hutru01 Posted April 4, 2008 Share Posted April 4, 2008 ^ That reminds me I need to touch up my FMIC...it is painted black and has a lot of rock chips... Link to comment Share on other sites More sharing options...
jmo Posted April 4, 2008 Share Posted April 4, 2008 http://www.legacygt.com/forums/showthread.php?t=84688 This is where i learned to do my own emblem Its raining like crazy out, so I'll have some decent pics soon. Link to comment Share on other sites More sharing options...
HighlineCA Posted April 4, 2008 Share Posted April 4, 2008 FYI - We can sandblast strip the chrome off the grill. We strip metal laid to plastic on our NSX bezels all the time. Then sand and refinish the trim in whatever color you wish. Thanks, Rich @ HCA Link to comment Share on other sites More sharing options...
jmo Posted April 4, 2008 Share Posted April 4, 2008 I've found a way to make behind the grill black!! After you make your grill turn it around and lay down mulch film. ( The stuff you use to prevent weeds from growing) Screw in the film with 2 screws at the bottom of the grill and 2 at the top. Then spray between the grill and film with spray glue. Let dry. Link to comment Share on other sites More sharing options...
jmo Posted April 4, 2008 Share Posted April 4, 2008 Then insert your grill and pop its. Link to comment Share on other sites More sharing options...
Zed 2.0 Posted April 4, 2008 Share Posted April 4, 2008 I've found a way to make behind the grill black!! After you make your grill turn it around and lay down mulch film. ( The stuff you use to prevent weeds from growing) Screw in the film with 2 screws at the bottom of the grill and 2 at the top. Then spray between the grill and film with spray glue. Let dry. You do realize that your radiator likes air, right? Link to comment Share on other sites More sharing options...
jmo Posted April 4, 2008 Share Posted April 4, 2008 Then drive around and then the film will look fitted. Link to comment Share on other sites More sharing options...
jmo Posted April 4, 2008 Share Posted April 4, 2008 I lets in alot of air, everything seems to be ok so far, but i will be keeping my eye on it. Link to comment Share on other sites More sharing options...
jmo Posted April 4, 2008 Share Posted April 4, 2008 While doing this all, I decided to paint around the fogs. I painted what was normally black, quartz silver. What was off silver, I painted black. Not sure what I think but I'm lovin the grill!! Link to comment Share on other sites More sharing options...
MiniStiGuy Posted April 4, 2008 Share Posted April 4, 2008 ummm your better off using actual window screening instead of mulch tarp because the airflow will be greater through the screening instead of the mulch tarp. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
jmo Posted April 6, 2008 Share Posted April 6, 2008 you're right mini, the tarp was just to strong and only let in minimal air flow. Link to comment Share on other sites More sharing options...
Golf4283 Posted April 12, 2008 Share Posted April 12, 2008 I bought all the recommended supplies last night for this and am gonna take the plunge and cut up my grill today after work. Any tips you guys have who have done it. Mounting the badge and mesh? Link to comment Share on other sites More sharing options...
collegemt Posted April 12, 2008 Author Share Posted April 12, 2008 my walkthrough explains how i did it. Link to comment Share on other sites More sharing options...
Golf4283 Posted April 12, 2008 Share Posted April 12, 2008 I was wondering how sturdy the grill stuff is. Im worried about it getting dented and pushed in. Link to comment Share on other sites More sharing options...
Rishi Posted April 12, 2008 Share Posted April 12, 2008 Making it look like a Bentley. Link to comment Share on other sites More sharing options...
collegemt Posted April 12, 2008 Author Share Posted April 12, 2008 I was wondering how sturdy the grill stuff is. Im worried about it getting dented and pushed in. It is not as sturdy as the stock grill, as far as denting it goes, if you get in a accident it will mees it up, but i think everyday driving it should be fine. It is pretty flexible mesh, so it can bend a bit. Link to comment Share on other sites More sharing options...
Golf4283 Posted April 12, 2008 Share Posted April 12, 2008 yea I just worry though if I take it to get it washed somewhere the guy drying it will smash it in. Link to comment Share on other sites More sharing options...
collegemt Posted April 12, 2008 Author Share Posted April 12, 2008 I was worried about that myself, i took it to a car wash yesterday, it had the big blow dryers, no problems. I might be a bit worried if somone else was drying the car though. Link to comment Share on other sites More sharing options...
Throttlejockey Posted April 12, 2008 Share Posted April 12, 2008 I bought all the recommended supplies last night for this and am gonna take the plunge and cut up my grill today after work. Any tips you guys have who have done it. Mounting the badge and mesh? I drilled two small holes in the plastic part that the emblem connects to and safety wired it to the grill. I also used clear silicone since it moved around a little. To hold it in place I ran a zip-ty through the grill and around the emblem till it dried. I also used silicone on the emblem itself. Link to comment Share on other sites More sharing options...
Golf4283 Posted April 12, 2008 Share Posted April 12, 2008 Just got done with mine. Just around 3.5 hours to do the whole job and that includes a trip to Home depot. I think I'm gonna order some new mesh online though, the powder coated stuff. I feel this will chip easily. I painted it flat black too which I like a lot better. hardest part was getting that damned thing off. I couldn't find the two side screws to save my life. Almost gave up but glad I didn't Check it out Link to comment Share on other sites More sharing options...
nemo Posted April 12, 2008 Share Posted April 12, 2008 Looks good, Golf. I think I am gonna order the powder coated stuff as well. I was messing around today, and found that if you stick a little mirror behind the grille (come up from the bumper) you can find the screws very easily. If you don't vote Trump, out, you're a bigot who hates america. Link to comment Share on other sites More sharing options...
collegemt Posted April 13, 2008 Author Share Posted April 13, 2008 Golf it turned out great. No more wings aren't you happy. How did you end up mounting the emblem? Link to comment Share on other sites More sharing options...
Throttlejockey Posted April 13, 2008 Share Posted April 13, 2008 Looks good, Golf. I think I am gonna order the powder coated stuff as well. I was messing around today, and found that if you stick a little mirror behind the grille (come up from the bumper) you can find the screws very easily. I'm happy with the powder coated stuff. I had a chip and touched it up with some black touch up paint I have for my truck. Can't even tell. Link to comment Share on other sites More sharing options...
Golf4283 Posted April 13, 2008 Share Posted April 13, 2008 I love it. To get the emblem on I drilled 4holes in the chrome tribe ring in the 4 tabs that stick out. I then ran small gauge steel wire through the holes. After that I used jb quick weld to hold it to the emblem then I tied it on. Easy easy job. Anyone with an 08 NEEDS to do this. Link to comment Share on other sites More sharing options...
collegemt Posted April 13, 2008 Author Share Posted April 13, 2008 Easy easy job. Anyone with an 08 NEEDS to do this. Very Very True! Link to comment Share on other sites More sharing options...
