dasbigunit Posted March 17, 2008 Share Posted March 17, 2008 Hey Guys, Do any of you know of a good place that explains how to do a clutch swap? I have the subaru tech docs pages CL-2 through 14, but I'm looking for either the facotry manual or a walkthrough on how to pull the transmission down. It should be factory pages 5MT 25 through about 29 or so... has anyone done it themselves? I've never done one on a subaru, but I've done clutch swaps before... is it more difficult with suby's? anyone? help? please? -EdMSA5T0505A54033 clutch disc and cover removal.pdf Link to comment Share on other sites More sharing options...
dasbigunit Posted March 17, 2008 Author Share Posted March 17, 2008 i found it, posting it below... still looking for someone who's done it themselves to rate the difficulty.... Thanks, EdMSA5T0505A54013 - MT 25-30 ASSY.pdf Link to comment Share on other sites More sharing options...
whitetiger Posted March 17, 2008 Share Posted March 17, 2008 well, you have to take the trans out. if you have a lift and a trans jack with air tools, then its a pretty easy task and can be done in 4hrs. If you dont have these things, then I wouldnt do it yourself. Link to comment Share on other sites More sharing options...
Infamous1 Posted March 17, 2008 Share Posted March 17, 2008 Everything is pretty straight foward, the part I found most difficult was separating the engine and trans then joining them back together. If you have a hoist, it is a plus. If you are doing it on jack stands be prepare for fun and back aches Link to comment Share on other sites More sharing options...
rao Posted March 17, 2008 Share Posted March 17, 2008 +1 You can also remove the motor (or slide it forward a few inches). It is not harder than on other cars, but having a lift would make it a lot easier. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
dasbigunit Posted March 18, 2008 Author Share Posted March 18, 2008 did you guys need a special tool to seperate the front driveshafts from the transmission housing? thanks for the replies by the way. Link to comment Share on other sites More sharing options...
rao Posted March 18, 2008 Share Posted March 18, 2008 You don't need a special tool for that. The flywheel bolts are TORX PLUS though so keep that in mind. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
dasbigunit Posted March 18, 2008 Author Share Posted March 18, 2008 Thanks Rao, I may just have to give this a try and save myself a couple hundred bucks. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted March 18, 2008 Share Posted March 18, 2008 have fun, i did this last week pm me if you need any specifics Link to comment Share on other sites More sharing options...
BlackGT Posted March 27, 2008 Share Posted March 27, 2008 I need to do a clutch this weekend, where did you guys buy the TORX PLUS tool? Anybody have the size handy? FYI- I've got 45K on my 05 LGT, stage 2 since 2K. Launched maybe 50 times in its life. thanks, Jeremy Link to comment Share on other sites More sharing options...
