cfdrumr Posted August 13, 2008 Share Posted August 13, 2008 I am getting new tires tmrw for my new wheels. Should I get the Federal SS-595 or the General UHP http://www.tirerack.com/images/tires/general/ge_exclaim_uhp_ci2_l.jpg??? Link to comment Share on other sites More sharing options...
cfdrumr Posted August 13, 2008 Author Share Posted August 13, 2008 really? no one has an opinion? Link to comment Share on other sites More sharing options...
DiscoWagon Posted August 13, 2008 Share Posted August 13, 2008 Neither? Link to comment Share on other sites More sharing options...
krzyss Posted August 13, 2008 Share Posted August 13, 2008 Why only these 2? Neither is my answer. What do you want from tires? Krzys Link to comment Share on other sites More sharing options...
Scotty Posted August 13, 2008 Share Posted August 13, 2008 Wow those tires cost less than my bicycle tires. Neither would be my answer too. Link to comment Share on other sites More sharing options...
VTGT Posted August 13, 2008 Share Posted August 13, 2008 neither..... you live in LA get some summer tires i.e. Falken Azenis or the like... Link to comment Share on other sites More sharing options...
ICECOLD Posted August 13, 2008 Share Posted August 13, 2008 i would pick the Federal SS-595 because if you look up the tires on the web, alot of people talk about how good they are.. and if you see drifting cars most of them use it.. because its a good tire that dont cost too much $$$ ..i hope that this helps you..here is the link . http://forums.nasioc.com/forums/archive/index.php/t-132094.html. Link to comment Share on other sites More sharing options...
Spoonwacker Posted August 13, 2008 Share Posted August 13, 2008 I've had the UHPs for about a month now and I'm happy with them so far. Another local member, uberwagon, had them for a while, but switched to something else - I think they wore very quickly. I got the UHPs because I needed 18" tires on a budget because I went slightly overbudget on my rims. They also have a nice big tread pattern that looks like it will work well in the wet up here. I didn't look at the SS-595. sorry...this forum practically blows goat nuts so im not always on here.Team Pony Express POSTED FROM MY COMPUTER USING A WEB BROWSER Link to comment Share on other sites More sharing options...
rao Posted August 13, 2008 Share Posted August 13, 2008 I like my UHP's on another car. I never understood the idea of using a drift car for tire marketing Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
mwiener2 Posted August 13, 2008 Share Posted August 13, 2008 I vote niether My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
cfdrumr Posted August 14, 2008 Author Share Posted August 14, 2008 I ended up getting the Federals for $85 mounted a corner...they grip MUCH better than the Toyo Proxes 4 I had on before... Link to comment Share on other sites More sharing options...
canddmeyer Posted August 14, 2008 Share Posted August 14, 2008 Neither Link to comment Share on other sites More sharing options...
OhBe1 Posted August 14, 2008 Share Posted August 14, 2008 There are two versions of the 595. One is for drift, which I assume has the "advantage" of losing traction easily. The other version was on my current Miata when I bought it, and they were surprisingly good - sticky, responsive, and decent in the wet. I ditched them because I hated the 17" on a first-gen Miata. They went on my kid's Civic. I currently have UHP's on that car, and they are taking forever to scrub off the release compound. Nice & responsive, but the dry grip is not there, at least yet. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
Spoonwacker Posted August 14, 2008 Share Posted August 14, 2008 I ended up getting the Federals for $85 mounted a corner...they grip MUCH better than the Toyo Proxes 4 I had on before... Cool. I came from Proxes 4, too, but I killed those at the track OhBe1 - I'm noticing the same thing with my UHPs. I took them on a, er, spirited drive a few weeks ago and that helped, but they still squeal a bit when I go over painted speed bumps... sorry...this forum practically blows goat nuts so im not always on here.Team Pony Express POSTED FROM MY COMPUTER USING A WEB BROWSER Link to comment Share on other sites More sharing options...
