NYtoVT Posted February 7, 2008 Share Posted February 7, 2008 FOUR questions: 1. What brake fluid are you using in your LGT? 2. What rotors are you using? 3. What brake lines are you using? 4. Brake Pads? next week I'll run... 1. Valvoline or ATE Super Blue (not sure yet) 2. stock (for now) 3. stock (for now) 4. Hawk HPS BTW, how much brake fluid does the 05+ LGT's hold and/ or need for a full flush? Link to comment Share on other sites More sharing options...
mcsquish Posted February 7, 2008 Share Posted February 7, 2008 1. Motul 2. DBA 4000 FR and RR 3. Techna-Fit 4. Hawk HPS Link to comment Share on other sites More sharing options...
ERLoft Posted February 8, 2008 Share Posted February 8, 2008 1. What brake fluid are you using in your LGT? - Motul RBF600 2. What rotors are you using? - Stock 3. What brake lines are you using? - StopTech stainless lines 4. Brake Pads? - Carbotech Bobcats for street, Panther XP12(F)/XP8® for track. 2013 █S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s - [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
goneskiian Posted February 12, 2008 Share Posted February 12, 2008 All stock here for now but coming up on 60k and was thinking of upgrading to stainless lines, HPS pads and of course some new fluid (may go with what the shop has on hand here as I have no intention of tracking the car anytime soon). One question though. Why does Goodridge come with 4 lines while Techna-fit have 6 lines? Yes, I'm a total brake system noob. Thanks for being kind. Link to comment Share on other sites More sharing options...
fweasel Posted February 12, 2008 Share Posted February 12, 2008 One question though. Why does Goodridge come with 4 lines while Techna-fit have 6 lines? The proper kit will have 6 lines, one for each front caliper and two for each rear caliper. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
Saul_Good Posted February 12, 2008 Share Posted February 12, 2008 1) Motul RBF600. Will switch to GS610 for the next trackday 2) Stock 3) Stock 4) Carbotech Bobcats for street/autox. Carbotech XP12 F&R for trackdays. Link to comment Share on other sites More sharing options...
magnetic1 Posted February 17, 2008 Share Posted February 17, 2008 The proper kit will have 6 lines, one for each front caliper and two for each rear caliper. Correct, Goodridge or the vendor probably looked up the wrong app. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
Waxiboy Posted February 19, 2008 Share Posted February 19, 2008 FOUR questions: 1. What brake fluid are you using in your LGT? 2. What rotors are you using? 3. What brake lines are you using? 4. Brake Pads? 1. ATE Super Blue 2. DBA slotted front; OEM rear 3. Technafit 4. Endless SSM Link to comment Share on other sites More sharing options...
Living Legacy Posted February 27, 2008 Share Posted February 27, 2008 TO answer the original post, I'm stock all around. I'm most likely going with: 1. Not sure yet...Dot 3 most likely 2. Stock 3. Goodridge 4. Stock Once the OEM pads and rotors go I'll think about upgrading them. From all the information that I've gathered so far, it's critical to NOT use synthetic as it will result in the rubber components to be broken down (according to the dealership if memory serves me right). That being said, what rubber components are in contact with the brake fluid aside from the OEM lines from the wheel well? I'm going to replace the lines so I'm not concerned about that, but I'm sure there are some gaskets/seals that might be affected. Has anyone heard of this? Motul RBF600 is synthetic and I was planning on going with this, but since the dealership suggested otherwise I might just go with a normal Dot 3 with decent boiling temps. Can someone please let me know if there is a problem with using synthetic fluid with the stock components (except for the stainless steel lines)? TIA! Link to comment Share on other sites More sharing options...
praedet Posted February 27, 2008 Share Posted February 27, 2008 Synthetic will not hurt stock components. They wanted you to buy OEM from them... Link to comment Share on other sites More sharing options...
Living Legacy Posted February 28, 2008 Share Posted February 28, 2008 Synthetic will not hurt stock components. They wanted you to buy OEM from them... Thanks, I just called the dealership and spoke to someone other than my normal service advise and he informed me that synthetic fluid was acceptable to use in our cars without damage. Sounds like I need to switch service advisers... Link to comment Share on other sites More sharing options...
q2slinger Posted March 4, 2008 Share Posted March 4, 2008 1. ATE Super Blue 2. Stock -> Stop Tech in the future... 3. Goodridge 4. Hawk HPS Very nice upgrade from stock. Link to comment Share on other sites More sharing options...
