods? Had the same problem back when I first installed my rear Cusco sway bars with rubber bushings. When I went to poly bushings and greased them every oil change, no more crunch sound. Link to comment Share on other sites More sharing options...
snow05gtRI Posted October 24, 2008 Author Share Posted October 24, 2008 stock suspension. only mods are Borla Cat Back, AEM CAI, and APv2 Stage 1 tuned by TA Link to comment Share on other sites More sharing options...
BigBad Posted October 24, 2008 Share Posted October 24, 2008 Then I bet you its the stock rubber bushings on the rear sway. I would replace them if their worn and at a minimum take them off, grease em and reassemble. Should take care of the crunch. Link to comment Share on other sites More sharing options...
snow05gtRI Posted October 24, 2008 Author Share Posted October 24, 2008 i'm guessing its not...but is that covered in the 5yr/60k powertrain? Link to comment Share on other sites More sharing options...
BigBad Posted October 24, 2008 Share Posted October 24, 2008 Don't know if its covered in the 5yr/60k. Would need to look that one up.. Link to comment Share on other sites More sharing options...
snow05gtRI Posted October 27, 2008 Author Share Posted October 27, 2008 k, thanks for the help! Link to comment Share on other sites More sharing options...
