question on replacing a belt
Posted
I have to replace one of the v-belts. it's the one that goes around the generator, crank pulley and the power steering oil pump pulley. Is this a DIY job with the right tools (care of my buddy PGT):cool:
258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos
Posted
thanks!
any suggestions? like "while you are at it replace....."
  • 3 years later...
Posted
I realize this is an old thread, but I thought I'd chime in just to answer the question since this was the first thread returned when I searched.
Yes it's a DIY. In fact it's the simplest belt change I've ever done. No jack's necessary. Just a 12mm socket (preferably with a 6" extension).
Just plan to replace both belts at the same time, nothing else has to come off.
