Voo Posted April 14, 2008 Share Posted April 14, 2008 Have a '06 LGT and being the cheap ass that I am, I was looking into getting a STI UP to replace mine. Does anyone have a suggestion as to what MY I should look at? And will I need to make any mods to the STI UP before installation? Thanks! Link to comment Share on other sites More sharing options...
The_Condor Posted April 14, 2008 Share Posted April 14, 2008 Any Sti up pipe will work. If you can, find one with the heat with heat shields in good condition. Link to comment Share on other sites More sharing options...
Voo Posted April 14, 2008 Author Share Posted April 14, 2008 Thanks Condor. So I will need to make sure that the UP comes with the heat shield? I know my car has the COBB shield already installed. Does that count? Link to comment Share on other sites More sharing options...
Voo Posted April 15, 2008 Author Share Posted April 15, 2008 I've got an offer for a 02-05 WRX STI Catless U/P (Just the U/P, nothing else). I plan on buying it if I can find out if it fits. Also, what kinda grommets would I need to buy as replacements, and is there anything else I would need to get before the install? As I mentioned, I already have a COBB D/P and heatshield installed. Thanks! Link to comment Share on other sites More sharing options...
Alaskan_Legacy Posted April 15, 2008 Share Posted April 15, 2008 Just a new Subaru gasket would be good. It's $20 or $30, I don't remember which one was which. Link to comment Share on other sites More sharing options...
JonLGT Posted April 15, 2008 Share Posted April 15, 2008 Get new gaskets and watch out for the half moon plugs between the head and the valve cover. Link to comment Share on other sites More sharing options...
05Limited Posted April 18, 2008 Share Posted April 18, 2008 The heatshield on the uppipe is a different heatshield than the one on your turbo - it stays permanently (hopefully) welded to the uppipe. Link to comment Share on other sites More sharing options...
Vsick Posted April 18, 2008 Share Posted April 18, 2008 I just bought one as well.....Is it true that if installing aftermarket downpipe you can just remove the heatshield? Link to comment Share on other sites More sharing options...
05Limited Posted April 18, 2008 Share Posted April 18, 2008 You never "have" to run the heatshield... it's just a compromise, the more shielding, the less heat in your engine compartment... it's not gonna tear anything up, just a marginal (maybe moderate) performance caused by heatsoak. Link to comment Share on other sites More sharing options...
Waxiboy Posted April 22, 2008 Share Posted April 22, 2008 Don't forget the resistor mod if you do not have AP. Link to comment Share on other sites More sharing options...
Voo Posted April 22, 2008 Author Share Posted April 22, 2008 Thanks for all the feedback! Got the STi U/P and both gaskets from Subaru for $80. I have AP, but I figure I'll shove the resistor in JIC. Now need to get my COBB Bushings, Apex HID kit and I'll be set for Install-day!!! PS: Someone in my area is selling Gimmick bushings, are they any different from the COBB ones? Link to comment Share on other sites More sharing options...
j255c Posted April 22, 2008 Share Posted April 22, 2008 go with a after market uppipe, i have a used sti-uppipe, while it was fine when i first installed it the heatshield welds have cracked and it rattles around now. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
Vsick Posted April 22, 2008 Share Posted April 22, 2008 go with a after market uppipe, i have a used sti-uppipe, while it was fine when i first installed it the heatshield welds have cracked and it rattles around now. solution is just to remove it right? after market up pipes do not have heat shields which results in no cracking . Link to comment Share on other sites More sharing options...
