fweasel Posted June 6, 2008 Share Posted June 6, 2008 I just read this on IWSTI and admit, I had also been previously misinformed... Torque specs for front brembo caliper mounting bolts is not not 114.3 ft/lbs Who ever spread this information is incorrect. I am not sure if this is what the STi shop manual says but if it does it is also incorrect. I just got off the phone with BREMBO USA and here is what i just found out. Torque spec for front Brembo caliper mounting bolts is 80 ft/lbs. BTW: The helpful brembo rep on the phone said 80 ft/lbs = 114 newton meters. Please be careful and let's stop the insanity of snapping caliper bolts and stripping caliper threads. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
Guest Posted July 3, 2008 Share Posted July 3, 2008 Indeed the 2005 STI factory manual I have says 155 Nm = 114.3 ft-lb!!!!! Link to comment Share on other sites More sharing options...
Underdog Posted April 17, 2010 Share Posted April 17, 2010 Bump for visibility! Thanks for the info... I chased all the threads and antiseized them before torquing them. I like to back off the torque ~10% when I antiseize them so I only used 70ftlbs. It looks like the Legacy OEM rear caliper supports get torqued to 40ftlbs. I wonder if this is true for rear Brembo adapters as well? Mine are threaded M10x1.25. The Crimson Dynamo Link to comment Share on other sites More sharing options...
GTLEGACY007 Posted February 18, 2011 Share Posted February 18, 2011 Question on this: should the threads be chased on a used set of Brembo's no matter what? Or is anti-seize enough? Also, is there Brembo specific hardware to use to mate the Brembos to the LGT hub? Link to comment Share on other sites More sharing options...
wpmarky Posted February 18, 2011 Share Posted February 18, 2011 the bolts are different, you'll need STI bolts. Link to comment Share on other sites More sharing options...
GTLEGACY007 Posted February 18, 2011 Share Posted February 18, 2011 the bolts are different, you'll need STI bolts. Roger that. What'd you do on yours, anti seize only or anti seize and Chase the threads? Link to comment Share on other sites More sharing options...
Underdog Posted February 18, 2011 Share Posted February 18, 2011 Mine have held up fine with just anti-seize. Removed both front calipers recently for a wheel bearing replacement and all was well. The Crimson Dynamo Link to comment Share on other sites More sharing options...
wpmarky Posted February 18, 2011 Share Posted February 18, 2011 uh, neither xD I just put the bolts on. I'm going to take them off this weekend and put some anti seize, hope they come off ok. Link to comment Share on other sites More sharing options...
GTLEGACY007 Posted February 19, 2011 Share Posted February 19, 2011 Cool, i'll just be going the anti-seize only route. I'm hoping that'll be good enough... Link to comment Share on other sites More sharing options...
dschultz Posted February 19, 2011 Share Posted February 19, 2011 I used 65 to 70lb-ft with anti-seize rather than 80 so as not to strip out the caliper holes. Link to comment Share on other sites More sharing options...
GTLEGACY007 Posted February 20, 2011 Share Posted February 20, 2011 exactly what i was thinking. I'll apply some anti-seize, and torque them about 70 ft-lbs and hopefully that'll do it Link to comment Share on other sites More sharing options...
integroid Posted February 20, 2011 Share Posted February 20, 2011 I just had my machine shop put helicoils in all of mine and never had a problem with them. Link to comment Share on other sites More sharing options...
Chameleon Posted February 23, 2011 Share Posted February 23, 2011 I just had my machine shop put helicoils in all of mine and never had a problem with them. which machine shop? how much did they charge? pm me if needed pls Link to comment Share on other sites More sharing options...
integroid Posted February 23, 2011 Share Posted February 23, 2011 which machine shop? how much did they charge? pm me if needed pls Ball Engine and machine. They built my original motor so they pretty much just did it for free. I just purchased the Heli-Coils and they put them in. I think they usually charge like $10-$20 each. Link to comment Share on other sites More sharing options...
