05 Outback 2.5i Posted January 18, 2005 Share Posted January 18, 2005 Did anyone else notice that outside temperature display seems to consistantly read 3 degrees higher than every one of those road side bank signs? Based on reports from the local news, I tend to side with the bank signs for acuracy over the Outback. Anyone else notice this? Anyone know if it can be recalibrated by the dealer? _________________ ~Scott & Nadia '05 Outback 2.5i Wagon Willow Green Opal/ Moss Green Metallic 225/60HR16 BFG Traction T/A's Link to comment Share on other sites More sharing options...
Guest JessterCPA Posted January 18, 2005 Share Posted January 18, 2005 Yes. It always seems a little colder than the temp readout says. Link to comment Share on other sites More sharing options...
D-2.5-GT Posted January 18, 2005 Share Posted January 18, 2005 haven't noticed that....but then again i don't drive by too many banks with that type of sign on a daily basis. If anything i would expect those large signs to be off. There used to be one where i lived previously which would get messed up every now and again and read something foolish like 92 degrees on a day when it was snowing and very cold! Link to comment Share on other sites More sharing options...
PGT Posted January 18, 2005 Share Posted January 18, 2005 I have an Oregon Scientific thermometer set-up with an outdoor remote sensor. It read 14 this morning. I went out the the car and started it up to let the heat and seats come up to temp....the car readout said 15. Link to comment Share on other sites More sharing options...
golfnz34me Posted January 19, 2005 Share Posted January 19, 2005 I have a similar problem with my new 2.5i. It usually shows a few degrees warmer than it is outside. In fact, the other morning when it was -13 outside it indicated +3 degrees Otherwise I love my new car! Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted January 19, 2005 Share Posted January 19, 2005 They tend to do that- I think it's because the sensor is located next to the radiator. Link to comment Share on other sites More sharing options...
Guest JessterCPA Posted January 19, 2005 Share Posted January 19, 2005 They tend to do that- I think it's because the sensor is located next to the radiator. My wife's TSX is dead on. Perfect reading. Link to comment Share on other sites More sharing options...
scubie02 Posted January 19, 2005 Share Posted January 19, 2005 tsx's are better...;P mine seems to fluctuate as I drive...I have to assume changing because of engine heat--it warms up quite a bit outside as I drive...;P Link to comment Share on other sites More sharing options...
dustinw Posted January 19, 2005 Share Posted January 19, 2005 I don't think they are accurate unless you are moving. However mine seems to be accurate enough that I've not noticed any significant discrepancies. Link to comment Share on other sites More sharing options...
Euclid Posted January 19, 2005 Share Posted January 19, 2005 well, it is a guage, not an exactometer. Link to comment Share on other sites More sharing options...
05LegacyGT330Ci Posted January 19, 2005 Share Posted January 19, 2005 I don't think they are accurate unless you are moving. However mine seems to be accurate enough that I've not noticed any significant discrepancies. I agree you need to be moving, if you are just sitting the car will be off most likely based on where its sitting. After 5 minutes it should be pretty close on and I notice it to not be too far off against other temperature gauges. '05 Black Legacy GT Wagon 5-spd '02 Topaz/Black 330Ci 5-spd Drift Ryder's School of Rally Arts, coming to an Australia near you. Link to comment Share on other sites More sharing options...
Deer Killer Posted January 19, 2005 Share Posted January 19, 2005 I've seen bank signs that have said 90F when it's 70F out.. Why would they be reliable sitting 10-15 ft in the air baking in the sun, when your air temp sensor is 8" of the ground and moving through air and a high rate of speed. You could have a thermometer sticking out your window and the real air temp could be 3 degrees from outside your window to the sensor on your car. Link to comment Share on other sites More sharing options...
rao Posted January 19, 2005 Share Posted January 19, 2005 Same here, shows about 4 degrees to warm in the car. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
firedawgs Posted January 20, 2005 Share Posted January 20, 2005 9 degrees here in southeastern MA this morning. The car struggled a little bit starting too. I heard that our car does not having very high Cold Cranking Amps on the battery. I guess an Optima battery can be on the list of upgrades. Updated my vBGarage: Link to comment Share on other sites More sharing options...
