Canon20D Posted August 29, 2007 Share Posted August 29, 2007 I was trying to figure out a way to go the Hogzaust, cause my bolts are really rusty. So i loosened the midpipe bolts (the ones with the springs) and man, that thing makes it sound Crazy awesome from idle up to about 4K. after that it sounds pretty bad, but it sounds great till then! Ill have to take a vid tomorrow... Im wondering if anyone knows a way to add some spacers to that area, so it lets out some volume, but not making my car sound like pee after 4K rpm. The way I was looking at it, they bolts dont work the way they would on the end of the y pipe like the hogzaust does. Link to comment Share on other sites More sharing options...
meier motor sports Posted August 29, 2007 Share Posted August 29, 2007 the mid pipe is regular bolts. the down pipe to the cat back is the one with springs [ame=http://www.youtube.com/watch?v=K2qxDWfdKTQ]YouTube - fly bye[/ame] open down pipe. catless Link to comment Share on other sites More sharing options...
Xenonk Posted August 29, 2007 Share Posted August 29, 2007 I was trying to figure out a way to go the Hogzaust, cause my bolts are really rusty. So i loosened the midpipe bolts (the ones with the springs) and man, that thing makes it sound Crazy awesome from idle up to about 4K. after that it sounds pretty bad, but it sounds great till then! Ill have to take a vid tomorrow... welcome to my world, just unbolt the WHOLE thing off. Dont even bother with spacers.. if you want less of the rattling noise, just add a 2' x 2.5" pipe extension off the cat, and you'll have one nice sounding car. My car sounds just fine for having a straight 4' section that terminates just behind the rear axle and I used my mid-pipe hanger as my final hanger to keep my 4' extension from hanging low due to the sheer weight. You should see how it sounds if you had a full catless system from the turbo and run a short dump (run an open downpipe and have a final turn-down pipe to keep the flames off the car. I have pics floating around here with my $40 custom catback exhaust ($20 worth of pipe, a welded hanger, and a slip-on flange to bolt up to the cat).. all legal for the race class I run my car in, and I saved over 40 lbs by doing it. My next step will be an upgrade to a new downpipe (catless) with a 3.5" dia exit pipe instead of the 2.5" I run now.. it's going to be LOUD. Couple that with a stage 2 map, I expect a 50 whp/60 ft.lbs. gain easy. Keefe Link to comment Share on other sites More sharing options...
rao Posted August 29, 2007 Share Posted August 29, 2007 Exhaust systems are overrated. However, be sure to ground your downpipe or the exhaust will get confused Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Xenonk Posted August 29, 2007 Share Posted August 29, 2007 Exhaust systems are overrated. However, be sure to ground your downpipe or the exhaust will get confused So for me, no exhaust = no grounding needed Keefe Link to comment Share on other sites More sharing options...
Canon20D Posted August 29, 2007 Author Share Posted August 29, 2007 http://www.imagingphototech.com/scoobie1.mpg http://www.imagingphototech.com/scoobie2.mpg http://www.imagingphototech.com/scoobie3.mpg <- Big (23Mb) Link to comment Share on other sites More sharing options...
meier motor sports Posted August 29, 2007 Share Posted August 29, 2007 leme guess you dont know about the fan really recall? vid 3 first second or so Link to comment Share on other sites More sharing options...
Canon20D Posted August 29, 2007 Author Share Posted August 29, 2007 ^^ oh i know about it and I went to subaru to have it fixed. They needed to order parts like 3 weeks ago I need to harrass them about it Link to comment Share on other sites More sharing options...
meier motor sports Posted August 29, 2007 Share Posted August 29, 2007 oh ok. cause when i first heard your fans kick on at high speed when u started the car i thought to myself "HEYYYYYYYYYYYY" Link to comment Share on other sites More sharing options...
Canon20D Posted August 29, 2007 Author Share Posted August 29, 2007 Lol I just re-did this with spacers (2 3/8" washers... wow, sounds just as loud! Hmm Ill have to try with just 1, or take em out all together, not sure right now.. ill update later! Link to comment Share on other sites More sharing options...
meier motor sports Posted August 29, 2007 Share Posted August 29, 2007 a space there is going to be loud no mater what. not really comparable to the hogzaust. just the way things work Link to comment Share on other sites More sharing options...
Canon20D Posted August 30, 2007 Author Share Posted August 30, 2007 Under hard accell - the exhaust spit out my washers.. sounds stock again Link to comment Share on other sites More sharing options...
meier motor sports Posted August 30, 2007 Share Posted August 30, 2007 Lol Link to comment Share on other sites More sharing options...
