isuace Posted October 28, 2007 Share Posted October 28, 2007 I installed my Koni's (with the WORX Tuning springs I got from Praedet) yesterday....and my car went from looking like this... http://i82.photobucket.com/albums/j274/isuace/carleftold.jpg http://i82.photobucket.com/albums/j274/isuace/rightside1.jpg http://i82.photobucket.com/albums/j274/isuace/carwheelwellold.jpg to this.... http://i82.photobucket.com/albums/j274/isuace/carleftnow.jpg http://i82.photobucket.com/albums/j274/isuace/carrightnow.jpg http://i82.photobucket.com/albums/j274/isuace/carwheelwellnow.jpg The spring seat (or whatever you wish to call it) on the Koni strut is definitely higher than the stock strut. Not sure what the solution to this is... or if there even should be a solution. I liked where it sat before, pretty much level all the way 'round before. Link to comment Share on other sites More sharing options...
BigBad Posted October 28, 2007 Share Posted October 28, 2007 whoa... you def have some height in the rear. The front does not look any lower that stock. Was it your orig objective to lower the front and rear with this setup? Link to comment Share on other sites More sharing options...
lucas569 Posted October 28, 2007 Share Posted October 28, 2007 wow that looks awful, id go back to the old ones... Link to comment Share on other sites More sharing options...
whobaru Posted October 28, 2007 Share Posted October 28, 2007 that's weird Link to comment Share on other sites More sharing options...
Guest Posted October 28, 2007 Share Posted October 28, 2007 Outbackized rearend Link to comment Share on other sites More sharing options...
johnAWD Posted October 28, 2007 Share Posted October 28, 2007 What the heck? Looks like a 70s era muscle car w/the back end jacked up. Link to comment Share on other sites More sharing options...
andrew.anderson Posted October 28, 2007 Share Posted October 28, 2007 That is wierd. Link to comment Share on other sites More sharing options...
VTGT Posted October 28, 2007 Share Posted October 28, 2007 Wtf Link to comment Share on other sites More sharing options...
bgLGT Posted October 28, 2007 Share Posted October 28, 2007 Weird, all the other koni installs I've seen have sat level. Did you get the wrong rear shocks sent somehow. Did you check the perch height to the OEM rears. Were those rears springs wagon specific? Link to comment Share on other sites More sharing options...
NSFW Posted October 28, 2007 Share Posted October 28, 2007 What springs did you have on it before? HTech? Pink? It looks lower than stock. Link to comment Share on other sites More sharing options...
Xenonk Posted October 28, 2007 Share Posted October 28, 2007 heh, i hope they didnt send you a set of rear Outback shocks. Keefe Link to comment Share on other sites More sharing options...
mattg Posted October 28, 2007 Share Posted October 28, 2007 not good Link to comment Share on other sites More sharing options...
isuace Posted October 28, 2007 Author Share Posted October 28, 2007 I checked the model numbers on the boxes that I got against the numbers listed on the website, and against the model numbers listed in the main Koni thread. The "before" pictures were with the same springs and oem struts. With that setup they sat pretty much level. The perch is definitely higher on the Koni's than the OEM's. I did not have to compress the springs at all to get them on the OEM struts, and I had to compress them a good bit to fit them on the Koni's. I may have to call Shox.com and see if they can lend any insight. Link to comment Share on other sites More sharing options...
pillboy Posted October 28, 2007 Share Posted October 28, 2007 Throw a couple dead bodies in the trunk. It is still ugly. Link to comment Share on other sites More sharing options...
isuace Posted October 28, 2007 Author Share Posted October 28, 2007 Can any of you other Koni owners measure from the bottom of the strut to the bottom of the spring seat/perch for me? Want to see if there is a difference in the product I got vs. what everyone else has. Link to comment Share on other sites More sharing options...
hifiandmtb Posted October 28, 2007 Share Posted October 28, 2007 No need - yours are different! Link to comment Share on other sites More sharing options...
fweasel Posted October 28, 2007 Share Posted October 28, 2007 That is definately not right, not to mention your rear alignment is probably a bit out of spec at the moment. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
NewScooby Posted October 28, 2007 Share Posted October 28, 2007 Can any of you other Koni owners measure from the bottom of the strut to the bottom of the spring seat/perch for me? Want to see if there is a difference in the product I got vs. what everyone else has. 5 7/8", from the bottom of the rear strut to the lowest point on the spring seat. Link to comment Share on other sites More sharing options...
isuace Posted October 29, 2007 Author Share Posted October 29, 2007 Where did you measure to? http://i82.photobucket.com/albums/j274/isuace/strut.jpg Link to comment Share on other sites More sharing options...
Guest Posted October 29, 2007 Share Posted October 29, 2007 You installed the seat upside down. Link to comment Share on other sites More sharing options...
NSFW Posted October 29, 2007 Share Posted October 29, 2007 http://www.arar93.dsl.pipex.com/mds975/Images/homer_simpson_doh_02.gif Link to comment Share on other sites More sharing options...
laz Posted October 29, 2007 Share Posted October 29, 2007 I found this already somewhere in the internetz! Sorry man! X --- Link to comment Share on other sites More sharing options...
Guest Posted October 29, 2007 Share Posted October 29, 2007 Btw, don't drive like this, you can break the retaining ring and suddenly go from monte carlo style to slammed to the ground style. When the seat is mounted properly it will actually "encompass" the ring so to prevent it from poping out from the grove. Link to comment Share on other sites More sharing options...
laz Posted October 29, 2007 Share Posted October 29, 2007 This could be a MasterCard commercial! ...installing your suspension components correctly on your GT -$299 on MasterCard ...Doing it incorrectly and made fun of on the internet -Priceless! Sorry! I could not help it! X --- Link to comment Share on other sites More sharing options...
-TT- Posted October 29, 2007 Share Posted October 29, 2007 this thread delivers :lol::lol::lol::lol: Link to comment Share on other sites More sharing options...
