mikesae Posted July 24, 2008 Share Posted July 24, 2008 Removing that gummy foamy strip is a pain! http://www.marcparnes.com/WheelWeights.jpg Link to comment Share on other sites More sharing options...
GULLABLE0NE Posted July 24, 2008 Share Posted July 24, 2008 check your local pep boys or whatever auto store that sells cheap accesories. "Goo Gone" is the greatest invention for removing sticky/ adhesive stuff. it comes in a small bottle for a few bucks but a little goes a long way. its what i use to get the double-sided tape of my trunk when debadging. Link to comment Share on other sites More sharing options...
mikesae Posted July 24, 2008 Author Share Posted July 24, 2008 perfect will do, thanks. Link to comment Share on other sites More sharing options...
DiscoWagon Posted July 25, 2008 Share Posted July 25, 2008 +1 for Goo Gone Link to comment Share on other sites More sharing options...
Bbc84 Posted July 25, 2008 Share Posted July 25, 2008 Goo Gone, maybe some Bug and Tar remover? Link to comment Share on other sites More sharing options...
SubLGTaru Posted July 25, 2008 Share Posted July 25, 2008 what is the point of removing it? Link to comment Share on other sites More sharing options...
rurouni_x Posted July 25, 2008 Share Posted July 25, 2008 what is the point of removing it? You can see it through the spokes of your wheels. Link to comment Share on other sites More sharing options...
Underdog Posted July 25, 2008 Share Posted July 25, 2008 check your local pep boys or whatever auto store that sells cheap accesories. "Goo Gone" is the greatest invention for removing sticky/ adhesive stuff. it comes in a small bottle for a few bucks but a little goes a long way. its what i use to get the double-sided tape of my trunk when debadging. The Crimson Dynamo Link to comment Share on other sites More sharing options...
TRS Posted July 25, 2008 Share Posted July 25, 2008 Removing that gummy foamy strip is a pain! Heat will soften up the adhesive so you can "roll" off most of the foam with your finger. A heat gun or hair drier is an efficient way, but you can even just position the wheel out in the sun so it heats up. I've had good success using 3M Adhesive & Wax Remover for left-over adhesive residue. http://3m.hillas.com/GetThumbNail.aspx?Type=Item&Image=13847&Size=large "Quickly removes wax, grease, oil and adhesive residue. It will not harm most cured automotive paints and is also suitable for vinyl and glass surfaces." Ingredients: SOLVENT NAPHTHA (PETROLEUM), LIGHT ALIPHATIC XYLENE ETHYLBENZENE TOLUENE BENZENE Link to comment Share on other sites More sharing options...
SpecBee Posted July 25, 2008 Share Posted July 25, 2008 http://www.mvdirona.com/jrh/SmartPhone/Images/ValsparGoofOffLineUp.jpg Goof off will remove any and everything even your girlfriends skirt. if she sniffs enough of it while you use it..... Link to comment Share on other sites More sharing options...
lawl Posted July 26, 2008 Share Posted July 26, 2008 that'll strip your paint though, if your wheels are painted. car for sale. PM me! Link to comment Share on other sites More sharing options...
SpecBee Posted July 27, 2008 Share Posted July 27, 2008 that'll strip your paint though, if your wheels are painted. YES! that too.. Very good, you're learning LAWL...Anyone else? Link to comment Share on other sites More sharing options...
km580 Posted July 27, 2008 Share Posted July 27, 2008 WD40 works good too, I used it for debadging. Won't hurt the paint. Fat people are hard to kidnap!!! Link to comment Share on other sites More sharing options...
MiniStiGuy Posted July 31, 2008 Share Posted July 31, 2008 pee on it? OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
rurouni_x Posted August 1, 2008 Share Posted August 1, 2008 haha i did that once when i was drunk, I was like I peening on this douchebag's gold wheels, then i was like dammit this is my car Link to comment Share on other sites More sharing options...
Heytiggr Posted August 4, 2008 Share Posted August 4, 2008 +1 for WD 40. You can also use goodl ol' cooking oil. This is one of those cool tricks from chemistry class: the acid and base interaction. The slippery stuff helps remove the sticky stuff - and no paint damage at all! Sometimes it make take a little elbow grease if the sticky stuff is old or really baked on, but I'd rather take the time and effort to keep my paint safe. Link to comment Share on other sites More sharing options...
