mcchicken Posted January 24, 2005 Share Posted January 24, 2005 My seatbelt chime has been successfully disarmed 3 times now.....anyone else have to keep doing every 60 days or so? Link to comment Share on other sites More sharing options...
NonovUrbizniz Posted January 25, 2005 Author Share Posted January 25, 2005 Nope... other than the dealer resetting it; mine has stayed dis-abled through sub zero temps and over 3 months. Link to comment Share on other sites More sharing options...
YBNormal07 Posted February 21, 2006 Share Posted February 21, 2006 FYI...I played my radio for about 5 hours yesterday while rebuilding a gazebo that caved in due to some snow. Upon starting it, I could tell the battery was a bit low due to the slow starter motor rotation sound. I guess the low battery charge re-engaged my seatbelt chime. So I'm assuming if you disconnect the batter or get low on charge, you'll have to performe this exercise again. Makes sense when you think about it. Link to comment Share on other sites More sharing options...
bosco Posted February 21, 2006 Share Posted February 21, 2006 has anyone thought that when you connect the male part of the buckle to the female part that the male is completeing the circuit inside causing the chime to quit?, instead of going though all that buckling/unbuckling and still end up not working, why can't you "jump" (making it think it's connected) the inside of the female part of buckle, you would need a wiring diagram ect., bosco:icon_idea Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
YBNormal07 Posted February 22, 2006 Share Posted February 22, 2006 I thought of that, but then thought better as why risk compromising the ability of your seatbelt to latch, or come undone when you need it the most. Clicking works for me. Link to comment Share on other sites More sharing options...
bosco Posted February 22, 2006 Share Posted February 22, 2006 good thought. by taking female latch apart you could compromise the latch. there must be some way to do this with out going inside latch. it has to have a circuit to the chime. is this a NO switch?, then buckle must close it. if there is a wire from female side buckle maybe you could just ground it out, if this is a NC switch then opening it (cut wire) should stop chime. wish i had a print of circuit. thoughts? Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
skibum761 Posted February 27, 2006 Share Posted February 27, 2006 I'm guessing your replicate the process for the passenger side too? Link to comment Share on other sites More sharing options...
bosco Posted February 27, 2006 Share Posted February 27, 2006 i am asking for infro about this, i don't know if this will work or not, it just makes sense to me there has to be some kind of path to chime, something has to tell it to work, there only two things in an electrical circuit, a load ( the chime) and a switch ( buckle?), if this is the case then yes to your question, i'm going to see a friend at his body shop to see if this might work, any ideas would be great, bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
OhBe1 Posted March 2, 2006 Share Posted March 2, 2006 I'd like to agree - either cut a wire or jump two wires. But, in all likelyhood, there's a computer involved. If there's a separate load sensor to check if there's a butt already in the seat, the computer might complain if the latch switch is always indicating belted. I've had the "20 latch/unlatch" version reset for no apparant reason a couple times now. Where's that wiring diagram? And a ROM dump? 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
bosco Posted March 3, 2006 Share Posted March 3, 2006 just when i thought i was on to something, never gave load sensor a thought, that's why these forum's are here, will look into that also, body shop confirmed there must be a connector under seat, bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
OhBe1 Posted March 3, 2006 Share Posted March 3, 2006 I plan on some experimentation this weekend. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
awdcc Posted March 7, 2006 Share Posted March 7, 2006 I got the driver side to work, is there a trick for the passenger side also or is it the same, do you need to have someone in the driver and passenger side due to the sensors? Link to comment Share on other sites More sharing options...
skibum761 Posted March 7, 2006 Share Posted March 7, 2006 I got the driver side to work, is there a trick for the passenger side also or is it the same, do you need to have someone in the driver and passenger side due to the sensors? No, once you disable the driver side the passenger side is disabled also, and the airbag still works when weight is in the seat Link to comment Share on other sites More sharing options...
brad32 Posted March 8, 2006 Share Posted March 8, 2006 Just bought a 2005 GT Wagon. Thanks for the directions to turn off the chimes. They were driving me bonkers. The Accessory position won't do it, though. Gages had to be visible. Next to go...DRL. Link to comment Share on other sites More sharing options...
OhBe1 Posted March 12, 2006 Share Posted March 12, 2006 Done. Just clip the black wire.See new thread - "No chimes. Period."http://legacygt.com/forums/showthread.php?p=509419#post509419 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
Maestro Nobones Posted March 17, 2006 Share Posted March 17, 2006 took me a couple tries but I got the 20 clicks method to work. neat! Link to comment Share on other sites More sharing options...
s00baru Posted March 18, 2006 Share Posted March 18, 2006 First time worked like a charm! That thing was driving me nuts! Link to comment Share on other sites More sharing options...
dr. pepper Posted March 27, 2006 Share Posted March 27, 2006 i have tries this "trick" three times now, and it never has worked. i have an LGT 5EAT, so i need some clarification, do the gauges have to be visible for it to work? if so, what did nonov mean when he said to let the belt anchor pop out of the reciever, is that just saying to take out the clip once its in? Link to comment Share on other sites More sharing options...
dr. pepper Posted March 27, 2006 Share Posted March 27, 2006 i just tried it again, and still it just resets itself!! i am going to explain exactly what i do, and someone please tell me if im doing it wrong, i turn they key so the guages go on, plug in the belt and unplug it fully 20 times, and on the 20th time leave it in, then turn the car on, i unplug the belt, and there is no chime, so i think it worked, then i turn it off, take out the key, and when i turn it back on, the chime starts instantly, WTF?!?! Link to comment Share on other sites More sharing options...
Fallschirmjaeger Posted March 27, 2006 Share Posted March 27, 2006 If all else fails, snip one of the two, thin black wires on the piece that holds up the inboard latch of the seatbelt. You just need to peel back the plactic with a finger and use a skinny pair of scissors or snips. Probably non-undoable, but I'm not worried, I use my seatbelts religiously except for the last 20 feet pulling into my garage. Link to comment Share on other sites More sharing options...
dr. pepper Posted March 27, 2006 Share Posted March 27, 2006 is the chime supposed to ding when you first turn the car on? cuz i just tried it one more time, and it seemed to work, except for the annoying dinging at first, but then it goes off, it just seems like this should disable it completely, and it shouldn't chime six or eight times when you first turn the car on Link to comment Share on other sites More sharing options...
dr. pepper Posted March 27, 2006 Share Posted March 27, 2006 is there any way to just disable the chime itself?, it has to be somewhere under the dash panel, right? cant you just clip a wire for the speaker or w/e it is? and then youd also disable the key in door open chime, which is seriously annoying also Link to comment Share on other sites More sharing options...
OhBe1 Posted March 28, 2006 Share Posted March 28, 2006 OK, one more time.... http://legacygt.com/forums/showthread.php?t=29895 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
Scooby Fan Posted April 6, 2006 Share Posted April 6, 2006 OK.....I'm stumped....I have tried this 20 click deal about 20 different times and ways....it SIMPLY doesn't work on my car....has this been tried on '06 models? I have read the thread for hours and am sure I am doing it as it is spelled out....NO LUCK Link to comment Share on other sites More sharing options...
OhBe1 Posted April 7, 2006 Share Posted April 7, 2006 It has worked on our '06, but then resets for unknown reasons. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
