spyguy Posted July 8, 2008 Share Posted July 8, 2008 It depends on how you wire them. Most people (myself included) have them set to white during the day, and then transition to amber/red when the headlights are on. There are 3 wires behind the gauge, red 12+, orange 12+ and ground. Ground is obviously always grounded, but with the red wire powered the gauge is white, with both the red and the orange powered, the gauge is orange. (i might have my colors messed up, but you get the point) When you put your gauges in the cubby possition it's convenient because the cubby has a light that turns on when the headlights are turned on. Tap it for your orange wire, and bam - white without headlights on, amber with them turned on. FYI: I used white at night time for the first little while and found it to be a little too brite for night driving. so smart, thats what i'm going to do. Link to comment Share on other sites More sharing options...
CapeStylz Posted July 9, 2008 Share Posted July 9, 2008 i have farmerjohns guages soon to be upgraded http://i275.photobucket.com/albums/jj315/CapeStylz/05%20lgt/gauges201.jpg Link to comment Share on other sites More sharing options...
fishbone Posted July 9, 2008 Share Posted July 9, 2008 ^ Very nice. So guys, the Prosport non-premium, just the electrical gauges, do they come with any mounting hardware? How do they look on the back, are they covered or do they have wires and such hangin' out. Link to comment Share on other sites More sharing options...
TSiWRX Posted July 9, 2008 Share Posted July 9, 2008 Update - Although I still do not recommend the AutoMeter NEXUS gauges (based on cost-effectiveness, given today's market availability), I just wanted to put in that with reflash of their latest firmware, the first-generation models (which I own, and have reported "issues" with) have become *much* more reliable, in terms of the "connection drop-outs" that I've spoken of earlier. Additionally, I've also reflashed to enable the "STi start/shut-off sequence," as a NASIOCer did for his, using his code, and must say that the start-up and shut-down sequences are now much more visually appealing than what they'd been, previously, on an aesthetic level. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
lossol Posted July 12, 2008 Share Posted July 12, 2008 http://www.gtboostgauge.com/GTBoost%20and%20radio.jpg Boost gauge under the trip computer. Its called GTBoost - More info here or here www.gtboostgauge.com VBG1 gauges available at www.gtboostgauge.com Link to comment Share on other sites More sharing options...
CypherMax Posted July 12, 2008 Share Posted July 12, 2008 heres mine i dont know the exact model and brand im pretty sure its an spt part. i got it as an option when i bought the car. in my opinion one of the nicest gauge sets out there. Link to comment Share on other sites More sharing options...
16psibrick Posted July 12, 2008 Share Posted July 12, 2008 http://simplicity.elitecaraudio.org/leg7.JPG Link to comment Share on other sites More sharing options...
DoubleM Posted July 13, 2008 Share Posted July 13, 2008 I posted this somewhere before, but here goes. It's an omori 45mm mechanical boost gauge. http://img.photobucket.com/albums/v463/subaruwrxfan/Spec%20B/DSC00963.jpg Link to comment Share on other sites More sharing options...
mars_volta Posted August 1, 2008 Share Posted August 1, 2008 heres mine. http://www.sixthsphere.com/storage2/images/louk96e9g4hx0rsfnxj.jpg Link to comment Share on other sites More sharing options...
SBT Posted August 1, 2008 Share Posted August 1, 2008 heres mine i dont know the exact model and brand im pretty sure its an spt part. i got it as an option when i bought the car. in my opinion one of the nicest gauge sets out there. This is the same set that I have. It is actually labelled as an STI part (at least mine is) and is about $800/shipped. Unless you do it yourself, it's another $100 for install. Agree that it is a nice gauge set and the opening ceremony nicely matches the factory dash gauge's. My only complaint is that it is not backlit like the instrument cluster so you have to have the lights on in order for its lights to be on and you have to convert (in your mind) the pressures and temp as it's not SAE. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Mr. Ed Posted August 5, 2008 Share Posted August 5, 2008 i almost went this route but the gauges supplied were not what I wanted (egt/afr/boost) so I have ordered prosport gauges and I am attempting a diy guage panel in the cubby... pics to come This is the same set that I have. It is actually labelled as an STI part (at least mine is) and is about $800/shipped. Unless you do it yourself, it's another $100 for install. Agree that it is a nice gauge set and the opening ceremony nicely matches the factory dash gauge's. My only complaint is that it is not backlit like the instrument cluster so you have to have the lights on in order for its lights to be on and you have to convert (in your mind) the pressures and temp as it's not SAE. Link to comment Share on other sites More sharing options...
SBT Posted August 6, 2008 Share Posted August 6, 2008 ^^ Cool - will look forward to the finished product. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
iNVAR Posted September 28, 2008 Share Posted September 28, 2008 *bump* just installed mine in a cubbypod a few days ago. Defi Racer, boost and oil pressure gauges. Link to comment Share on other sites More sharing options...
Siper2 Posted September 28, 2008 Share Posted September 28, 2008 My only complaint is that it is not backlit like the instrument cluster so you have to have the lights on in order for its lights to be on and you have to convert (in your mind) the pressures and temp as it's not SAE. For a second I thought you meant that it wasn't lit at ALL, even when the lights were on. Whew.... I really want to get the STi pod, love it. I had the RS Performance Gauge pack, I really liked how it was, too. (Took this when I was comparing the Kartboy and OEM shift knobs, but it got the gauges. ) http://img.photobucket.com/albums/v396/Siper2/DSC02818.jpg I ended up moving it below the radio in my '00 RS (sold last Wednesday ), since I also picked up an OEM Forester compass pack to put on top. http://img.photobucket.com/albums/v396/Siper2/Subaru%20Impreza/STi-V6-interior--andSnake016.jpg Anyway, yeah I like OEM gauges I guess. My issue with MOST aftermarket ones is that the fitment stinks. So I'm planning on the STi triple-gauge for my new '05 GT. Link to comment Share on other sites More sharing options...
RaGe Posted November 17, 2008 Share Posted November 17, 2008 installed are the STRI-Xline and innovate DB wideband. In the center cubby are the 60mm boost, and 60mm EGT. Installed on the A-pillar are the 52mm oil pressure and the wideband. http://i72.photobucket.com/albums/i171/Crucifix79/cubby%20pod/gauge096-1.jpg http://i72.photobucket.com/albums/i171/Crucifix79/cubby%20pod/gauge098.jpg OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
g2redgsr Posted November 20, 2008 Share Posted November 20, 2008 installed are the STRI-Xline and innovate DB wideband. In the center cubby are the 60mm boost, and 60mm EGT. Installed on the A-pillar are the 52mm oil pressure and the wideband. http://i72.photobucket.com/albums/i171/Crucifix79/cubby%20pod/gauge096-1.jpg http://i72.photobucket.com/albums/i171/Crucifix79/cubby%20pod/gauge098.jpg where did you get the two on the column and the pod? thats what i want Link to comment Share on other sites More sharing options...
RaGe Posted November 20, 2008 Share Posted November 20, 2008 gauges were purchased from ravspec. A vendor from this site. http://legacygt.com/forums/showthread.php?t=57417&highlight=stri the cubby pod was picked up from casopolis. I dont know if he is still making them or not though. http://legacygt.com/forums/showthread.php?t=87534 A-pillar pod was picked up from a member on here as well. http://legacygt.com/forums/showthread.php?t=95724&highlight=pillar+pod OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
Siper2 Posted November 24, 2008 Share Posted November 24, 2008 Jeez, RaGe, how cold was it, when you took that pic? 80 degrees on your climate control? I'd roast!!! Link to comment Share on other sites More sharing options...
SBT Posted November 24, 2008 Share Posted November 24, 2008 ^ It was so cold that the temp gauge malfunctioned and indicated 80 degrees;) - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Siper2 Posted November 24, 2008 Share Posted November 24, 2008 Yeah. Yeah that's it. Kind of like how they estimate that you'd gain weight if you were able to time travel. Yyyyyyyyeah....... Link to comment Share on other sites More sharing options...
RaGe Posted November 24, 2008 Share Posted November 24, 2008 the panel shows 36F, btu with the wind chill it was a tad bit colder. we have been having single digit temps here the last few days. OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
g2redgsr Posted November 25, 2008 Share Posted November 25, 2008 http://simplicity.elitecaraudio.org/leg7.JPG this looks like the route i may go, so its out of the way and near all the other gauges...how are they connected there though? and are those hose clamps? Link to comment Share on other sites More sharing options...
GoRilla Posted January 28, 2009 Share Posted January 28, 2009 Bump, The options for gauge mounting really sucks for us legacy guys, especially if you have the nav, I'm stuck on what to do? I need two gauges. Maryland's Suby friendly Realtor. My favorite suby shop: http://www.IAGPerformance.com Link to comment Share on other sites More sharing options...
GoRilla Posted January 28, 2009 Share Posted January 28, 2009 http://i75.photobucket.com/albums/i299/2fuzzy2/02.jpg http://i75.photobucket.com/albums/i299/2fuzzy2/DSC02898.jpg http://i75.photobucket.com/albums/i299/2fuzzy2/DSC02406.jpg http://i75.photobucket.com/albums/i299/2fuzzy2/DSC02897.jpg Does anyone know what gauge pod this is or if they make one for 2 gauges? Maryland's Suby friendly Realtor. My favorite suby shop: http://www.IAGPerformance.com Link to comment Share on other sites More sharing options...
bdickey058 Posted January 29, 2009 Share Posted January 29, 2009 what pod will work with the AEM True boost gauge Link to comment Share on other sites More sharing options...
