Andreu Posted November 29, 2007 Share Posted November 29, 2007 What would you guys choose if spending 500-600 on a spring and strut set-up? I want to do anti sway and tower brace, but i also want to lower it a bit without sacraficing drivability. What would you go with. Also dont include sway bars and tower brace in that price. Link to comment Share on other sites More sharing options...
rc0032 Posted November 29, 2007 Share Posted November 29, 2007 This is the best you can do for that price http://legacygt.com/forums/showthread.php?t=75765 Link to comment Share on other sites More sharing options...
Xenonk Posted November 29, 2007 Share Posted November 29, 2007 I'd save the money and spend it on tires and a good alignment. You'll get way more performance by getting better tires. The reason behind this is that in stock class autocrossing vs modded class autocrossing is that you'll see that cars in the stock class are allowed to take advantage of the change of tires and a front sway bar only. When you compare the performance, results and times, you'll see that tires will go A LONG way. There were many comparisons when a stock class car with race tires only can do so much better than a car with struts and springs and normal street tires. The logic comes from the fact that with a stiffer suspension setup, you are only putting more emphasis on the tires. And of course, the only thing that you have contact with you and the car to the ground is the tires. So the stiffer you go, the more strain and emphasis that you tires has to be able to handle the increased weight/force transfer. Having a softer compliant suspension isn't that bad, it only means you can toss the car around more to get the weight to transfer to make use of the tires. How your tires will really determine how much grip you have. If you dont transfer enough weight over the tires, you're not going to get grip. Makes sense? Keefe Link to comment Share on other sites More sharing options...
Andreu Posted November 29, 2007 Author Share Posted November 29, 2007 I'd save the money and spend it on tires and a good alignment. You'll get way more performance by getting better tires. The reason behind this is that in stock class autocrossing vs modded class autocrossing is that you'll see that cars in the stock class are allowed to take advantage of the change of tires and a front sway bar only. When you compare the performance, results and times, you'll see that tires will go A LONG way. There were many comparisons when a stock class car with race tires only can do so much better than a car with struts and springs and normal street tires. The logic comes from the fact that with a stiffer suspension setup, you are only putting more emphasis on the tires. And of course, the only thing that you have contact with you and the car to the ground is the tires. So the stiffer you go, the more strain and emphasis that you tires has to be able to handle the increased weight/force transfer. Having a softer compliant suspension isn't that bad, it only means you can toss the car around more to get the weight to transfer to make use of the tires. How your tires will really determine how much grip you have. If you dont transfer enough weight over the tires, you're not going to get grip. Makes sense? Hey thanks, that makes me feel better. Do the potenza tires from the sti work good? Link to comment Share on other sites More sharing options...
RangerMan Posted November 30, 2007 Share Posted November 30, 2007 I just spent $550 having 4 Kumho SPTs installed out the door. HUGE improvement over stock. I have not killed a single bunny since I got them. The car's handling increased considerably. Not to mention braking and wet traction and hydroplane resistance. Very satisfied and falls right in your budget. Link to comment Share on other sites More sharing options...
whitetiger Posted November 30, 2007 Share Posted November 30, 2007 Hey thanks, that makes me feel better. Do the potenza tires from the sti work good? you can get better summer tires for the money such as the potenza RE-01R. Do you need allseason tires though since you are in ohio? Link to comment Share on other sites More sharing options...
DiscoWagon Posted December 3, 2007 Share Posted December 3, 2007 Good tires also increase braking performance! Link to comment Share on other sites More sharing options...
boostsr20 Posted December 9, 2007 Share Posted December 9, 2007 you can get better summer tires for the money such as the potenza RE-01R. Do you need allseason tires though since you are in ohio? The re-01r's are awesome tires but for the price you can't beat STI take offs. They are very similar in grip. I just got a set of like new 8/32nds for $320 shipped. Link to comment Share on other sites More sharing options...
VXCL Posted December 12, 2007 Share Posted December 12, 2007 used jdm bilstein and spring combo. monkeyhermit is selling a setup in classifieds right now. im running a $650 used jdm setup and was best bang for the $$$ for my needs. MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
wcbjr Posted December 12, 2007 Share Posted December 12, 2007 Good tires also increase braking performance! Only if your current brakes can lockup the wheels at speed. Otherwise, you need bigger/better brakes first. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
gsr94 Posted December 12, 2007 Share Posted December 12, 2007 used jdm bilstein and spring combo. monkeyhermit is selling a setup in classifieds right now. im running a $650 used jdm setup and was best bang for the $$$ for my needs. how much does the JDM set up lower the car and how's the ride? Link to comment Share on other sites More sharing options...
VXCL Posted December 13, 2007 Share Posted December 13, 2007 how much does the JDM set up lower the car and how's the ride? depends on the springs, im dropped about 1" all around on the provas, the swifts actually drop more in the front and less in the back compared to the provas so gap would look pretty even from the get go. also keep in mind im running a speb b wheel and tire setup which is 1" larger in diameter then oem re92s on 17s, so that eats up another .5" of gap. heres my setup http://www.legacygt.com/forums/showthread.php?t=67196&highlight=prova monkey has pics in his sale thread http://www.legacygt.com/forums/showthread.php?t=76498 MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
