dan_is_key Posted October 22, 2007 Share Posted October 22, 2007 wow that looks really stealthy on that 08, I'll be posting pics of mine very soon Link to comment Share on other sites More sharing options...
ddavis Posted October 29, 2007 Share Posted October 29, 2007 Thanks for the pics man, it made today go alot easier. Oh and I had similar problems, bolts not being right, alottt of trimming, and beat up goods. Although wbc taped all the bolts into there proper brackets for me which made life a lil easier. (Crappie pic in the dark, but its bad together ) http://www.ddavisart.com/fmic.jpg Link to comment Share on other sites More sharing options...
GTTuner Posted October 29, 2007 Share Posted October 29, 2007 It looks like my Typhoon and heat shield will bet hitting the dumpster with one of these FMIC kits????? BTW, nice job guys. Link to comment Share on other sites More sharing options...
J-Cobb Posted January 11, 2008 Share Posted January 11, 2008 Nice work! Question 1: Are you still using your stock turbo with the WBR kit? Question 2: Assuming you have an COBB AP2 did you need a new map? Question 3: What differences have YOU felt since the install of the FMIC? WBR VS. PERRIN VS. AVO ? which one is the best bang for buck and ease of installation? Link to comment Share on other sites More sharing options...
ddavis Posted January 11, 2008 Share Posted January 11, 2008 1) Fmic wouldnt make much sense on a stock turbo, but you can do it. 2)You dont need a new map, but most gains will come from a tune with it. 3)I thought the kit was a good fmic kit for the money. Installation wasnt that bad, but it not a direct bolt on and plan to run to the autoparts store a couple of times during the install. I think any fmic you go with will give you trouble installing. Link to comment Share on other sites More sharing options...
Brad023 Posted January 2, 2009 Share Posted January 2, 2009 just got the wbr fmic can any one tell what to get before tackleing the job monday. hints, or tips are greatly appreciated. Link to comment Share on other sites More sharing options...
PeterJMC Posted January 2, 2009 Share Posted January 2, 2009 Link to comment Share on other sites More sharing options...
ddavis Posted January 2, 2009 Share Posted January 2, 2009 It depends what all wbr includes now. This guide was pretty good to me when I was installing it. A few extra things I remember needing was a dremel for cutting with some extra cutting blades for it, extra bolts, coolant, extra coolant hose, t fitting, and some rubber caps to plug the coolant line when you reroute it. I just remember running back and fourth a handful of times so you want to have a spare car around when your doing the install. Link to comment Share on other sites More sharing options...
j255c Posted January 2, 2009 Share Posted January 2, 2009 if you want the fmic to sit flush | | and not like this | \ you will need to cut some of the subframe with a dremel. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
abakja1 Posted January 2, 2009 Share Posted January 2, 2009 Tru dat below VV,... I didnt have to cut any of the subframe except to cut the driver side edge by the headlight(? forgot) but this was shown in the instruction pics.... and using a dremel with the cutoff sawblade IS the tool to use to cut your bumper,...Do get the rubber end caps for your coolant lines and plastic,..better yet, metal Ts to reroute your coolant lines to overflow tank..I personally didnt like the round one included in the kit, so I went to parts store and bought another overflow tank for <$8....The one in the kit I dont think holds enough and overflowed alot.... There are a few more threads with installs and pics on this forum too,...I did one... It depends what all wbr includes now. This guide was pretty good to me when I was installing it. A few extra things I remember needing was a dremel for cutting with some extra cutting blades for it, extra bolts, coolant, extra coolant hose, t fitting, and some rubber caps to plug the coolant line when you reroute it. I just remember running back and fourth a handful of times so you want to have a spare car around when your doing the install. Link to comment Share on other sites More sharing options...
PeterJMC Posted January 2, 2009 Share Posted January 2, 2009 ... There are a few more threads with installs and pics on this forum too,...I did one... http://legacygt.com/forums/showthread.php?t=72118 Link to comment Share on other sites More sharing options...
mwiener2 Posted January 4, 2009 Author Share Posted January 4, 2009 The one in the kit I dont think holds enough and overflowed alot.... I ended getting another tank too. mine overflowed anytime I got the engine nice and hot. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Brad023 Posted January 5, 2009 Share Posted January 5, 2009 bought a used wbr fmic and need the piece to bolt it to a legacy style turbo does any one have one that they aren't useing or no if wbr sells them seperatly Link to comment Share on other sites More sharing options...
mwiener2 Posted January 6, 2009 Author Share Posted January 6, 2009 i should have mine.. i'll try to remember to look for it My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Brad023 Posted January 6, 2009 Share Posted January 6, 2009 thanks but i allready bought one from wbr performance lol can't wait to put it on. Link to comment Share on other sites More sharing options...
CTATV Posted February 19, 2009 Share Posted February 19, 2009 Subscribed for futurereference Link to comment Share on other sites More sharing options...
Guest adam07specB Posted June 16, 2009 Share Posted June 16, 2009 Bump for this sweet ass walkthrough... I did mine last saturday and had my laptop open to this the whole time for guidance.... Thanks for a good Job!!! I will post some pics of mine Link to comment Share on other sites More sharing options...
Guest adam07specB Posted June 16, 2009 Share Posted June 16, 2009 Pics of mine http://i291.photobucket.com/albums/ll306/adam07specb/IMG_1629.jpg http://i291.photobucket.com/albums/ll306/adam07specb/IMG_1634.jpg http://i291.photobucket.com/albums/ll306/adam07specb/IMG_1636.jpg http://i291.photobucket.com/albums/ll306/adam07specb/IMG_1637.jpg Link to comment Share on other sites More sharing options...
enthusiast Posted June 16, 2009 Share Posted June 16, 2009 Man those pipes really look stealthy. Good job on the install. Now clean the rest of your engine bay! My mod list Link to comment Share on other sites More sharing options...
Guest adam07specB Posted June 16, 2009 Share Posted June 16, 2009 Man those pipes really look stealthy. Good job on the install. Now clean the rest of your engine bay! yeah yeah yeah.... thanks again Link to comment Share on other sites More sharing options...
Ghostride Posted October 19, 2009 Share Posted October 19, 2009 can any one tell me what size the coupling from the throttle body to BOV piping is? I bought it used and it's missing some parts. I'm guessing it's a 3" to 2.5" straight reducing coupling. Thanks for your help. Link to comment Share on other sites More sharing options...
Darkness of Death Posted October 19, 2009 Share Posted October 19, 2009 the piping for the wbr is 2.75". not sure about the throttle body though Link to comment Share on other sites More sharing options...
Ghostride Posted November 2, 2009 Share Posted November 2, 2009 Thanks to this install thread, it was a life saver this weekend. Some friends and I installed this kit that I bought used. Some things may look different because I'm not sure I had all the correct parts, but we adapted and made things work. Link to comment Share on other sites More sharing options...
