Guest Posted December 10, 2007 Share Posted December 10, 2007 I just discovered this interesting tidbit by comparing 05 FSM to 07 FSM. I did not see this mentioned here before. LGT 07+ final drive ratio is 3.90 vs. 4.11 on 05-06 LGT. What it means 07+ cars are geared taller, e.g. at 3000 rpm in 5th gear (with stock size tire) will cruise at 76.34 mph vs. 72.44 mph. Transmission gear ratios are the same, just different diffs. This applies to LGT only. OBXT final drive remains unchanged between 05-07 and is 4.44. So yet another slight difference between different MYs of our cars.... This also means that 07+ owners can just drop in 04-05 STI 6spd tranny (also 3.90), without the need to change the rear diff. Link to comment Share on other sites More sharing options...
chenc544 Posted December 10, 2007 Share Posted December 10, 2007 Are you sure it's '07+? I know '08 has the 3.9 final drive but I thought '07 still has the 4.11... Link to comment Share on other sites More sharing options...
Guest Posted December 10, 2007 Share Posted December 10, 2007 Yup, checked 07 Factory Service Manual. Link to comment Share on other sites More sharing options...
SubLo Posted December 10, 2007 Share Posted December 10, 2007 ________________________________________________ [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1980"]'05 BSM OBXT Row-your-own, W.I.P. :rolleyes:[/URL] [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1242"]'06 Shrek B # 64 - The car the wife loved to hate :( Sold...[/URL] Link to comment Share on other sites More sharing options...
chenc544 Posted December 10, 2007 Share Posted December 10, 2007 I guess Subaru Research must have it wrong, it says '07 has the 4.11. It also has the wrong final drive for '07 Spec B so I guess it's not that surprising. Link to comment Share on other sites More sharing options...
XLeezardx Posted December 10, 2007 Share Posted December 10, 2007 So what, 05 still faster than 07. =) Link to comment Share on other sites More sharing options...
sirsimon Posted December 10, 2007 Share Posted December 10, 2007 Nice - thanks for the info. Link to comment Share on other sites More sharing options...
Guest Posted December 10, 2007 Share Posted December 10, 2007 Nice - thanks for the info. Well, 2007+ SpecB is indeed also 3.90 fnal drive. Actualy the rear diff on SpecB is is 3.545, since the transmission has 1.1 reduction. 2007+ SpecB transmission is interchangeable with 2006+ STI transmission (same rear diff ratio). Link to comment Share on other sites More sharing options...
Kaos22B Posted December 10, 2007 Share Posted December 10, 2007 woot, 05' ftw. Link to comment Share on other sites More sharing options...
Yamarocket630 Posted December 14, 2007 Share Posted December 14, 2007 It's about the MPGs... 07 LGT is rated 27MPG highway, 05-06 was rated 25. CAFE FTL. Link to comment Share on other sites More sharing options...
gianspi Posted December 14, 2007 Share Posted December 14, 2007 cafe? enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
sirsimon Posted December 15, 2007 Share Posted December 15, 2007 CAFE = Corporate Average Fuel Economy Link to comment Share on other sites More sharing options...
BigBad Posted December 15, 2007 Share Posted December 15, 2007 05' more umph off the line Link to comment Share on other sites More sharing options...
diamondgraymetallic21 Posted December 16, 2007 Share Posted December 16, 2007 Fold down seats = MPG Link to comment Share on other sites More sharing options...
Vimy101 Posted December 16, 2007 Share Posted December 16, 2007 05' more umph off the line 06 Spec.B. Link to comment Share on other sites More sharing options...
sexylegacy Posted December 16, 2007 Share Posted December 16, 2007 05 wagon 5mt. Link to comment Share on other sites More sharing options...
sirsimon Posted December 16, 2007 Share Posted December 16, 2007 86 GL 4WD hatch. Dual-range 4WD 4-spd FTMFW. Link to comment Share on other sites More sharing options...
