Naylor Posted May 7, 2008 Share Posted May 7, 2008 i've been on cobb springs, stock struts now for about 7 months. i had an alignment done not too long after my spring install. i'm starting to notice uneven wear on the inside of my front passenger side tire...every other thread is wearing faster than the other, like a wave. Could this just be a bad alignment or blown strut or both? thanks Link to comment Share on other sites More sharing options...
Opie Posted May 7, 2008 Share Posted May 7, 2008 It could be either, but i'd get the alignment checked first, pay attention to the toe settings... Link to comment Share on other sites More sharing options...
whitetiger Posted May 7, 2008 Share Posted May 7, 2008 +1 to alignment first, but the stock struts are crap to begin with. putting lowering springs on them makes bad in to worse. If you alignment ends up being good, id get a set of koni struts and ditch the stockers. Link to comment Share on other sites More sharing options...
hiymeh Posted May 8, 2008 Share Posted May 8, 2008 Naylor.... I just had the exact same problem, passenger front strut was the root cause. It should be really obvious though if the toe angle is out that far. Michigan winters or more so michigan roads are hard on cars. I had 5 alignment settings in the red :o) Link to comment Share on other sites More sharing options...
Naylor Posted May 8, 2008 Author Share Posted May 8, 2008 thanks for everyone's quick responses...the wavy tread wear is what makes me think its the strut, but i'll find out today on the alignment. Link to comment Share on other sites More sharing options...
Underdog Posted May 8, 2008 Share Posted May 8, 2008 That's called "cupping" and is usually an indication of worn suspension components. Given how weak the stock struts are, I'm sure any lowering spring would quickly put them to bed. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Naylor Posted May 8, 2008 Author Share Posted May 8, 2008 got your pm! thanks. this is quickly turning expensive. i'm sure the wear on my tires are too much to just replace one. 1. new tires 2. new struts 3. possibly new springs to mate w/ spec b top hats my wife is going to love this one! :lol: Link to comment Share on other sites More sharing options...
Underdog Posted May 8, 2008 Share Posted May 8, 2008 got your pm! thanks. this is quickly turning expensive. i'm sure the wear on my tires are too much to just replace one. 1. new tires 2. new struts 3. possibly new springs to mate w/ spec b top hats my wife is going to love this one! :lol: you have to play the safety card! especially if you have rugrats in the car! talk about expensive? i spent $2700 on suspension parts and then had to drop another ~$500 on tools to do the job myself. considering we're 5 months out from our wedding my fiance' didn't give me too much trouble. Oh and I did not count the Tokicos in that $2700 as they were a backup... you can imagine why i'm eager to sell! The Crimson Dynamo Link to comment Share on other sites More sharing options...
Naylor Posted May 16, 2008 Author Share Posted May 16, 2008 well, the alignment cameback fine, rotated the tires and adjusted the toe a bit. looks like i need to start the debate between new struts or coilovers. Link to comment Share on other sites More sharing options...
