V-Power Posted May 6, 2007 Share Posted May 6, 2007 I started hearing an annoying hum from what I believe is the right rear of the car. Only noticeable above 55mph ... accelerate up to 100mph and it gets louder. The car drives good, it's just that sound is getting on my nerves ... dropped my friend off last night and his comment was "why's your car sound like it's powered by an outboard motor?" When I took it into the Dealer, of course they couldn't "duplicate" and noted "it's your tires ... " B.S. Any clues? Could this be the infamous wheel bearing? Thanks! Link to comment Share on other sites More sharing options...
jim1969 Posted May 6, 2007 Share Posted May 6, 2007 diff? Link to comment Share on other sites More sharing options...
Beanboy Posted May 6, 2007 Share Posted May 6, 2007 Passenger rear eh? I say wheel bearing. Some reason by far the most common bearing to go first. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
Emmo Posted May 7, 2007 Share Posted May 7, 2007 I'm going to go with wheel bearing as well. I just had mine replaced under warranty. I literally couldn't hear the radio, pretty annoying. Link to comment Share on other sites More sharing options...
Jim_KT Posted May 7, 2007 Share Posted May 7, 2007 +1 on the wheel bearing. Been there, done that. If you can somehow (either you and your buddies or a reputable shop) lift your vehicle off of all fours and put it in drive and allow it to idle, you should be able to hear the offending bearing. The passenger side rear bearing went out on my LGT as well and my preferred mechanic diagnosed it as such. As a side note, the same mechanic replaced the bearing with genuine Subaru components and I was able to get the cost of parts and labor reimbursed by SOA. SOA has a clause in their warranty that if the nearest Subaru dealership is greater than 70-80 miles from you, then you can take your vehicle to a local automotive repair facility and they will reimburse you if you provide SOA with a sales receipt and defective component(s) as well as a letter clarifying your reasons as to why said vehicle was repaired at a non-Subaru facility. I just wanted to throw my experience out there just in case you fall under the same, or if anyone else for that matter. Link to comment Share on other sites More sharing options...
V-Power Posted May 8, 2007 Author Share Posted May 8, 2007 thanks folks ... time for another visit to the dealer. love the car, hate the nagging issues Link to comment Share on other sites More sharing options...
CarlosLGT Posted May 9, 2007 Share Posted May 9, 2007 +1 only mine was the LF corner, they blamed the initial grease not being viscous enough, so they've switched. Link to comment Share on other sites More sharing options...
c-lo Posted June 12, 2007 Share Posted June 12, 2007 I have this now too:mad:. I hear it over 40mph. Can this be a DIY job? what am I looking at to have the dealer take care of it? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
fatbastard Posted June 12, 2007 Share Posted June 12, 2007 Wheel bearings are covered to 60k...are you over that? I know I have to bring mine in for one now too. Link to comment Share on other sites More sharing options...
c-lo Posted June 12, 2007 Share Posted June 12, 2007 Wheel bearings are covered to 60k...are you over that? I know I have to bring mine in for one now too. 68k! what luck huh:mad: 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
fatbastard Posted June 13, 2007 Share Posted June 13, 2007 Doh...well I would imagine it isn't too bad. If I remember correctly the wife had one replaced on her A4 at Audi for ~$100 and they are spensive but I think the Subie bearing is more expensive...go figure. Link to comment Share on other sites More sharing options...
g-mann Posted June 13, 2007 Share Posted June 13, 2007 price on hub bearing assy around $125 msrp, very common replacement in our area. Link to comment Share on other sites More sharing options...
c-lo Posted June 13, 2007 Share Posted June 13, 2007 price on hub bearing assy around $125 msrp, very common replacement in our area. is this a job one can do on their own or best left to a mechanic? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
fatbastard Posted June 13, 2007 Share Posted June 13, 2007 Haven't done one on a Subie but typically you'll need a bearing puller which you could rent but unless you are excited by doing this on your own you probably won't save much if anything. Link to comment Share on other sites More sharing options...
derffred Posted June 13, 2007 Share Posted June 13, 2007 Take it to someone that knows what they're doing Link to comment Share on other sites More sharing options...
c-lo Posted June 13, 2007 Share Posted June 13, 2007 yeah, think I"ll do that 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
g-mann Posted June 13, 2007 Share Posted June 13, 2007 Double check me on this, you should have the hub & bearing assy that just taps off, after bolt removal. It will sometimes stick to the backing plate, but basic r&r is pretty straight up. showing the pn 28473AG00B for the car. If your buying the part anyway, take it home & ck it out - no worse off for taking a quick look. Link to comment Share on other sites More sharing options...
c-lo Posted June 13, 2007 Share Posted June 13, 2007 thanks. will do. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
AKLGT Posted June 13, 2007 Share Posted June 13, 2007 i've had both the front and rear driver's side bearing and hub replaced now. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
c-lo Posted June 13, 2007 Share Posted June 13, 2007 i've had both the front and rear driver's side bearing and hub replaced now. why? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
AKLGT Posted June 13, 2007 Share Posted June 13, 2007 because they were bad. why else would they be replaced under warranty?? Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
c-lo Posted June 13, 2007 Share Posted June 13, 2007 because they were bad. why else would they be replaced under warranty?? duh, just re-read your post. thought you were telling me to replace all of them:lol:. gonna do it myself. buddy down the street is quite familiar with this job 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
