darkstar Posted December 21, 2004 Share Posted December 21, 2004 [quote name='Xenonk']same here.. I am thinking it's the cold.. my car started harsh this morning.. my thought that I drained the battery during a cold crank just enough for the chime to reset and kick back in. Oh well, another 20 to 30 clicks to do later tonight. Keefe[/QUOTE] This sounds about right to me as well. Yesterday, -2 F outside, really harsh crank to start it up. And ding, ding, ding...... It was back.:mad: Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted December 21, 2004 Share Posted December 21, 2004 Hmmm....it was the cold that put my battery in the graveyard. You'd think they'd put something with more than 400+ cca in the car. OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
uberpollo Posted December 21, 2004 Share Posted December 21, 2004 That's some funny stuff right there. It was about 0 F on Monday morning and I'll be damned if the chime wasn't back. Link to comment Share on other sites More sharing options...
Xenonk Posted December 21, 2004 Share Posted December 21, 2004 I really think it's CCA battery issue.. it's taking a lot to turn over the engine and taking away the charge needed to keep the chime warning signal off. Did your car studdering or had a hard time cranking Monday morning at 0 F? Keefe Keefe Link to comment Share on other sites More sharing options...
spoof Posted December 22, 2004 Share Posted December 22, 2004 [quote name='kinddog']I've tried it at least 10 times... to the letter of all the instructions. NOTHING. it's enough to drive a man insane.[/QUOTE] It took me several tries. What finally worked on for me was following the tip to count each time I removed the buckle. I had previously been counting each time I inserted the buckle (I'm a guy, what can I say?). Worked the first time using that strategy. I think you just have to pick your mojo and believe....;) Link to comment Share on other sites More sharing options...
Magruder Posted December 22, 2004 Share Posted December 22, 2004 Minus 4 in Lincoln, NH this morning, and voila, the chime has chimed in and returned! Link to comment Share on other sites More sharing options...
frontrangeSubie Posted December 22, 2004 Share Posted December 22, 2004 [quote name='Xenonk']I really think it's CCA battery issue.. it's taking a lot to turn over the engine and taking away the charge needed to keep the chime warning signal off. Did your car studdering or had a hard time cranking Monday morning at 0 F? Keefe[/QUOTE] I'm tending to lean in this direction also...I think the CCA's are the issue....when you crank the starter, the code for the omit of alarm resets..... Link to comment Share on other sites More sharing options...
kb7 Posted December 22, 2004 Share Posted December 22, 2004 First thing I did when I got my GT 3 weeks ago was the 20-clicks routine to disable the chime. It was 9 degrees this morning, and the chime suddenly returned. :( Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted December 22, 2004 Share Posted December 22, 2004 Optima Red Top.....35R. Turns over on the first turn of the key...:) OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
frontrangeSubie Posted December 22, 2004 Share Posted December 22, 2004 [quote name='BoxerGT2.5']Optima Red Top.....35R. Turns over on the first turn of the key...:)[/QUOTE] Yeah...I remember you getting this battery last week....Im going to do the same (I think that is the code problem with the chime) Link to comment Share on other sites More sharing options...
dmw Posted January 17, 2006 Share Posted January 17, 2006 Worked for me after four or five tries. I was about to give up but I really don't have much to do with my time so sitting there plunging my belt in and out of the buckle for minutes on end seemed ok in a way. AND IT FINALLY WORKED. Made my weekend. Every day so far, I leave it unbuckled for a minute, just to listen to it not chirp. BTW, it does chirp 5-6 times, then stops. That is fine by me. Link to comment Share on other sites More sharing options...
jj808 Posted January 17, 2006 Share Posted January 17, 2006 Heard they changed the sequence for the 06 LGT. Its now up, up, down, down, left, right, left, right, B, A, Select, Start... Link to comment Share on other sites More sharing options...
dark_rex Posted January 17, 2006 Share Posted January 17, 2006 mine is disabled with this trick... i think it took a few attempts. dR Link to comment Share on other sites More sharing options...
MDork Posted January 17, 2006 Share Posted January 17, 2006 first try for me....best mod evAr! did you guys see the trick to disabling traction control on the new lexuseseses? makes the seatbelt trick seem easy. and you have to do it every time you start the car in the lexus. Link to comment Share on other sites More sharing options...
BDII Posted January 17, 2006 Share Posted January 17, 2006 . I like the chime for passagners who don't like seat belts because it drives them mad until they put it on. - Mike I agree. I have friends who never wear their belts and it drives me nuts, but when they get in my car they know to put it on or deal with the chime. i initially disabled it. then the stealership disconnected my battery and I have been unable to get it to turn off since. oh well Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Bretm1 Posted January 17, 2006 Share Posted January 17, 2006 I've disabled three loaner car chimes at my dealer while my car has been in (now for the fourth time) the shop. 2 Foresters and one Outback. It was difficult for me not to go and unplug the DRL's. I don't think others should have to suffer. This is not my beautiful car. Link to comment Share on other sites More sharing options...
Gire Posted January 18, 2006 Share Posted January 18, 2006 Not to 'chime' in on this old thread, but mine came back suddenly last week after probably 10 months of being disabled!! WTF? Time to pull out the cheat-sheet I made myself way back when and get it shut off~ Link to comment Share on other sites More sharing options...
rts Posted January 18, 2006 Share Posted January 18, 2006 Worked first time for me. Link to comment Share on other sites More sharing options...
jlce88 Posted January 18, 2006 Share Posted January 18, 2006 well I'll throw in my 2 cents FWIW. This worked for me: turned key on, right hand held the button to unlatch the belt and inserted the buckle for 30 seconds as rapidly as possible. At a count of 30 I turned the key off and haven't heard a chime since. I didn't count the times I did the buckle unbuckle trick, but I get no chime ever, not when I put the key in, or unbuckle while driving, ever. I was told the sensor was at the bottom of the the latch and it didn't matter if the button was held down. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 12, 2006 Share Posted August 12, 2006 Well, I flashed a new realtime map the other day and it came back on Link to comment Share on other sites More sharing options...
SLegacy99 Posted August 12, 2006 Share Posted August 12, 2006 Man I just realized I shoulda gotten a Honda chime at the junkyard yesterday. Damn. Link to comment Share on other sites More sharing options...
