serra010 Posted September 11, 2007 Share Posted September 11, 2007 Today may have been the worst day of my life... i drove to class in my 05gt and after my 2 classes were done i went back to my car, parked in a parking garage with a 7'8" clearance and it wouldnt start, it made a clickin noise and that was it...so about an hour later i went back and tried to get stuff out of my car and it had no power at all to it, now i would have them tow my car to the dealership cuz its still under warrenty but they tow cant fit in the garage and they can move it but any damage, i would have to cover it...so im hoping if i change the battery i may have some luck.... worst part about it.. i have no idea how to change it ..so please if someone can go from start to finish on how to take out the battery and put it back in please do........ ITD HELP ME OUT SO MUCH..thank you very much Link to comment Share on other sites More sharing options...
rao Posted September 11, 2007 Share Posted September 11, 2007 A much easier thing to do would be to jump start your car 1. Take the hold down off. 2. disconnect the NEGATIVE cable - it is the black one NOT THE RED ONE 3. disconnect the POSITIVE cable - it is the red one 4. Remove the battery 5. Put the new battery in; make sure that the POSITIVE AND NEGATIVE terminals are orientated the same way that the old one was. 6. Connect the POSITIVE cable - it is the red one 7. Connect the NEGATIVE cable - it is the black one 8. Have your keyfob handy because your alarm will likely go nuts, press the unlock button if it does. 9. Put the hold on back on. You need a 10 mm socket and wrench to do all of this. Make sure you do not touch anything gains the positive and negative terminals at the same time. Keep in m ind that if this is the worst day of your life you are in really good shape Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
pillboy Posted September 12, 2007 Share Posted September 12, 2007 How long does Subaru Roadside Assistance last? It is still ugly. Link to comment Share on other sites More sharing options...
hondas123 Posted September 12, 2007 Share Posted September 12, 2007 As Rao suggested......JUMP START IT!!!! http://www.ehow.com/how_511_jump-start-car.html - The Mortgage Man Link to comment Share on other sites More sharing options...
icrackedcorn Posted September 23, 2007 Share Posted September 23, 2007 jump it failing that (assuming you parked ground level) push it out in neutral and meet the tow outside obedience to church and state is subjugation to the unjust authority of men Link to comment Share on other sites More sharing options...
hondas123 Posted September 24, 2007 Share Posted September 24, 2007 ^^^ This was thirteen days ago. I hope he's not still trying to start it. - The Mortgage Man Link to comment Share on other sites More sharing options...
RaGe Posted September 25, 2007 Share Posted September 25, 2007 if he is something is wrong huh? OTM. Sorry I didn't mean to start a war which mainly forum people is all about . Link to comment Share on other sites More sharing options...
2006Specb122 Posted January 12, 2008 Share Posted January 12, 2008 How long does Subaru Roadside Assistance last? I was wondering the same thing... bump bump.... Link to comment Share on other sites More sharing options...
ToRealEyes Posted July 17, 2008 Share Posted July 17, 2008 I was wondering the same thing... bump bump.... If i recall, it usually lasts for the same duration as your basic bumper-bumper warranty. Mine lasted 2.5 years. 36000 miles, hello! I'm pretty sure they'll still help you out, but you'll be looking at a pretty big bill if you're not covered. Link to comment Share on other sites More sharing options...
ToRealEyes Posted July 17, 2008 Share Posted July 17, 2008 1. Take the hold down off. 2. disconnect the NEGATIVE cable - it is the black one NOT THE RED ONE 3. disconnect the POSITIVE cable - it is the red one 4. Remove the battery 5. Put the new battery in; make sure that the POSITIVE AND NEGATIVE terminals are orientated the same way that the old one was. 6. Connect the POSITIVE cable - it is the red one 7. Connect the NEGATIVE cable - it is the black one 8. Have your keyfob handy because your alarm will likely go nuts, press the unlock button if it does. 9. Put the hold on back on. Thanks for this post Rao! I just successfully changed out the battery for a diehard gold south (Sears is two blocks away). I would have been scared shitless if I didn't have your forewarning about the alarm going nuts. Link to comment Share on other sites More sharing options...
Grios2.5 Posted July 17, 2008 Share Posted July 17, 2008 wow this is the funniest thing ive seen today LOL Link to comment Share on other sites More sharing options...
at25 Posted August 19, 2008 Share Posted August 19, 2008 well, that could also be called the funniest post ever )) hope Serra010 eventually found the way out.. Link to comment Share on other sites More sharing options...
taskforcefreddy Posted August 19, 2008 Share Posted August 19, 2008 I've said it all along... the last thing college makes you is smart. Link to comment Share on other sites More sharing options...
