SpawnGT Posted March 24, 2008 Share Posted March 24, 2008 Quick question...stage 2.5FMIC and have a crucial shorty(NO CAT) connected to a deccatted Mid, connected to the XO2 catback. Would closing one of the Y-pipe pipes causing it to be one long exhaust like the sti be a bad thing for the car? right now im consiering have a muffler shop weld into one of the y-pipes my electrical exhaust cutout so that with only 1 xo2 can i have alil less loudness. Link to comment Share on other sites More sharing options...
hakgwai Posted March 24, 2008 Share Posted March 24, 2008 i'm thinking shouldn't be a problem. since there are companies that make single side mufflers Link to comment Share on other sites More sharing options...
JNRacing Posted March 24, 2008 Share Posted March 24, 2008 Is the y pipe 3 inches after the split? you don't want to decrease the flow of your exhaust. Link to comment Share on other sites More sharing options...
Instanced Posted March 25, 2008 Share Posted March 25, 2008 Install a Flap system when there's alot of pressure, the flap will open and the extra needed flow will occur... i think the R32 does that... correct? "flapper mod" ... R32 owners do that which = forcing the flap open all the time... the flap helps keep the noise down at lower rpms... but really opens up when you get on it. I bet you could even get that flap directly from someone who replaced their R's exhaust system Link to comment Share on other sites More sharing options...
SpawnGT Posted May 19, 2008 Author Share Posted May 19, 2008 BUMP this thread up. Instead of starting a new thread on the "flapper" i want to know if anyone has any ideas or actual examples of a flapper system from such a car like the r32, or the Audi's out there, that would allow for some kind of "flapper" action without our exhausts. Link to comment Share on other sites More sharing options...
SeeeeeYa Posted May 20, 2008 Share Posted May 20, 2008 BUMP this thread up. Instead of starting a new thread on the "flapper" i want to know if anyone has any ideas or actual examples of a flapper system from such a car like the r32, or the Audi's out there, that would allow for some kind of "flapper" action without our exhausts. To be honest, this isn't complicated to do. Virtually all the older V8s used such a "flapper" on one exhaust manifold to route exhaust in such a way as to heat the engine up quicker, routing it circuitously over to the other side's exhaust pipe. It was both heat and pressure operated, where a bimetal coil kept it closed until heated, OR the exhaust forced the offset-hinged butterfly valve open. The mechanism is called a Heat Riser. However, all the modifications one ever did to those mechanisms was, mostly, to eliminate them when performance was the aim. Link to comment Share on other sites More sharing options...
BigBad Posted May 20, 2008 Share Posted May 20, 2008 I believe Pltek makes a single side catback, 3" all the way front to back including a 12" resonator. Link to comment Share on other sites More sharing options...
mwiener2 Posted May 20, 2008 Share Posted May 20, 2008 I'm single outet My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Xenonk Posted May 20, 2008 Share Posted May 20, 2008 I think Apex'i makes their RS revolution exhaust with a spring-loaded system to quiet their exhausts down.. you may want to check that out. Keefe Link to comment Share on other sites More sharing options...
HangKen Posted May 20, 2008 Share Posted May 20, 2008 I think Apex'i makes their RS revolution exhaust with a spring-loaded system to quiet their exhausts down.. you may want to check that out. My friend has one of these and it really works. http://www.apexi.co.jp/products/exhaust/ecv.html Sorry, in Japanese but it says it reduces up to 10 dB and the cost range from $170 - $200. Link to comment Share on other sites More sharing options...
BlackHole Posted May 21, 2008 Share Posted May 21, 2008 Interesting. There is a Nissan 67mm (2.5") application that might fit aftermarket LGT Y-pipes if they have a 2-bolt flange w/ 106mm (~4.2") bolt spacing. Kyle "BlackHole" Link to comment Share on other sites More sharing options...
fullerslgt Posted May 22, 2008 Share Posted May 22, 2008 As far as horsepower is concerned wouldnt a single exhaust be better? My buddy had dual on his turbod honda and switched to single and gained over 20 at the wheels. Link to comment Share on other sites More sharing options...
SeeeeeYa Posted May 22, 2008 Share Posted May 22, 2008 As far as horsepower is concerned wouldnt a single exhaust be better? My buddy had dual on his turbod honda and switched to single and gained over 20 at the wheels. I suspect you're comparing apples to oranges. A BIG single probably is better than a skinny stock dual exhaust. But a BIG well designed dual exhaust is going to be better than a similarly designed single, all other things being equal such as mufflers. That said, one BIG pipe with a straight through "muffler" is probably best of all. Link to comment Share on other sites More sharing options...
Infamous1 Posted May 22, 2008 Share Posted May 22, 2008 A single outlet will increase the exhaust noise as well... Link to comment Share on other sites More sharing options...
a.lim Posted May 25, 2008 Share Posted May 25, 2008 if you are trying to reduce the sound level this isn't a good idea.. infamous is right it'll be louder. and more cabin drone. more pressure being exerted out into a smaller exit is what you're trying to avoid. its like placing your thumb over the opening of a water hose. thats my analogy. Link to comment Share on other sites More sharing options...
