smallblock Posted June 20, 2007 Share Posted June 20, 2007 Has anyone put together a cold air intake that uses the pocket where the passenger side fog light resides as a "ram air" inlet, and relocated the fog lights? Seems like it would work. Plenty of room in there. Link to comment Share on other sites More sharing options...
legacy2005 Posted June 20, 2007 Share Posted June 20, 2007 I just took out the fog light and used some heater pipe to route the air from the fog up to the intake. i hardly use my fogs during summer so its no big deal. figure when winter comes the air will be cold enough that it wont need a ram air so i will take it back apart and put my fog back in. Work hard. Play even harder. My Garage Link to comment Share on other sites More sharing options...
ex-ma hole Posted June 20, 2007 Share Posted June 20, 2007 Notice any performance gains from the airflow? Link to comment Share on other sites More sharing options...
smallblock Posted June 20, 2007 Author Share Posted June 20, 2007 So did you just plumb it into the resonator hole in the stock airbox? I need to measure the air pressure at the stock air intake point and at the fog light hole with a manometer. I'd still rather relocate the fogs. Link to comment Share on other sites More sharing options...
rc0032 Posted June 20, 2007 Share Posted June 20, 2007 Ram air on a turbo car....interesting Link to comment Share on other sites More sharing options...
rao Posted June 20, 2007 Share Posted June 20, 2007 It's like a supercharger on top of a turbocharger. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
rc0032 Posted June 20, 2007 Share Posted June 20, 2007 Really I'm a NOS fan, much less complicated Link to comment Share on other sites More sharing options...
muddy02 Posted June 20, 2007 Share Posted June 20, 2007 might be a dumb question, but how is this any different from the stock intake scoop mounted at the grille? it's "plumbed" to the airbox as well. is the idea to have both? seems like you're still gonna get the same flow out of the air box anyway, no matter how many feeds you run to it. am i missing the idea? It's not about speed, it's about acceleration! Link to comment Share on other sites More sharing options...
legacy2005 Posted June 20, 2007 Share Posted June 20, 2007 I made mine so i could get additional air into the engine bay where the air filter sits. i have a k&n typhoon and it gets mighty toasty at idle. so i rigged up a way to get cooler air from outside the engine bay. Work hard. Play even harder. My Garage Link to comment Share on other sites More sharing options...
muddy02 Posted June 20, 2007 Share Posted June 20, 2007 ^ so you're not using it as an intake, but more of an engine bay cooling inlet? It's not about speed, it's about acceleration! Link to comment Share on other sites More sharing options...
rc0032 Posted June 20, 2007 Share Posted June 20, 2007 I made mine so i could get additional air into the engine bay where the air filter sits. i have a k&n typhoon and it gets mighty toasty at idle. so i rigged up a way to get cooler air from outside the engine bay. But if you are idling there is no movement to "ram" the air in. Link to comment Share on other sites More sharing options...
rao Posted June 20, 2007 Share Posted June 20, 2007 The Air knows it is about to be "rammed home" so to speak so it starts moving even while idling Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
legacy2005 Posted June 20, 2007 Share Posted June 20, 2007 its more of a cooling unit, mainly made it for when i was on the dyno. so i could set a fan up in front of it so the intake temps would be 200+. plus it doesnt hurt to have for autox, any air i can get to the filter helps a great deal. Work hard. Play even harder. My Garage Link to comment Share on other sites More sharing options...
smallblock Posted June 21, 2007 Author Share Posted June 21, 2007 The path through the stock air scoop behind the grille looks quite torturous, and I'd like to get cool air from a high pressure area. The fog light looks like an ideal place, although testing may show that it holds no benefit over the stock scoop due to its location. I'm just looking to see what kind of data exists for those who have tried it. Thanks to legacy2005 for your observations about your setup. Time for some instrumented testing, I guess. We all seek to maximize n in PV=nRT (the ideal gas law), this applies to NA or forced induction. Colder, higher pressure air is always better, be it straight into the throttle body or compressor. Link to comment Share on other sites More sharing options...
SIA Posted June 21, 2007 Share Posted June 21, 2007 What I did is take a piece of aluminum and angle it from behind the grill into the stock air inlet under the hood. Attaching it to the radiator support. It didn't seem to do much at low speeds but something is going on there because I am getting better mileage. Most of my driving is highway and when it rains (real hard) the filter gets wet. Link to comment Share on other sites More sharing options...
qikslvr Posted June 27, 2007 Share Posted June 27, 2007 I ended up going to an AEM CAI because when I put the Subaru Bug Deflector on it basically closed that intake on the top of the grill off almost completely. Now my air filter is way down in the passenger tire well where there is really no "open or free-flowing" access to the outside air. It runs better with the skidplate off, but I would rather not, so this may be a good option or starting point. I may just make a snorkel that goes through the side of the skid right in that area. Let's kick this pig! Link to comment Share on other sites More sharing options...
SeeeeeYa Posted June 27, 2007 Share Posted June 27, 2007 I ended up going to an AEM CAI because when I put the Subaru Bug Deflector on it basically closed that intake on the top of the grill off almost completely. Now my air filter is way down in the passenger tire well where there is really no "open or free-flowing" access to the outside air. It runs better with the skidplate off, but I would rather not, so this may be a good option or starting point. I may just make a snorkel that goes through the side of the skid right in that area. Actually, I don't think you have to do, or remove, anything with that AEM down there. Taking that 'skidplate' off is bad both for the car's airflow and for cooling. It helps draw air through the TMIC as well as engine compartment. Extensive logging has shown that the AEM CAI allows IATs from 0 to 3 degrees of ambient, excellent numbers unaproachable with short rams or stock intake. The ONLY modification to the AEM installation I made concerned potential water problems some have reported. You can bet that taking that undercover off would greatly exacerbate that issue. Link to comment Share on other sites More sharing options...
qikslvr Posted June 27, 2007 Share Posted June 27, 2007 Ya, I'm just talking about track days. I'm aware that the bottom of my air filter is only about 8" off the ground on the gutter side and the engine bay opening is perfect for water splash. Thats why I have a heatshield on the exposed side of my filter already. Besides, I don't drive my car in the rain or the winter if I can help it. Thats why I have a Jeep, Range Rover or Yaris. As for cooling; (again at the track) with the skidplate and engine shroud on; my engine won't cool down at all inbetween runs this time of year even after an hour between runs. Removing the skidplate would at least allow air to actually flow through the engine compartment(by convection if nothing else) and blow onto the block and oil pan while the vehicle is sitting still with the hood up and the engine is not running. Let's kick this pig! Link to comment Share on other sites More sharing options...
Saul_Good Posted June 29, 2007 Share Posted June 29, 2007 If you want ram air i think this would be good. http://img518.imageshack.us/img518/1283/airgrilck6.jpg Link to comment Share on other sites More sharing options...
hutru01 Posted June 29, 2007 Share Posted June 29, 2007 But if you are idling there is no movement to "ram" the air in. at "ramming" the air in Link to comment Share on other sites More sharing options...
pjcampbell Posted April 7, 2020 Share Posted April 7, 2020 Has anyone come up with a decent way to do this? My goal would be getting intake air as close to ambient as possible. I will have a large Cone air filter sitting down in that area where the airbox used to be. I could just remove the pax side fog light but I think it will look pretty bad. I don't need either fog light so willing to remove both, but would like something that looks decent and preferably inconspicuous. Maybe it would look fine w/o the fog light at all? Just a big gaping hole? Link to comment Share on other sites More sharing options...
shralp Posted April 9, 2020 Share Posted April 9, 2020 See my brake duct post, guess you could do something like that... https://legacygt.com/forums/showthread.php/roo-brake-ducts-install-pics-214102.html?t=214102 Link to comment Share on other sites More sharing options...
m sprank Posted April 13, 2020 Share Posted April 13, 2020 Way to revive a dead thread. It was dead for a reason. LOL. It works on drag cars with 4" intakes and low mount turbos. Link to comment Share on other sites More sharing options...
boxkita Posted April 13, 2020 Share Posted April 13, 2020 for a track car, you want air from high up on the car. Everything near the surface is dirty, oily, gritty and otherwise terrible for your engine. The front snorkel is extremely good at bringing in enough air with very little water content. If you really want a bigger snorkel, I had one custom made in cf. Has a scoop to gather more air. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
pjcampbell Posted April 15, 2020 Share Posted April 15, 2020 At the moment I have a very large cone filter in the stock airbox location, probably not bad for IAT. If nothing else, leaving the air filter ON and temporarily removing the fog light for a drag strip day should not hurt, but not sure if it would help to make it worth the effort. If I could get the air UP to cool my supercharger (like the brake duct one) that might be the best use of it. Link to comment Share on other sites More sharing options...
