f85stealth Posted October 15, 2007 Author Share Posted October 15, 2007 Read post 16 Link to comment Share on other sites More sharing options...
Guest heightsgtltd Posted October 15, 2007 Share Posted October 15, 2007 where you say that the wheels you have are stock for the spec B? Link to comment Share on other sites More sharing options...
PGT Posted October 15, 2007 Share Posted October 15, 2007 The only thing Brembo claims you need is 18" X 7.5" wheels please, show me a link where you found this info. I'd like to read up on what Brembo recommends before I change the thread title Link to comment Share on other sites More sharing options...
-TT- Posted October 15, 2007 Share Posted October 15, 2007 They come stock with the Spec B post 1 WRONG. they came with YOUR spec b. they are NOT STOCK. ibtl. this thread must die Link to comment Share on other sites More sharing options...
red beast Posted October 15, 2007 Share Posted October 15, 2007 i had 15mm spacers by h r springs http://www.hrsprings.com/ mine were 15mm. very finely made german engineering. fit perfectly. hubcentric spacers transfer the the weight to the lip on the hub. never depend on the the studs alone to take the stress. during my research at nasioc about spacers there was a small consensus that a 3mm flat spacer on a 8mm lip was the max you should use before going to full hubcentric setup. with 15mm spacers you have to change all the wheel studs. note: you never reuse a wheel stud. if you need new studs h and r sells them through a dealer. if you decide to go back to stock you must buy new subaru studs to replace the spacer studs. it's easier to change the studs on the front than the rear. the rear hubs must be removed. never bang out a stud or you'll risk damaging the bearings. my rears were damaged and took 24,000 mile to start groaning. they are expensive to fix, luckily it was "covered" under warranty. i will never do it again. Link to comment Share on other sites More sharing options...
PGT Posted October 15, 2007 Share Posted October 15, 2007 no mention at all about fitment, only dimensions, same as StopTech and everybody else. Onus is on the customer. A 23 B 110 C 192 http://www.brembo.com/CatalogoHPGT/DetailPages/Images/CaliperClearance460.gif Link to comment Share on other sites More sharing options...
meier motor sports Posted October 15, 2007 Share Posted October 15, 2007 There are a million threads here that tell you which wheels work with the Brembo BBK...and Spec B wheels aren't one of them...it's not the wheel size that's the problem...it's the wheel offset. the OP cant find the search feature any ways Link to comment Share on other sites More sharing options...
KartRacerBoy Posted October 15, 2007 Share Posted October 15, 2007 Read post 16 so you ordered them in +46mm offset and they didn't fit? Link to comment Share on other sites More sharing options...
PGT Posted October 15, 2007 Share Posted October 15, 2007 so you ordered them in +46mm offset and they didn't fit? how the hell should he know? like, duh! i stated a long while back i have the prodrive P1's what offset they are i have no idea...the car was purchased used and i have no way of knowing.. there is a way of knowing....take the damn wheel back off and look for the casting that shows offset. $10 it says 53 Link to comment Share on other sites More sharing options...
-TT- Posted October 15, 2007 Share Posted October 15, 2007 dahahahhahahhahhahhahhaha thread title FTMFW! Link to comment Share on other sites More sharing options...
Guest heightsgtltd Posted October 15, 2007 Share Posted October 15, 2007 No thank you for this entertaining thread! Link to comment Share on other sites More sharing options...
G.T.Subie Posted October 15, 2007 Share Posted October 15, 2007 Denial is your best friend Link to comment Share on other sites More sharing options...
KartRacerBoy Posted October 15, 2007 Share Posted October 15, 2007 I'm unsubscribing b4 I get a rupture. Link to comment Share on other sites More sharing options...
f85stealth Posted October 15, 2007 Author Share Posted October 15, 2007 i had 15mm spacers by h r springs http://www.hrsprings.com/ mine were 15mm. very finely made german engineering. fit perfectly. hubcentric spacers transfer the the weight to the lip on the hub. never depend on the the studs alone to take the stress. during my research at nasioc about spacers there was a small consensus that a 3mm flat spacer on a 8mm lip was the max you should use before going to full hubcentric setup. with 15mm spacers you have to change all the wheel studs. note: you never reuse a wheel stud. if you need new studs h and r sells them through a dealer. if you decide to go back to stock you must buy new subaru studs to replace the spacer studs. it's easier to change the studs on the front than the rear. the rear hubs must be removed. never bang out a stud or you'll risk damaging the bearings. my rears were damaged and took 24,000 mile to start groaning. they are expensive to fix, luckily it was "covered" under warranty. i will never do it again. Thank you for being one of the few to try and help. The 3MM should work just fine i just need to know where to get em. Link to comment Share on other sites More sharing options...
PGT Posted October 15, 2007 Share Posted October 15, 2007 why not just get the proper P1's and sell the current ones? Much better than spacers. Link to comment Share on other sites More sharing options...
f85stealth Posted October 15, 2007 Author Share Posted October 15, 2007 please, show me a link where you found this info. I'd like to read up on what Brembo recommends before I change the thread title There you go! http://www.thekingofparts.com/servlet/Detail?no=46 Link to comment Share on other sites More sharing options...
f85stealth Posted October 15, 2007 Author Share Posted October 15, 2007 After links like that can you all understand why i thought it would fit?! I'm sure you can guess where i bought them too. Link to comment Share on other sites More sharing options...
PGT Posted October 15, 2007 Share Posted October 15, 2007 There you go! http://www.thekingofparts.com/servlet/Detail?no=46 that's a vendor, not Brembo. Besides, it says 'You will need a minimum of 17x7.5" wheel to clear' - stock STI BBS wheels are 17x7.5. Brake clearance has to do with size and offset. It's a known fact that Prodrive P1's do not fit over Brembo's unless you get the STI specific fitment that only comes in crystal titanium color. due diligence and the search function is your friend, or, post a thread next time...any number of people could have directed you to the info you needed. Heck, the vendor you linked to could have probably answered your question had you asked them. Link to comment Share on other sites More sharing options...
Boxer Bob Posted October 15, 2007 Share Posted October 15, 2007 This should be quite simple to figure out what size you have, if indeed you have USDM stock Spec B rims. Turn the rim over and look on the back side of the rim spokes you will see stamped inside the spokes "Made in Japan", "18X7 JJ", "Offset 55". I have a USDM '06 Spec B with stock rims. Link to comment Share on other sites More sharing options...
f85stealth Posted October 15, 2007 Author Share Posted October 15, 2007 that's a vendor, not Brembo. Besides, it says 'You will need a minimum of 17x7.5" wheel to clear' - stock STI BBS wheels are 17x7.5. Brake clearance has to do with size and offset. It's a known fact that Prodrive P1's do not fit over Brembo's unless you get the STI specific fitment that only comes in crystal titanium color. due diligence and the search function is your friend, or, post a thread next time...any number of people could have directed you to the info you needed. Heck, the vendor you linked to could have probably answered your question had you asked them. When i seen i needed a minimum of 17x7.5 and i knew i had 18x7.5 i figured thats all there was to it, it would fit. f you never question somethign you never research it. If there was somethign more on that link about fitment i would have dug up some more facts....point still remains i need spacers where can i get em locally....all i need is like a 3MM spacer maybe 5 Link to comment Share on other sites More sharing options...
red beast Posted October 15, 2007 Share Posted October 15, 2007 Onus is on the customer. is she pretty? if so she can be on me. Link to comment Share on other sites More sharing options...
f85stealth Posted October 15, 2007 Author Share Posted October 15, 2007 Heres another thing the STi specific rims have an offset of 46mm but the regular ones have an offset of 53mm.....why would the STi ones fit if the offset is smaller? Link to comment Share on other sites More sharing options...
PGT Posted October 15, 2007 Share Posted October 15, 2007 When i seen i needed a minimum of 17x7.5 and i knew i had 18x7.5 i figured thats all there was to it, it would fit. f you never question somethign you never research it. If there was somethign more on that link about fitment i would have dug up some more facts....point still remains i need spacers where can i get em locally....all i need is like a 3MM spacer maybe 5 you are in Tampa with Mastro there and you want to know where to buy spacers? did you ask King of Parts about fitment or did you assume your wheels would work? You thought you had stock Spec B wheels which are 18x7 Link to comment Share on other sites More sharing options...
Guest heightsgtltd Posted October 15, 2007 Share Posted October 15, 2007 No, he thought he had stock Spec B wheels that were 18X7.5 Link to comment Share on other sites More sharing options...
f85stealth Posted October 15, 2007 Author Share Posted October 15, 2007 you are in Tampa with Mastro there and you want to know where to buy spacers? did you ask King of Parts about fitment or did you assume your wheels would work? You thought you had stock Spec B wheels which are 18x7 Mastro would have em? No i didnt ask king of parts because of that statement all i needed was a 17X7.5.....i thought i had stock spec B wheels but i knew the wheels i had were 18 x 7.5 Link to comment Share on other sites More sharing options...
