al-gorithm Posted August 6, 2008 Share Posted August 6, 2008 Well, I finally did it. I did some searching on NASIOC, bought some parts and slapped it all in. One thing I do have to say is that this doesn't go in as easy as they do in the STi from what I've read. Issues: The bases/brackets from Speedware for the WRX and STi don't fit the rear left and rear right bolt locations. Only the front two match. I had to make roughed in metal adapters which I will weld in place when I take the seats out again. *more on this below re:#3.The seat is aligned 1-2 inches to the left. This makes the recline hard to get to unless you slide the seat up forward. The shoulder bolster against the B-Pillar also rubs a little. Dropping your phone beside the centre console has become that much easier.I couldn't get the heater elements out of the stock seats, well really the back one I couldn't. I can pull the covers back on the Recaros so I will buy some heater elements and put them on. Things I found out: The wiring below the seat. The side airbag is tricked by a 3.3ohm resistor. There are two plugs for the seat belt sensor. One sensor for the seat position which was transferable to the Recaro because of the base/bracket installed. One connection for the heated seats.A one inch square tubing spacer between the rails and the base offer close to similar height as the Recaros sit lower (lower have is not as tall as the stock seat)After sitting in the stock legacy seat again, I don't know if I'll ever be able to go back. It feels like I am sitting on a bench compared to the Recaro. All in all, it can be done. I've only done the driver's side but will do the passenger's side this week. It should be the same with the addition of the passenger sensor. I don't think I will bother calibrating the sensor at the dealership. I'll just get one of my friend's kids at the shop to sit on the seat and test. I think it's 40 lbs that it activates so I'll test and report back. I wouldn't recommend this to people who are extremely picky on how centered their seat is or do not have any ability to fabricate adapters or weld new tabs to the bases. But I do have to say they feel great to sit in. I always lean to the left when I drive so it brings me closer to the door armrest. I've sat in all other OEM Subaru seats and these, to me, are way better in support especially in turns. I don't slide around hardly. I hope I can swap the covers onto the rears. That's my next project after the passenger seat. UPDATE: I got the driver's seat aligned properly. Fortunately the speedware brackets have slots that allow positioning for centering. Now I can put an amp under there with all the room. Link to comment Share on other sites More sharing options...
al-gorithm Posted August 6, 2008 Author Share Posted August 6, 2008 Driver's side pics http://i60.photobucket.com/albums/h15/al-gorithm/RecaroSeatDriversSide.jpg Link to comment Share on other sites More sharing options...
al-gorithm Posted August 6, 2008 Author Share Posted August 6, 2008 Not going to even try the passenger side... what a clusterf**k under there. Too much modification under there to try. Link to comment Share on other sites More sharing options...
al-gorithm Posted August 6, 2008 Author Share Posted August 6, 2008 Maybe rear seat pics? Link to comment Share on other sites More sharing options...
VTGT Posted August 6, 2008 Share Posted August 6, 2008 Subscribe Link to comment Share on other sites More sharing options...
PhilT Posted August 6, 2008 Share Posted August 6, 2008 Great work Al, I'm hoping the '08 STi seats are a direct fit though. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
al-gorithm Posted August 6, 2008 Author Share Posted August 6, 2008 The STi rails hopefully will mount to the LGT bases. I know that my brother's 03WRX seats did. Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2008 Share Posted August 6, 2008 Great work Al, I'm hoping the '08 STi seats are a direct fit though. They are, already confirmed. Link to comment Share on other sites More sharing options...
MOMSWGN Posted August 6, 2008 Share Posted August 6, 2008 08 Sti seats aren't that much of an improvement over the LGTs, just sat in on today. Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2008 Share Posted August 6, 2008 08 Sti seats aren't that much of an improvement over the LGTs, just sat in on today. I think they suck and are worse than LGT seats. Link to comment Share on other sites More sharing options...
cfdrumr Posted August 6, 2008 Share Posted August 6, 2008 ...they look good! Link to comment Share on other sites More sharing options...
MOMSWGN Posted August 6, 2008 Share Posted August 6, 2008 How exactly does one get around the air bag problem? I guess that this would not be much of a problem with the 08 seats. Link to comment Share on other sites More sharing options...
al-gorithm Posted August 6, 2008 Author Share Posted August 6, 2008 I was thinking of securing the side airbags to the frame like they are in the stock seat, then stitching a velcro piece along the side stitching or it's stock equivalent position where it would eject. This is overkill for me, but if I had the time, I would do that but I don't think it would work because I think the frame is too far deep in the seat for it to properly inflate. Link to comment Share on other sites More sharing options...
DiscoWagon Posted August 6, 2008 Share Posted August 6, 2008 Why didn't you get seat rails made for the LGT? Link to comment Share on other sites More sharing options...
al-gorithm Posted August 6, 2008 Author Share Posted August 6, 2008 Speedware doesn't make brackets for the LGT. It would have to be custom for that. Maybe I'll offer to template a set for them. I'm not the only one with recaro seats on this board. I think he had to get his modified too but I don't know for sure. Link to comment Share on other sites More sharing options...
whitetiger Posted August 6, 2008 Share Posted August 6, 2008 What about JDM 08+ sti seats? Did the jdm STI come with recaros as standard? Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2008 Share Posted August 6, 2008 What about JDM 08+ sti seats? Did the jdm STI come with recaros as standard? As an option, yes. So do EDM have that option - non-UK EDM would be a better choice if one doesn't want to sit in passenger seat all the time Link to comment Share on other sites More sharing options...
MOMSWGN Posted August 7, 2008 Share Posted August 7, 2008 Do the jdm 08 STi seats have an air bag? Link to comment Share on other sites More sharing options...
Guest Posted August 7, 2008 Share Posted August 7, 2008 yes Link to comment Share on other sites More sharing options...
DiscoWagon Posted August 7, 2008 Share Posted August 7, 2008 Speedware doesn't make brackets for the LGT. It would have to be custom for that. Maybe I'll offer to template a set for them. I'm not the only one with recaro seats on this board. I think he had to get his modified too but I don't know for sure. Maybe you shouldn't buy from Speedware: http://tees-usa.com/seatrail_su.html Bride has two styles of rails that will fit your Recaro. Link to comment Share on other sites More sharing options...
slug6er Posted August 7, 2008 Share Posted August 7, 2008 the gc or gd chassis seat brackets dont fit at all from what i was told the pan on the legacy is the same as an outback. as for rails and brackets i bought mine from wedge engineering. as for the passenger side good luck on that im still trying to figure out how to get rid of the airbag light there is like a million wires under there. Link to comment Share on other sites More sharing options...
whitetiger Posted August 7, 2008 Share Posted August 7, 2008 As an option, yes. So do EDM have that option - non-UK EDM would be a better choice if one doesn't want to sit in passenger seat all the time so, the best bet is to get a LHD EDM 08+ sti front seat set. Anyone know any place that imports this stuff? Link to comment Share on other sites More sharing options...
Guest Posted August 7, 2008 Share Posted August 7, 2008 so, the best bet is to get a LHD EDM 089+ sti front seat set. Anyone know any place that imports this stuff? We lack good Euro importer on the board... plus with EUR/USD rate I am afraid to know the cost. We should ask Japanparts if they have access to Euro spec parts. After all they come from Japan... Link to comment Share on other sites More sharing options...
MOMSWGN Posted August 7, 2008 Share Posted August 7, 2008 If someone can arrange for this, I'd be in for a front set. Link to comment Share on other sites More sharing options...
VTGT Posted August 8, 2008 Share Posted August 8, 2008 ^ Me too my front seat rocks back and forth Link to comment Share on other sites More sharing options...
