fattymcgee Posted October 21, 2011 Share Posted October 21, 2011 Thanks for the write-up, nvery helpful. I just got done putting in new spark plugs and the up pipe and I'm trying to put on a used Cobb downpipe. I haven't heard of anyone else with this problem but the donut gasket from the mid-pipe to the catback is in two pieces. Half of it is seized on the OEM midpipe and half is seized on the CBE. Gonna have to figure out a way to get it out of the CBE so I can put the new one in. Any suggestions? (This is at my home so I'm using ramps and I don't have a boatload of tools) Was thinking about using a dremel tool. Link to comment Share on other sites More sharing options...
DDMan Posted November 1, 2011 Share Posted November 1, 2011 Agree, a great write up. I just pulled my DP to get a O2 sensor bung welded in and to get it ceramic coated. I had 4 bolts left holding the heatshield on and I got to all of them without having to pull the intercooler off. I got 3 of the top turbo/DP bolts done from the top with a breaker bar, but the bottom ones wouldn't budge. The way I got it to work was put PB Blaster on them, let em soak, then I used a 14mm socket and flex joint attached to about a 2' long extension. Then put my breaker bar on the end of that. That loosened everything up pretty quick. I got everything off in about an hour, which I thought was pretty good for never doing it before. Link to comment Share on other sites More sharing options...
ktm200 Posted May 28, 2012 Share Posted May 28, 2012 Nice write up. Helped with my install. Thanks. Link to comment Share on other sites More sharing options...
Snowferno Posted September 13, 2012 Share Posted September 13, 2012 Subscribed for Upcoming install Link to comment Share on other sites More sharing options...
Snowferno Posted September 13, 2012 Share Posted September 13, 2012 Edit- double post Link to comment Share on other sites More sharing options...
Max Capacity Posted September 13, 2012 Share Posted September 13, 2012 Don't forget to use anti-seize compound on all the nut's and bolts. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
EconCoder Posted November 3, 2012 Share Posted November 3, 2012 If I remove the IC to make the swap easier, will I need to get new gaskets for the IC? If I do, what are they? Link to comment Share on other sites More sharing options...
Screechers Posted November 9, 2012 Share Posted November 9, 2012 nice writeup Link to comment Share on other sites More sharing options...
nhltfour Posted January 4, 2013 Share Posted January 4, 2013 very helpful. remember to wrap it up Link to comment Share on other sites More sharing options...
amp583 Posted June 30, 2014 Share Posted June 30, 2014 Throwing on my Cobb this weekend, a few questions... - Do you re-use all gaskets or ideally purchase both a) Turbo>DP & b) Donut Gasket? - Any difference between grimspeed gaskets and OEM? Are there better gaskets? - If new gaskets are bought does it matter if permatex copper is used or just added benefit? Link to comment Share on other sites More sharing options...
golunnova Posted June 30, 2014 Share Posted June 30, 2014 I used a new OEM donut gasket and a grimmspeed turbo to dp gasket. New gaskets help save you some grief. Totally worth it. Didn't use any permatex copper with the gaskets. No leaks for a year so far. Link to comment Share on other sites More sharing options...
Hartley747 Posted January 23, 2015 Share Posted January 23, 2015 Thanks to everyone for the info provided on this thread. I installed a downpipe on my 2008 today to finally go to stage II. I used rhino ramps and managed the install without removing the TMIC. I sprayed everything with PB the night before and had no problems with anything except the hanger bolt which snapped and needed to be drilled out (should have given that some more PB). I also used a grimm speed 3" to 2.5 adapter for the stock catback so I could use a new doughnut gasket. It was a challenge to compress the springs enough to get the nuts threaded but there are no leaks so far. It sound completely stock at idle but you can hear the turbo whistle under throttle. Link to comment Share on other sites More sharing options...
amm203 Posted October 11, 2015 Share Posted October 11, 2015 Used this guide to change my Downpipe yesterday. Thank you for the awesome write-up. I managed to do it without removing the IC. Even with 72k miles the bolts to the turbo came off after 30 minutes with PB blaster. The most annoying part was the bolts at the middle of the downpipe holding the heat shield - they were rusted out. Just spun it until it broke. Trimming the top heat shield to fit was a breeze. This is a surprisingly easy job to do on rhino ramps. Now she just sounds mean with the turbo-back. Link to comment Share on other sites More sharing options...
goldramgb Posted October 13, 2015 Share Posted October 13, 2015 Thanks I'm going to be using this in the future! Link to comment Share on other sites More sharing options...
