black318i Posted September 17, 2008 Share Posted September 17, 2008 Sorry in advance for the noob questions. I just got all my parts in and I'm wondering should I start with mickeyd's stage one and tweak it or start from scratch? My parts list is below. Should I post logs and go from there or what? Also I will be using 91 octane. I will be using Romraider with an LC1. I also have an EGT and boost gauge. AVO catted DP OEM catless UP Perrin Crank Pulley GFB 50\50 BOV (full recirculate) Link to comment Share on other sites More sharing options...
Infamous1 Posted September 18, 2008 Share Posted September 18, 2008 Start with Mickeyd's if you are unfamiliar with setting up base maps. Link to comment Share on other sites More sharing options...
black318i Posted September 18, 2008 Author Share Posted September 18, 2008 Thanks, hopefully I will be able to do the exhaust this weekend and post some logs. Link to comment Share on other sites More sharing options...
black318i Posted November 7, 2008 Author Share Posted November 7, 2008 I know it took me forever, but everything is installed now. Now that the Stage II tune is posted should I start with that? If so I'd just leave the MAF scaling alone for now since I'm using the stock intake now right? Link to comment Share on other sites More sharing options...
rao Posted November 7, 2008 Share Posted November 7, 2008 You do not need to touch the MAF scaling, especially without a wideband. There is not need o mess with it and no benefit. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
black318i Posted November 7, 2008 Author Share Posted November 7, 2008 Ok cool. So should I start with the stage II map then? Link to comment Share on other sites More sharing options...
rao Posted November 7, 2008 Share Posted November 7, 2008 That's what I would do. Unless you have some strange combination, there is not anything else that should be done. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
black318i Posted November 8, 2008 Author Share Posted November 8, 2008 Great thanks, Hopefully I can post some logs this weekend. Link to comment Share on other sites More sharing options...
