Deer Killer Posted March 10, 2008 Author Share Posted March 10, 2008 Well then I got a cracked piston from the factory! (edit - and so did a lot of other people) Link to comment Share on other sites More sharing options...
Guest Posted March 10, 2008 Share Posted March 10, 2008 Well then I got a cracked piston from the factory! Very possible! Very. Link to comment Share on other sites More sharing options...
rao Posted March 10, 2008 Share Posted March 10, 2008 Just keep telling yourself that everything is fine and maybe it will be....... Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Deer Killer Posted March 10, 2008 Author Share Posted March 10, 2008 Just keep telling yourself that everything is fine and maybe it will be.......No, I'm going to go do some differential equations, that will help everything! Link to comment Share on other sites More sharing options...
rao Posted March 10, 2008 Share Posted March 10, 2008 It could Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
2005garnetGT Posted March 10, 2008 Share Posted March 10, 2008 Of course engines consume oil, but that's too much. Many of Subaru 2.5L turbos consume too much oil, due to widespread defects. But it does not mean that's normal. And not NOT ALL 2.5L consume that much oil. Healthy EJ255/EJ257 will use only 0.5 quart over 6000-7000 miles, and pushing 350+ whp to the wheels. Ask edmundu. Honestly, your engine has issues, but it does not mean it will get worse or fail. However if you going to put serious power on it, chances are it will get worse. Do leak down test. mine only started leaking through my last crush washer, now its fine. my motor (it has 17k on it) never consumed a noticeable amount of oil.. Link to comment Share on other sites More sharing options...
Guest Posted March 10, 2008 Share Posted March 10, 2008 mine only started leaking through my last crush washer, now its fine. my motor (it has 17k on it) never consumed a noticeable amount of oil.. Which is how it should be. Link to comment Share on other sites More sharing options...
Guest Posted March 10, 2008 Share Posted March 10, 2008 Well then I got a cracked piston from the factory! (edit - and so did a lot of other people) Yup and so did a lot of other people. Or got them cracked due to bad gas, tuning, abuse, poor break-in. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted March 10, 2008 Share Posted March 10, 2008 No, I'm going to go do some differential equations, that will help everything! :lol: Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
2005garnetGT Posted March 10, 2008 Share Posted March 10, 2008 :lol: he sounds like my systems and materials professors.... Link to comment Share on other sites More sharing options...
Ridgeracer Posted March 11, 2008 Share Posted March 11, 2008 Unless your camera is broken you need to spend a lot more time checking out your engine and a lot less time worrying about differential equations as they relate to boost control Seriously. This is what they should look like (even thous this car has a horrible tune and barely runs ) http://www.legacygt.com/forums/showthread.php?t=71952&highlight=spark+plugs Did you steal my old plugs in my toolbox...lol "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Jim_KT Posted March 13, 2008 Share Posted March 13, 2008 Did you steal my old plugs in my toolbox...lol Same here. The original plugs that came with my car looked like that after 37k. Link to comment Share on other sites More sharing options...
