Mr_Dean Posted July 27, 2007 Share Posted July 27, 2007 Hello all, I've been trying to research different ways to increase my fuel efficiency. I'm considering buying an accessport2 from cobbstuning: http://www.cobbtuning.com/products/?id=2436 I understand that you can do on the fly map switching from performance to fuel efficiency maps. Does anyone know first-hand what kind of mileage I would realistically get with the fuel efficiency ECU map of the accessport2? I currently get ~18mpg city and ~23mpg freeway. Thanks, Dean Link to comment Share on other sites More sharing options...
dbrunone Posted July 27, 2007 Share Posted July 27, 2007 Most people report a 2-3mpg highway increase with the AP. But remember, your highest performance map will also be your most fuel efficient map, as long as you stay off the throttle. So if you get the AP (a more efficient tune), and you accelerate the same way, you'll get higher mileage, even with a "performance" map. Link to comment Share on other sites More sharing options...
gianspi Posted July 28, 2007 Share Posted July 28, 2007 The negligible increase in fuel economy will never justify the $700 product to get there. enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
gianspi Posted July 28, 2007 Share Posted July 28, 2007 If you drive 12,000 miles per year, it would take 5.7 years to break even financially with the $700 AP (based on +2 mpg and $3/gal). enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
Impulse Posted July 28, 2007 Share Posted July 28, 2007 fyi, most people who get the accessport loose fuel economy. why? too much fun ;] i get the same amount of fuel consumption 21city/28hwy with the AP as i did when i didnt, but i can accelerates MUCH faster now Link to comment Share on other sites More sharing options...
rocknroll Posted July 28, 2007 Share Posted July 28, 2007 Cobb's economy map does increase mpg in highway driving, but I found that it does nothing for city driving. Besides which the lack of boost (it limits to 7-8psi) becomes an annoyance after a while. Link to comment Share on other sites More sharing options...
SLegacy99 Posted July 29, 2007 Share Posted July 29, 2007 Get your self a drop in K & N air filter. Boosted me up from 29 mpg hwy to 32. They do cost a little more than a normal air filter, but you dont have to replace them for a million miles. Link to comment Share on other sites More sharing options...
Mr_Dean Posted July 30, 2007 Author Share Posted July 30, 2007 Hey All, Thanks for all the thought provoking responses. I think you've really convinced me to look at a "Stage 1" tune with accessport2 as more of a performance rather than fuel savings change when considering its purchase. One last question would be... I've heard when your car is tuned for gas savings or your running an "economy" mapping that your engine runs hotter so you shouldn't push it very hard. Is that true? I would think that a gas-savings type tuning would mainly be limiting the amount of fuel injected into the engine. How can a higher oxygen to fuel ratio make the engine run hotter? Thanks, Dean Link to comment Share on other sites More sharing options...
captainmorgan Posted July 30, 2007 Share Posted July 30, 2007 Your dealer actually has an option. Just take your car there and trade it for 2.5i or better yet, a Honda or something. But seriously, stay off the gas and you're usually fine. You can tune to lean out your ST and LT fuel trims, but that can be dangerous. Also an intake will lean your mixture out, though again, can be dangerous if you start pushing it (EGT's go way up). Link to comment Share on other sites More sharing options...
rocknroll Posted July 30, 2007 Share Posted July 30, 2007 Hey All, Thanks for all the thought provoking responses. I think you've really convinced me to look at a "Stage 1" tune with accessport2 as more of a performance rather than fuel savings change when considering its purchase. One last question would be... I've heard when your car is tuned for gas savings or your running an "economy" mapping that your engine runs hotter so you shouldn't push it very hard. Is that true? I would think that a gas-savings type tuning would mainly be limiting the amount of fuel injected into the engine. How can a higher oxygen to fuel ratio make the engine run hotter? Thanks, Dean What the Cobb economy map does is limit boost pressure to wastegate levels (7-8psi w/ stock actuator) and increases timing when the motor is in cruise/light acceleration. As soon as there's any load on the engine timing is backed down to where it would normally be. Seriously though, if you're going to buy a GT and always run the economy map you might as well get the non-turbo. The car is very much NOT fun to drive at 7psi. Unless your daily commute is 90% highway with light enough traffic that you can maintain constant highway speeds you're not gonna get the return out of it. Link to comment Share on other sites More sharing options...
Underdog Posted July 30, 2007 Share Posted July 30, 2007 Couldn't think of a better way to say it... But remember, your highest performance map will also be your most fuel efficient map, as long as you stay off the throttle. So if you get the AP (a more efficient tune), and you accelerate the same way, you'll get higher mileage, even with a "performance" map. The Crimson Dynamo Link to comment Share on other sites More sharing options...
wukindada Posted July 31, 2007 Share Posted July 31, 2007 Just purchase a 20g or larger turbo & watch how much better your mileage gets;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
