DogLeggGT Posted August 29, 2007 Share Posted August 29, 2007 So, I'm driving to Lowes earlier today and all of a sudden my car sounds like a racer with the performance of a horse and buggy. It sounds like there's a massive exhaust leak and it happened all at once. I limped home without any discernable turbo whatsoever. I called Cobb and quizzed the guy about what might have happened since my check engine light had been on and cruise control light flashing for a couple days and simply hadn't had the chance to make the call. After a lot of head scratching, and listening to my car over the phone, he suggested that I should check the O2 sensor in the header, right behind the passenger side front wheel well. Sure enough I get on my back and there's the sensor hanging on by its wires, looking like the threads were stripped! I take the car to the dealership adn they confirm that the O2 sensor was blown right out of the header bung. Threads not stripped, but ROLLED OVER like it was shot out of a cannon. So we order a new ($$$) O2 sensor and she'll be installed tomorrow. I called Perrin and the guy in tech suggested that when the sensor was removed from the OEM bung and threaded into the Perrin bung the threads were damaged, effectivly leaving less thread-mass to thread into the bung, hence weakened threads, hence the resultent projectile O2 sensor. Anyone heard of this happening before? Link to comment Share on other sites More sharing options...
rao Posted August 29, 2007 Share Posted August 29, 2007 Headers are always fun on turbo Subarus. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
DogLeggGT Posted August 30, 2007 Author Share Posted August 30, 2007 hmmm, hopefully this header has no more fun and games. any suggestions on how to keep the O2 sensor in the bung without loc titeing it for all eternity? Link to comment Share on other sites More sharing options...
rao Posted August 30, 2007 Share Posted August 30, 2007 The real solution is to take the headers and throw them in the garbage can. Other than that, try a new O2 sensor and hope for the best. Do not use loctite or anything like that. The sensor will have anti-seize on it and just tighten it to the normal spec. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
urfsin Posted August 30, 2007 Share Posted August 30, 2007 I have Perrin headers and they are great. Granted I only have about 12,000 miles on them. I did buy them used though, so I figure there are about 20,000 miles on them total. I drive my car hard and I race in Rally X and Auto X. Zero problems so far. Slide It Sideways Link to comment Share on other sites More sharing options...
qikslvr Posted August 30, 2007 Share Posted August 30, 2007 Sounds like someone either cross threaded it or over tightened it IMO. I'd make sure to clean the threads by running the correct size tap down it before putting the new sensor in just to be sure that any thread left over from the old sensor is gone. Let's kick this pig! Link to comment Share on other sites More sharing options...
Boostjunkie Posted August 30, 2007 Share Posted August 30, 2007 While shooting the O2 sensor out of the manifold/header is a bit unusual, having the threads getting buggered up removing and reinstalling it is not that odd. That would certainly explain it coming loose. IIRC, BOXRPWR had his O2 sensor shoot out of his stock manifolds a while back, so this is not an issue with headers per se. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted August 30, 2007 Share Posted August 30, 2007 The real solution is to take the headers and throw them in the garbage can. That would be wrong! Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
DogLeggGT Posted August 30, 2007 Author Share Posted August 30, 2007 Sounds like someone either cross threaded it or over tightened it IMO. I'd make sure to clean the threads by running the correct size tap down it before putting the new sensor in just to be sure that any thread left over from the old sensor is gone. yah, thanks for the suggestions. this is just what the guy from Perrin mentioned to me. make sure to take a look at the threads in the bung and put on the proper amount of antisieze. Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted August 30, 2007 Share Posted August 30, 2007 Atleast they didn't assplode. OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
DogLeggGT Posted August 30, 2007 Author Share Posted August 30, 2007 it was more like the car all of a sudden had a huge case of mud butt Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted August 30, 2007 Share Posted August 30, 2007 it was more like the car all of a sudden had a huge case of mud butt I know the feeling all to well. OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
