fweasel Posted June 6, 2008 Share Posted June 6, 2008 Babies have got to be cheaper. That is all. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
KartRacerBoy Posted June 6, 2008 Share Posted June 6, 2008 How many race days did the Hawks last? Which pad specificallyl? Link to comment Share on other sites More sharing options...
KartRacerBoy Posted June 6, 2008 Share Posted June 6, 2008 And I bet your fast pad wear had a lot to do with those R compound slicks you like to drive to work on (as well as on the track). Link to comment Share on other sites More sharing options...
rao Posted June 6, 2008 Share Posted June 6, 2008 FWIW, kids are NOT cheaper Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
KartRacerBoy Posted June 6, 2008 Share Posted June 6, 2008 Oh, and that's "ridiculous"! And didn't you have less grippy pads in the back? That would be another factor shifting the braking force to those fancy front racing pads, wouldn't it? Link to comment Share on other sites More sharing options...
KartRacerBoy Posted June 6, 2008 Share Posted June 6, 2008 FWIW, kids are NOT cheaper One meal a day and they are. And then they don't grow so much and you save on clothes. And then you can spend $$$ on fancy brake pads for track days when you took the work day off and made no money to support them. It's all good! Link to comment Share on other sites More sharing options...
magnetic1 Posted June 7, 2008 Share Posted June 7, 2008 I thought you had Brembos? They are kinda expensive, but also depends on what brand. Also, like mentioned above, using non-track pads in the rear wear the fronts faster. The one thing that will absolutely increase pad life is ducting. If you can find a way to add ducting to cool the rotors, pad life increases dramatically! Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
Xenonk Posted June 10, 2008 Share Posted June 10, 2008 yank out the fog lights and run the ducting through there.. simple enough, the hard part is fastening the ducts close enough to the center of the hub. Keefe Link to comment Share on other sites More sharing options...
