mustang killer Posted November 17, 2007 Share Posted November 17, 2007 does any1 know the size of the MAF on the AEM CAI? i have one now, but i want to know if it would be a good idea to get a Perrin Big MAF for my new turbo. so how many mm is the AEM CAI MAF? Link to comment Share on other sites More sharing options...
johnAWD Posted November 17, 2007 Share Posted November 17, 2007 Not sure what the MAF housing diameter is on the CAI. Which turbo are you upgrading to, and how much power do you forsee making? Link to comment Share on other sites More sharing options...
mustang killer Posted November 17, 2007 Author Share Posted November 17, 2007 Not sure what the MAF housing diameter is on the CAI. Which turbo are you upgrading to, and how much power do you forsee making? SZ55, im hoping to make at least 350 whp on my 5EAT Link to comment Share on other sites More sharing options...
Infamous1 Posted November 17, 2007 Share Posted November 17, 2007 See if your shop can weld in one of these, then no need to worry about the intake. http://cgi.ebay.com/ebaymotors/Subaru-WRX-STI-Blow-Thru-MAF-Mounting-Flange-Aluminum_W0QQitemZ160129495646QQcmdZViewItem?hash=item160129495646 Link to comment Share on other sites More sharing options...
edmundu Posted November 17, 2007 Share Posted November 17, 2007 If I recall, it was virtually the same as stock....IIRC 68-69mm. THe outside diam of the AEM tube is just a over 70mm, so with 1mm wall thickness it should be about what I said. In any event, I made 350whp on it in 75-80* shop air temps, and it was pulling 4.8-4.82v, so there was room for a bit more.... Link to comment Share on other sites More sharing options...
mustang killer Posted November 17, 2007 Author Share Posted November 17, 2007 If I recall, it was virtually the same as stock....IIRC 68-69mm. THe outside diam of the AEM tube is just a over 70mm, so with 1mm wall thickness it should be about what I said. In any event, I made 350whp on it in 75-80* shop air temps, and it was pulling 4.8-4.82v, so there was room for a bit more.... hmm i think i might get a Perrin Big MAF because im shootin for at least 350 whp on a dyno dynamics + 5EAT = heartbreacker Link to comment Share on other sites More sharing options...
LittleBlueGT Posted November 17, 2007 Share Posted November 17, 2007 hmm i think i might get a Perrin Big MAF because im shootin for at least 350 whp on a dyno dynamics + 5EAT = heartbreacker That would be likely too much for the AEM. The AVO is a bit bigger, and likely easier to tune then the Perrin. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
mustang killer Posted November 17, 2007 Author Share Posted November 17, 2007 That would be likely too much for the AEM. The AVO is a bit bigger, and likely easier to tune then the Perrin. i will have to weigh my options. do the Perrin Big MAF's for the STI's work for our cars? Link to comment Share on other sites More sharing options...
GTTuner Posted November 17, 2007 Share Posted November 17, 2007 Bigger may not be better. Check with some tuners and get some opinions on that. The Typhoon has a smaller dia than others and Jon at TDC said it flowed better, you need some velocity to spin nice too. Link to comment Share on other sites More sharing options...
