Meltdown07 Posted July 12, 2007 Share Posted July 12, 2007 I've read several grill tips here, and did some searching, but I need some definitive advice/opinions. I recently switched out my modified grilleguy stock grill for and RBS DIY one I purchased some time ago. Well I got it all painted- several layers of the base, mid-coat, and some clearcoat. The paint was a very good match for stock, but now after a few thousand miles they grill has started to get several rock chips. Obviously I realize things are going to get rock chips, but I feel this has more than it should. What causes this to happen? Is it not enough clearcoat? I was under the impression that the RBS grills were ready for paint, so I did not prime it. Is that causing the problem? Anyone with experience in this sort of thing, what do you advise that I use as my method on this grill? I want to strip it down and do it over again, but if I can do it myself with similar durability to a professional paint job at the dealer or what not I would prefer to do that, since the color match is pretty close, and I still have plenty of left over paint. Anyway, any advice is appreciated! Go Cardinals! Link to comment Share on other sites More sharing options...
GTTuner Posted July 12, 2007 Share Posted July 12, 2007 Unfortunately stone chips are inevitable. My headlights are chipped bad. If I buy new head lights, I will have a summer set and a winter set:) You need a "winter" grille. Link to comment Share on other sites More sharing options...
Gire Posted July 12, 2007 Share Posted July 12, 2007 ^^^ Yup. After 2 and a half years, I realized this earlier this summer. My RBS grille, although I love the look to death, had a thin paint application and has succumbed to about 20 good rocks chips. After painting over those chips with Dealer-purchsed touch up paint, my RBS grille looks like a teenaged girl with bad skin wearing too much cover-up. Bumps and craters galore. 2 months ago I took my stock grille out of the shed and proceeded to paint the chrome ring and supporting parts with about 10 coats of Duplicolor basic black. I left the wings chrome, like they are on the JDM models. It needs a ton of coats to stand up to rock chips and I think 10 ought to do the trick. So far it still looks perfect. I don't think the RBS grilles had 10 coats applied to them. Probably 2, and then a clear coat. This was an RBS grille in white that I bought years ago though... I can't comment on how the paint is holding up on newer batches...probably holding up very well. Link to comment Share on other sites More sharing options...
c-lo Posted July 12, 2007 Share Posted July 12, 2007 I started to repaint my grill when I noticed that the chrome tape started to peel away. So, I started peeling and peeling. I"ve got most of the tape off the bottom, and can't take anymore off. My plan is to use a little bondo to smooth out the grill completely ) like the RBS and than put a s#$% load of paint on. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Spec B Posted July 13, 2007 Share Posted July 13, 2007 I actually take off my DIY grill once every 6 weeks and hit it with a few thin coats of paint. It is actually pretty easy since it is entirely matt black (no need to tape anything off). No matter how many times I paint it, the chips appear.. Link to comment Share on other sites More sharing options...
Meltdown07 Posted July 13, 2007 Author Share Posted July 13, 2007 Okay, well if I had the dealer professionally paint my RBS grill do you think it would hold up any better? I know rock chips are inevitable, but I feel like this thing is chipping too fast. Go Cardinals! Link to comment Share on other sites More sharing options...
