MOMSWGN Posted September 12, 2008 Share Posted September 12, 2008 Got a 2005 LGT. Do I have a speedometer sensor in the tranny or is it done through the ABS system? Thanks. Link to comment Share on other sites More sharing options...
rao Posted September 12, 2008 Share Posted September 12, 2008 Through the ABS system. The ABS control unit takes the 4 wheel speed sensor's signals and outputs what must be an average of the 4 through the CAN bus to the speedometer and the ECU. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
MOMSWGN Posted September 12, 2008 Author Share Posted September 12, 2008 Thanks. Your the best, even though you are a sarcastic SOB Link to comment Share on other sites More sharing options...
rao Posted September 12, 2008 Share Posted September 12, 2008 What can I say? ABS is a topic that lends itself to sarcasm Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Mr. Ed Posted September 13, 2008 Share Posted September 13, 2008 there is one in the transmission isn't there? ...I had to replace mine Link to comment Share on other sites More sharing options...
MOMSWGN Posted September 13, 2008 Author Share Posted September 13, 2008 I can't remember when the Legacys when from in the tranny to ABS. Yours should be ABS, Ed. Link to comment Share on other sites More sharing options...
