Beanboy Posted February 5, 2005 Share Posted February 5, 2005 Asked a while ago, just curious if anybody found out... All of the specs I've seen, I don't see a difference in springs/roll bars/struts between the GT and the 2.5i. Are they the same? -B -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
SC GT Posted February 5, 2005 Share Posted February 5, 2005 I don't know the what the differences are, but per the parts manual: Front: Struts are different Springs are the same Sway bars are different Rear Struts are different Springs are the same Sway bars are the same Check the circumfrence of your front sway bar so we can figure out the difference between the i and GT swaybars. The GT's is 66 mm which = 21 mm diameter. Link to comment Share on other sites More sharing options...
Beanboy Posted February 5, 2005 Author Share Posted February 5, 2005 Interesting... More than I knew so far. Thanks! -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
rm -rf Posted February 8, 2005 Share Posted February 8, 2005 Is there an easy way to get at the front sway bar w/o jacking up the car? I tried to measure it by reaching under the car but couldn't. --Mike Link to comment Share on other sites More sharing options...
rc0032 Posted February 8, 2005 Share Posted February 8, 2005 Is there an easy way to get at the front sway bar w/o jacking up the car? I tried to measure it by reaching under the car but couldn't. --Mike The front bar is under the plastic cover. You will have to take this off to get to the bar. My guess is no you can’t measure it without getting under the car. Link to comment Share on other sites More sharing options...
Edvig Posted February 8, 2005 Share Posted February 8, 2005 The front bar is under the plastic cover. You will have to take this off to get to the bar. My guess is no you can’t measure it without getting under the car. Sadly, the 2.5i doesn't come with a plastic skid plate. Link to comment Share on other sites More sharing options...
rc0032 Posted February 8, 2005 Share Posted February 8, 2005 Sadly, the 2.5i doesn't come with a plastic skid plate. Then its easy Link to comment Share on other sites More sharing options...
PGT Posted February 8, 2005 Share Posted February 8, 2005 turn your wheels all the way to one side. You should be able to get to the front bar from the wheel well....at least enough to measure Link to comment Share on other sites More sharing options...
