Effin Ponderous Posted May 30, 2007 Share Posted May 30, 2007 I have cusco front and rear sways...just put new bushings on them about a month ago. The right rear bracket just snapped today...no apparent reason except what some have warned about. Is there a fix or do I need to weld? I've searched and cant find anything Cusco specific. Link to comment Share on other sites More sharing options...
Legacy05 Posted May 30, 2007 Share Posted May 30, 2007 I think you will need to get it welded .. and I would suggest then ordering the AVO re-enforcement brackets .. I have those .. I also have the CUSCO RSB ... Link to comment Share on other sites More sharing options...
SnoDork Posted May 30, 2007 Share Posted May 30, 2007 Wow!! Got any pictures?!? ~Sucka-Duck~ Link to comment Share on other sites More sharing options...
Effin Ponderous Posted May 30, 2007 Author Share Posted May 30, 2007 No, I'll take them tomorrow. Shite!!!! Link to comment Share on other sites More sharing options...
Jim_KT Posted May 31, 2007 Share Posted May 31, 2007 Definitely get it welded back together and be sure to order up some reinforcement brackets, or make them on your own. I went the easy route and purchased a set of AVO brackets from a member. Link to comment Share on other sites More sharing options...
Effin Ponderous Posted May 31, 2007 Author Share Posted May 31, 2007 Can I do it without the welding and just the brackets? Link to comment Share on other sites More sharing options...
Effin Ponderous Posted May 31, 2007 Author Share Posted May 31, 2007 will the AVo work with Cusco? Link to comment Share on other sites More sharing options...
Jim_KT Posted May 31, 2007 Share Posted May 31, 2007 I'm guessing that you probably could, but if it were me - I'd have a competent welder put your bracket back together for safe measure. Link to comment Share on other sites More sharing options...
BlackHole Posted May 31, 2007 Share Posted May 31, 2007 will the AVo work with Cusco? Yes, they'll work with any swaybar, OEM or aftermarket. They are just heavy duty brackets that replace the flimsy stock units. AVO had them on their website for $80 shipped last weekend. Kyle "BlackHole" Kyle "BlackHole" Link to comment Share on other sites More sharing options...
Legacy05 Posted May 31, 2007 Share Posted May 31, 2007 Yes they will work I have them with my CUSCO RSB. Link to comment Share on other sites More sharing options...
Opie Posted May 31, 2007 Share Posted May 31, 2007 I have cusco front and rear sways...just put new bushings on them about a month ago. The right rear bracket just snapped today...no apparent reason except what some have warned about. Is there a fix or do I need to weld? I've searched and cant find anything Cusco specific. What other suspension mods do you have? Link to comment Share on other sites More sharing options...
azca Posted May 31, 2007 Share Posted May 31, 2007 you didn't have reinforcement brackets installed? Link to comment Share on other sites More sharing options...
Pete Fowler Posted May 31, 2007 Share Posted May 31, 2007 Bein' a noob my opinion is suspect, but I remember reading a thread recently where the word out of Japan was you should have the RSB mount rewelded first, then add the AVO (or other) reinforcement bracket. Seems the reinforcement brackets need a solid OEM mount to work properly. Please read up and confirm, of course. Pete Link to comment Share on other sites More sharing options...
jagcars26 Posted May 31, 2007 Share Posted May 31, 2007 This is the first I've heard of the Cuscos busting mounts,,,other suspension mods??? Link to comment Share on other sites More sharing options...
robinlsb Posted May 31, 2007 Share Posted May 31, 2007 As I have said in the past. The rear mounts are toys. If you put in a RSB either add the reinforcements then, or spend bigger bucks later. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
SnoDork Posted May 31, 2007 Share Posted May 31, 2007 I have cusco front and rear sways...just put new bushings on them about a month ago. The right rear bracket just snapped today...no apparent reason except what some have warned about. Is there a fix or do I need to weld? I've searched and cant find anything Cusco specific. What bushings did you use? OEM? Aftermarket/Harder material?? Were your Rear Bushings Shot?...Was the traditional swaybar prep of greasing the bushing... How did you know it snapped? Did the car drive differently? Did you hear an "noise" or did you discover it while under the car doing other maintanence?? Sorry for all the questions... ~Sucka-Duck~ Link to comment Share on other sites More sharing options...
Legacy05 Posted May 31, 2007 Share Posted May 31, 2007 good questions, were you using the stock endlinks?? I am ... Link to comment Share on other sites More sharing options...
Effin Ponderous Posted May 31, 2007 Author Share Posted May 31, 2007 Energy suspension bushings put on a month ago. I drive the car like the old man that I am (for the most part) Used plenty of the bushing special lube. I knew it snapped because i heard a loud bang. Stock endlinks because my MSI adjustables weren't necessary (heightwise) Link to comment Share on other sites More sharing options...
Effin Ponderous Posted May 31, 2007 Author Share Posted May 31, 2007 I took camera phone pics but they suck. I am having the repair done at a great shop across the street from me. The welder is an engineer as well and is not only repairing the broken side, but reinforcing both sides so it won't happen again. The whole thing will cost me $200 Link to comment Share on other sites More sharing options...
Legacy05 Posted May 31, 2007 Share Posted May 31, 2007 Nice nice. Link to comment Share on other sites More sharing options...
SnoDork Posted May 31, 2007 Share Posted May 31, 2007 I am having the repair done at a great shop across the street from me. The welder is an engineer as well and is not only repairing the broken side, but reinforcing both sides so it won't happen again. The whole thing will cost me $200 ^^Pictures of that FO Sho! ~Sucka-Duck~ Link to comment Share on other sites More sharing options...
HansGT Posted May 31, 2007 Share Posted May 31, 2007 Link to comment Share on other sites More sharing options...
Effin Ponderous Posted May 31, 2007 Author Share Posted May 31, 2007 Bad Camera phone pic but hopefully you can see where everything snapped (pic is on an angle) Link to comment Share on other sites More sharing options...
G.T.Subie Posted May 31, 2007 Share Posted May 31, 2007 Sh*t ! Could lowering springs cause this? Denial is your best friend Link to comment Share on other sites More sharing options...
lawl Posted May 31, 2007 Share Posted May 31, 2007 that does it. Going coilovers and that'll be the end of suspension mods. (or JDM rear bar, if any) car for sale. PM me! Link to comment Share on other sites More sharing options...
