tallguylehigh Posted July 6, 2007 Share Posted July 6, 2007 Ok, I'm having a serious brain fart here, and the search function didnt return anything too helpful. What are the stock wheel weights for the 05 Legacy GT? Thanks! Link to comment Share on other sites More sharing options...
whitetiger Posted July 6, 2007 Share Posted July 6, 2007 Do you know anything about wheel weights? They are just stick on balancing weights. Its not a subaru part. Link to comment Share on other sites More sharing options...
tallguylehigh Posted July 6, 2007 Author Share Posted July 6, 2007 No, I mean what does the actual wheel weigh. Link to comment Share on other sites More sharing options...
chenc544 Posted July 6, 2007 Share Posted July 6, 2007 19-20 lbs Link to comment Share on other sites More sharing options...
hal9e3 Posted July 8, 2007 Share Posted July 8, 2007 19-20 lbs Truth he speaks, AKA +1. Link to comment Share on other sites More sharing options...
Infamous1 Posted July 8, 2007 Share Posted July 8, 2007 Stock wheel and tire(re92's) combo is 56lbs each side. Link to comment Share on other sites More sharing options...
meier motor sports Posted July 8, 2007 Share Posted July 8, 2007 Do you know anything about wheel weights? They are just stick on balancing weights. Its not a subaru part. noob! Link to comment Share on other sites More sharing options...
NewLegGT67 Posted July 9, 2007 Share Posted July 9, 2007 Stock wheel and tire(re92's) combo is 56lbs each side. Okay, I'm a noob. Do you mean 56lbs on each side or each corner? How could the stock wheel and tire combo be 56lbs each side if the stock wheel is 19-20 lbs? That would mean each tire is 8lbs. I weighed my full spare stock wheel and re92 tire combo and it was about 43-44lbs. I'm probably the only person that has Wu-Tang Clan and Paul McCartney on their mp3. Link to comment Share on other sites More sharing options...
Guest Gitster Posted July 9, 2007 Share Posted July 9, 2007 Okay, I'm a noob. Do you mean 56lbs on each side or each corner? How could the stock wheel and tire combo be 56lbs each side if the stock wheel is 19-20 lbs? That would mean each tire is 8lbs. I weighed my full spare stock wheel and re92 tire combo and it was about 43-44lbs. Yeah but was it inflated? I mean we put about 33-36 lbs of air in each tire Link to comment Share on other sites More sharing options...
Infamous1 Posted July 9, 2007 Share Posted July 9, 2007 Okay, I'm a noob. Do you mean 56lbs on each side or each corner? How could the stock wheel and tire combo be 56lbs each side if the stock wheel is 19-20 lbs? That would mean each tire is 8lbs. I weighed my full spare stock wheel and re92 tire combo and it was about 43-44lbs. Sorry each corner, two different wheel and tire both inflated to a high 40psi. 56lbs each, they were noticably heavier than my 19" Arospeeds with PS2's which weighed in at 49lbs. Link to comment Share on other sites More sharing options...
meier motor sports Posted July 9, 2007 Share Posted July 9, 2007 this thread is full of bad info Link to comment Share on other sites More sharing options...
Guest Gitster Posted July 9, 2007 Share Posted July 9, 2007 Link to comment Share on other sites More sharing options...
PhilT Posted July 9, 2007 Share Posted July 9, 2007 Using nitrogen to inflate the tyres will reduce the total per corner by 4 lbs. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Guest Gitster Posted July 9, 2007 Share Posted July 9, 2007 :lol: Link to comment Share on other sites More sharing options...
meier motor sports Posted July 9, 2007 Share Posted July 9, 2007 Using nitrogen to inflate the tyres will reduce the total per corner by 4 lbs. hydrogen or helium would be lighter. i guesss if you want a real answer take a wheel off and weigh it. Link to comment Share on other sites More sharing options...
meier motor sports Posted July 9, 2007 Share Posted July 9, 2007 a stock wheel is a little over 20lbs if i remember. i had to ship 3 of them. tires in our stock size are also around 20lbs each. Link to comment Share on other sites More sharing options...
chenc544 Posted July 9, 2007 Share Posted July 9, 2007 When I took off my stock wheels and tires combo, they weight ~42 lbs total. TireRack has the RE92 at 23 lbs so the OEM wheels are 19-20 lbs give a take a little for 20k miles of wear on the tires. But these numbers are only as good as my bathroom scale is accurate... Link to comment Share on other sites More sharing options...
BigInALegacy Posted July 9, 2007 Share Posted July 9, 2007 I'd say a good enough ballpark... my new 18's weigh 19lbs (Arospeed Xpress). A little Nitrogen, and they'll be lighter than my stockers! WOOT WOOT!! Link to comment Share on other sites More sharing options...
hal9e3 Posted July 9, 2007 Share Posted July 9, 2007 The stock wheel weighs 19 lbs. or maybe a little more. It doesn't weigh less. I weighed several of them myself. Link to comment Share on other sites More sharing options...
Legend Posted August 23, 2007 Share Posted August 23, 2007 I had my 18" 5Zigen Heidfeld Mesh wheels off today. They are wrapped in Michelin Pilot Alpin 225/40/18's (all-season tires) w/ 5K miles on 'em. I thought they felt pretty damn heavy but the combo is 41.5 pounds... lighter than stock 17"??? Surprising. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
croll326 Posted November 16, 2007 Share Posted November 16, 2007 stock wheel with falken ziex 512 worn pretty bad and with 35 PSI weights 38 pounds. i weighed it yesterday. Link to comment Share on other sites More sharing options...
Andreu Posted December 2, 2007 Share Posted December 2, 2007 Stock wheel and tire(re92's) combo is 56lbs each side. Dont you mean 56lbs per wheel and tire? Link to comment Share on other sites More sharing options...
Garandman Posted December 2, 2007 Share Posted December 2, 2007 When I weighed the stock LGT rims before mounting snows, they were between 17-18 lbs, don't recall the exact number. The BBS RK's were almost exactly 18, the stock OB five spokes a lot more. Who Dares Wins スバル Link to comment Share on other sites More sharing options...
