nm Posted February 4, 2008 Share Posted February 4, 2008 Why can't the Subaru engineers design a proper head gasket, that doesn't leak? I think its a flat engine thing. VW's wasserboxers have the same issues. I suspect the watercooled porsches (with flat 6s) may show similar problems Link to comment Share on other sites More sharing options...
Gasaraki Posted February 4, 2008 Share Posted February 4, 2008 Are you telling me that my 08 Legacy will still have the head gasket problem like my 97? Jeez, I thought they would have solved it by now... Link to comment Share on other sites More sharing options...
GTTuner Posted February 4, 2008 Share Posted February 4, 2008 From what I was told (my poor, mis-informed self) it is just a "stop leak" additive to stop HG seepage. I did not use it. I change my coolant every 15k. Drain and refill the radiator. Link to comment Share on other sites More sharing options...
Opie Posted February 4, 2008 Share Posted February 4, 2008 The head gasket "problem" isn't caused by a bad design, it's caused by corrosion to the head gasket material by using coolants and additives that are not compatable with the Subaru's. If you use nothing but Subaru coolant and Subaru conditioner at the scheduled intervals it is very, very unlikely that you would ever have a head gasket issue. If you want to save $2-$3 bucks by using something else then you will have a greater risk. Link to comment Share on other sites More sharing options...
Ari_OutbackWagon Posted February 4, 2008 Author Share Posted February 4, 2008 OP here. I ended up waiting until I can pick up the conditioner at the dealer today. ...and BTW, all 2009 Subaru's (and the 2008 STi) will use a new Subaru coolant that is good for 100,000 miles. It's blue in color and does not require the conditioner...and is only available from Subaru. So, is this new coolant going to be compatible with our cars, or only MY 2009+? If so, that would great. Come to think of it the coolant I picked up from the dealer on Friday looks to be a pretty dark blueish green, even at 50%/50%. Wonder why the service guy didn't tell me I needed the conditioner, is this the new stuff? Link to comment Share on other sites More sharing options...
outahere Posted February 4, 2008 Share Posted February 4, 2008 I think its a flat engine thing. VW's wasserboxers have the same issues. I suspect the watercooled porsches (with flat 6s) may show similar problems Do you know if Porsche requires the use of a coolant additive? Link to comment Share on other sites More sharing options...
SuperCleanLGT Posted February 5, 2008 Share Posted February 5, 2008 The conditioner is mainly to treat and prolong the life of your water pump. Link to comment Share on other sites More sharing options...
Opie Posted February 5, 2008 Share Posted February 5, 2008 OP here. I ended up waiting until I can pick up the conditioner at the dealer today. So, is this new coolant going to be compatible with our cars, or only MY 2009+? If so, that would great. Come to think of it the coolant I picked up from the dealer on Friday looks to be a pretty dark blueish green, even at 50%/50%. Wonder why the service guy didn't tell me I needed the conditioner, is this the new stuff? The new stuff isn't available yet. Link to comment Share on other sites More sharing options...
Ari_OutbackWagon Posted February 6, 2008 Author Share Posted February 6, 2008 The new stuff isn't available yet. Can we use it when it comes out, or is it specific for 09+ MY? Link to comment Share on other sites More sharing options...
PhilT Posted February 6, 2008 Share Posted February 6, 2008 The conditioner is mainly to treat and prolong the life of your water pump. You didn't read the service bulletin did you ? Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
generalleeharvey Posted February 6, 2008 Share Posted February 6, 2008 I had my cooling system flushed/refilled from Monroe Muffler just before I got my head gaskets/water pump/timing belt done...It's only been about 1.5k miles since the service was performed... Is it necessary that I get my cooling system flushed/refilled in the near future with the Subaru products? Link to comment Share on other sites More sharing options...
SuperCleanLGT Posted February 6, 2008 Share Posted February 6, 2008 You didn't read the service bulletin did you ? I guess I'm about to....... Link to comment Share on other sites More sharing options...
Opie Posted February 7, 2008 Share Posted February 7, 2008 Can we use it when it comes out, or is it specific for 09+ MY? Sure can. Link to comment Share on other sites More sharing options...
spect2k Posted May 24, 2008 Share Posted May 24, 2008 Has anyone added watter wetter or royal purples 'ice' to their coolant when adding the conditioner? Any impact there? Glad to hear about the long-life coolant. My toyota uses that as well - I am surprised that subaru hasn't used it up until now. I will be using that when I am ready for a flush. Link to comment Share on other sites More sharing options...
bradlgt21 Posted October 14, 2008 Share Posted October 14, 2008 Ok so I am looking into what I need for my 30k. I have everything figured out but coolant. I stumbled across this and figured I would be safe just using the Subaru stuff. Don't want to risk any head gasket problems and it's not expensive anyway so not worries. Is this the new blue stuff you guys were talking about? http://www.5-starperformance.com/servlet/the-1033/Subaru-OEM-Antifreeze--fdsh-/Detail Does this stuff already have the additive in it? I was thinking instead of using it for "long life" just use it every 30k like a normal coolant. What do you guys think? Link to comment Share on other sites More sharing options...
franklin Posted October 14, 2008 Share Posted October 14, 2008 So is this new blue colored Subaru coolant the "best" coolant for my '05 Legacy turbo? Link to comment Share on other sites More sharing options...
exarus Posted October 15, 2008 Share Posted October 15, 2008 Ok so I am looking into what I need for my 30k. I have everything figured out but coolant. I stumbled across this and figured I would be safe just using the Subaru stuff. Don't want to risk any head gasket problems and it's not expensive anyway so not worries. Is this the new blue stuff you guys were talking about? http://www.5-starperformance.com/servlet/the-1033/Subaru-OEM-Antifreeze--fdsh-/Detail Does this stuff already have the additive in it? I was thinking instead of using it for "long life" just use it every 30k like a normal coolant. What do you guys think? That's the stuff my Subaru Service Department gave me. I asked about the additive and they said it was used in older Subaru's which had a head gasket problem, but the 2005+ Legacies don't need it. Link to comment Share on other sites More sharing options...
spect2k Posted October 15, 2008 Share Posted October 15, 2008 ^^hopefully that's accurate! Link to comment Share on other sites More sharing options...
Guest Posted October 15, 2008 Share Posted October 15, 2008 Now, Subaru wants that goo in all cars. The dealer is not following requirements. Link to comment Share on other sites More sharing options...
